EKZE160ELL222MJ251
EKZE160ELL222MJ251
    NCC(贵弥功)
    AEC-D10X25MM_TM
    2200UF ±20% 16V
EKZE160ELL222MJ251 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS KZE Low impedance, 105℃ KZH Series Lower Z KZE ・Newly innovative electrolyte is employed to minimize impedance ・Endurance with ripple current: 2,000 to 5,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant Lower Z KY ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ 6.3 to 100Vdc ±20% (M) I=0.01CV or 3µA, whichever is greater. Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 6.3V 10V 16V 25V 35V 50V 63V 80V 100V tanδ (Max.) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.09 0.08 When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase. Z (-25℃) / Z (+20℃) 2max. Z (-40℃) / Z (+20℃) 3max. Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃. Time φ5 &φ6.3 : 2,000hours φ8 : 3,000hours φ10 : 4,000hours φ12.5 toφ18 : 5,000hours Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±25% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve (PET : Brown) F±0.5 ●Terminal L' Vent (Except φ5 &φ6.3) φD φd F φD' L' 5 0.5 2.0 15min 4min (φ5 to φ10) (φ12.5 to φ18) Gas escape end seal 6.3 0.5 2.5 8 10, 12.5 0.6 0.6 3.5 5.0 φD+0.5max. L+1.5max. 16, 18 0.8 7.5 ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KZ E AAA E AA AAA M AAA N Supplement code Size code Capacitance tolerance code Capacitance code (ex. 6.8µF:6R8, 10µF:100, 1,000µF:102) Lead forming·taping code Terminal code Voltage code (ex. 6.3V:6R3, 10V:100, 100V:101) Series code Category Please refer to "Product code guide (radial lead type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZESeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 6.3 10 16 25 35 150 330 560 820 1,000 1,200 1,200 1,500 2,200 3,300 3,900 4,700 5,600 5,600 6,800 100 220 470 680 680 1,000 1,000 1,200 1,500 2,200 3,300 3,900 3,900 4,700 5,600 56 120 330 470 470 680 680 1,000 1,200 1,500 2,200 2,700 2,700 3,300 3,900 47 100 220 330 330 470 470 680 820 1,000 1,500 1,800 1,800 2,200 2,700 33 56 150 220 220 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.30 0.13 0.072 0.056 0.053 0.041 0.038 0.023 0.022 0.021 0.018 0.016 0.015 0.018 0.016 0.30 0.13 0.072 0.056 0.053 0.041 0.038 0.023 0.022 0.021 0.018 0.016 0.018 0.015 0.016 0.30 0.13 0.072 0.056 0.053 0.041 0.038 0.023 0.022 0.021 0.018 0.016 0.018 0.015 0.016 0.30 0.13 0.072 0.056 0.053 0.041 0.038 0.023 0.022 0.021 0.018 0.016 0.018 0.015 0.016 0.30 0.13 0.072 0.056 0.053 1.0 0.41 0.22 0.17 0.16 0.13 0.12 0.069 0.066 0.053 0.045 0.041 0.039 0.045 0.043 1.0 0.41 0.22 0.17 0.16 0.13 0.12 0.069 0.066 0.053 0.045 0.041 0.045 0.039 0.043 1.0 0.41 0.22 0.17 0.16 0.13 0.12 0.069 0.066 0.053 0.045 0.041 0.045 0.039 0.043 1.0 0.41 0.22 0.17 0.16 0.13 0.12 0.069 0.066 0.053 0.045 0.041 0.045 0.039 0.043 1.0 0.41 0.22 0.17 0.16 250 405 760 995 1,030 1,250 1,430 1,820 2,150 2,360 2,770 3,290 3,400 3,140 3,460 250 405 760 995 1,030 1,250 1,430 1,820 2,150 2,360 2,770 3,290 3,140 3,400 3,460 250 405 760 995 1,030 1,250 1,430 1,820 2,150 2,360 2,770 3,290 3,140 3,400 3,460 250 405 760 995 1,030 1,250 1,430 1,820 2,150 2,360 2,770 3,290 3,140 3,400 3,460 250 405 760 995 1,030 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKZE6R3E□□151ME11D EKZE6R3E□□331MF11D EKZE6R3E□□561MHB5D EKZE6R3E□□821MH15D EKZE6R3E□□102MJC5S EKZE6R3E□□122MH20D EKZE6R3E□□122MJ16S EKZE6R3E□□152MJ20S EKZE6R3E□□222MJ25S EKZE6R3E□□332MK20S EKZE6R3E□□392MK25S EKZE6R3E□□472MK30S EKZE6R3E□□562MK35S EKZE6R3E□□562ML20S EKZE6R3E□□682ML25S EKZE100E□□101ME11D EKZE100E□□221MF11D EKZE100E□□471MHB5D EKZE100E□□681MH15D EKZE100E□□681MJC5S EKZE100E□□102MH20D EKZE100E□□102MJ16S EKZE100E□□122MJ20S EKZE100E□□152MJ25S EKZE100E□□222MK20S EKZE100E□□332MK25S EKZE100E□□392MK30S EKZE100E□□392ML20S EKZE100E□□472MK35S EKZE100E□□562ML25S EKZE160E□□560ME11D EKZE160E□□121MF11D EKZE160E□□331MHB5D EKZE160E□□471MH15D EKZE160E□□471MJC5S EKZE160E□□681MH20D EKZE160E□□681MJ16S EKZE160E□□102MJ20S EKZE160E□□122MJ25S EKZE160E□□152MK20S EKZE160E□□222MK25S EKZE160E□□272MK30S EKZE160E□□272ML20S EKZE160E□□332MK35S EKZE160E□□392ML25S EKZE250E□□470ME11D EKZE250E□□101MF11D EKZE250E□□221MHB5D EKZE250E□□331MH15D EKZE250E□□331MJC5S EKZE250E□□471MH20D EKZE250E□□471MJ16S EKZE250E□□681MJ20S EKZE250E□□821MJ25S EKZE250E□□102MK20S EKZE250E□□152MK25S EKZE250E□□182MK30S EKZE250E□□182ML20S EKZE250E□□222MK35S EKZE250E□□272ML25S EKZE350E□□330ME11D EKZE350E□□560MF11D EKZE350E□□151MHB5D EKZE350E□□221MH15D EKZE350E□□221MJC5S 35 50 63 80 270 330 470 560 680 1,000 1,200 1,200 1,500 1,800 22 56 100 120 150 180 220 270 330 470 560 680 820 820 1,000 15 33 56 82 82 120 120 180 180 220 270 390 470 470 560 680 680 680 820 820 1,000 1,200 1,200 1,500 1,800 68 100 120 150 150 220 330 330 390 470 470 470 560 680 680 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 10×25 12.5×20 12.5×25 12.5×30 12.5×35 16×20 16×25 5×11 6.3×11 8×11.5 8×15 10×12.5 8×20 10×16 10×20 12.5×16 10×25 12.5×20 12.5×25 12.5×30 16×20 12.5×35 12.5×40 16×25 18×20 16×31.5 18×25 16×35.5 16×40 18×31.5 18×35.5 18×40 10×12.5 10×16 10×20 10×25 12.5×16 12.5×20 12.5×25 16×20 12.5×30 12.5×35 16×25 18×20 12.5×40 16×31.5 18×25 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.041 0.038 0.023 0.022 0.021 0.018 0.016 0.018 0.015 0.016 0.34 0.14 0.074 0.061 0.061 0.046 0.042 0.030 0.028 0.027 0.023 0.021 0.019 0.023 0.021 0.88 0.35 0.22 0.16 0.11 0.12 0.076 0.056 0.072 0.046 0.041 0.031 0.028 0.032 0.024 0.021 0.025 0.030 0.021 0.024 0.019 0.018 0.020 0.018 0.017 0.17 0.11 0.084 0.069 0.11 0.062 0.047 0.048 0.042 0.036 0.038 0.045 0.032 0.032 0.036 0.13 0.12 0.069 0.066 0.053 0.045 0.041 0.045 0.039 0.043 1.18 0.50 0.22 0.18 0.18 0.14 0.12 0.090 0.085 0.068 0.059 0.052 0.051 0.059 0.056 3.5 1.4 0.88 0.64 0.44 0.48 0.31 0.23 0.29 0.19 0.13 0.093 0.084 0.096 0.072 0.063 0.075 0.090 0.063 0.072 0.057 0.054 0.060 0.054 0.051 0.66 0.47 0.34 0.28 0.34 0.18 0.14 0.15 0.13 0.11 0.12 0.14 0.095 0.095 0.11 1,250 1,430 1,820 2,150 2,360 2,770 3,290 3,140 3,400 3,460 238 385 724 950 979 1,190 1,370 1,580 1,870 2,050 2,410 2,860 2,960 2,730 3,010 165 265 500 665 690 820 950 1,150 1,150 1,350 1,500 1,900 2,300 2,000 2,500 2,800 2,600 2,500 2,850 2,800 2,900 3,400 3,300 3,400 3,500 480 600 800 900 750 1,100 1,250 1,350 1,500 1,650 1,700 1,500 1,800 1,850 1,750 Part No. EKZE350E□□271MH20D EKZE350E□□331MJ16S EKZE350E□□471MJ20S EKZE350E□□561MJ25S EKZE350E□□681MK20S EKZE350E□□102MK25S EKZE350E□□122MK30S EKZE350E□□122ML20S EKZE350E□□152MK35S EKZE350E□□182ML25S EKZE500E□□220ME11D EKZE500E□□560MF11D EKZE500E□□101MHB5D EKZE500E□□121MH15D EKZE500E□□151MJC5S EKZE500E□□181MH20D EKZE500E□□221MJ16S EKZE500E□□271MJ20S EKZE500E□□331MJ25S EKZE500E□□471MK20S EKZE500E□□561MK25S EKZE500E□□681MK30S EKZE500E□□821MK35S EKZE500E□□821ML20S EKZE500E□□102ML25S EKZE630E□□150ME11D EKZE630E□□330MF11D EKZE630E□□560MHB5D EKZE630E□□820MH15D EKZE630E□□820MJC5S EKZE630E□□121MH20D EKZE630E□□121MJ16S EKZE630E□□181MJ20S EKZE630E□□181MK16S EKZE630E□□221MJ25S EKZE630E□□271MK20S EKZE630E□□391MK25S EKZE630E□□471MK30S EKZE630E□□471ML20S EKZE630E□□561MK35S EKZE630E□□681MK40S EKZE630E□□681ML25S EKZE630E□□681MM20S EKZE630E□□821MLN3S EKZE630E□□821MM25S EKZE630E□□102MLP1S EKZE630E□□122ML40S EKZE630E□□122MMN3S EKZE630E□□152MMP1S EKZE630E□□182MM40S EKZE800E□□680MJC5S EKZE800E□□101MJ16S EKZE800E□□121MJ20S EKZE800E□□151MJ25S EKZE800E□□151MK16S EKZE800E□□221MK20S EKZE800E□□331MK25S EKZE800E□□331ML20S EKZE800E□□391MK30S EKZE800E□□471MK35S EKZE800E□□471ML25S EKZE800E□□471MM20S EKZE800E□□561MK40S EKZE800E□□681MLN3S EKZE800E□□681MM25S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS Low impedance, 105℃ KZESeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ 820 16×35.5 820 18×31.5 80 1,000 16×40 1,000 18×35.5 1,200 18×40 6.8 5×11 15 6.3×11 27 8×11.5 39 8×15 47 10×12.5 100 56 8×20 68 10×16 82 10×20 100 12.5×16 120 10×25 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.029 0.030 0.027 0.027 0.026 1.4 0.57 0.36 0.25 0.17 0.19 0.11 0.084 0.11 0.069 0.086 0.090 0.081 0.081 0.077 5.6 2.3 1.4 1.0 0.66 0.76 0.47 0.34 0.34 0.28 2,000 1,900 2,200 2,200 2,700 125 205 355 450 480 565 600 800 750 900 Part No. WV (Vdc) Cap (µF) Case size φD×L(mm) 20℃ EKZE800E□□821MLP1S EKZE800E□□821MMN3S EKZE800E□□102ML40S EKZE800E□□102MMP1S EKZE800E□□122MM40S EKZE101E□□6R8ME11D EKZE101E□□150MF11D EKZE101E□□270MHB5D EKZE101E□□390MH15D EKZE101E□□470MJC5S EKZE101E□□560MH20D EKZE101E□□680MJ16S EKZE101E□□820MJ20S EKZE101E□□101MK16S EKZE101E□□121MJ25S 100 150 220 220 270 330 330 330 390 470 470 560 560 680 680 820 12.5×20 12.5×25 16×20 12.5×30 12.5×35 16×25 18×20 12.5×40 16×31.5 18×25 16×35.5 18×31.5 16×40 18×35.5 18×40 Rated ripple current (mArms/ -10℃ 105℃, 100kHz) Impedance (Ω max./100kHz) 0.062 0.047 0.048 0.042 0.036 0.038 0.045 0.032 0.032 0.036 0.029 0.030 0.027 0.027 0.026 0.18 0.14 0.15 0.13 0.11 0.12 0.14 0.095 0.095 0.11 0.086 0.090 0.081 0.081 0.077 1,100 1,250 1,350 1,500 1,650 1,700 1,500 1,800 1,850 1,750 2,000 1,900 2,200 2,200 2,700 Part No. EKZE101E□□151MK20S EKZE101E□□221MK25S EKZE101E□□221ML20S EKZE101E□□271MK30S EKZE101E□□331MK35S EKZE101E□□331ML25S EKZE101E□□331MM20S EKZE101E□□391MK40S EKZE101E□□471MLN3S EKZE101E□□471MM25S EKZE101E□□561MLP1S EKZE101E□□561MMN3S EKZE101E□□681ML40S EKZE101E□□681MMP1S EKZE101E□□821MM40S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Capacitance(µF) 6.8 220 680 2,200 4,700 to to to to to 180 560 1,800 3,900 120 0.40 0.50 0.60 0.75 0.85 1k 0.75 0.85 0.87 0.90 0.95 10k 0.90 0.94 0.95 0.95 0.98 100k 1.00 1.00 1.00 1.00 1.00 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
EKZE160ELL222MJ251 价格&库存
很抱歉,暂时无法提供与“EKZE160ELL222MJ251”相匹配的价格&库存,您可以联系我们找货
