1. Device Name
VC-TCXO
2. Model Name
DSA321SDA
3. Nominal Frequency
20.000 MHz
4. Mass
0.03g max.
5. Absolute Maximum Ratings
1
2
Item
Supply Voltage
Storage Temperature Range
6. Recommended Operating Conditions
1
2
3
4
Item
Supply Voltage
Load Impedance (resistance part)
(parallel capacitance)
Control Voltage Range
Operating Temperature Range
7. Electrical Characteristics
Symbol
VCC
T_STG
Symbol
VCC
LOAD_R
LOAD_C
VCONT
T_OPR
Rating
-0.3~+6.0
-40~+85
min.
+3.135
9
9
+0.5
-40
typ.
+3.3
10
10
+1.5
unit
V
°C
max.
+3.465
11
11
+2.5
+85
unit
V
kΩ
pF
V
°C
(TA=-40~+85°C, LOAD_R//C=10kΩ//10pF, VCC=+3.3V, VCONT=+1.5V, unless otherwise noted)
Item
1
2
3
4
Current Consumption
Output Level
Symmetry
Frequency Stability
1.Tolerance
2.vs Temperature
5
6
3.vs Supply Voltage
4.vs Load Variation
5.vs Aging
Start Up Time
Frequency Control
1.Control Range
2.Input Resistance
SSB Phase Noise
Conditions
GND level (DC cut)
After 2 times reflow
Ref. to Nominal Frequency
TA=-30~+85°C
Ref. to Frequency (TA=+25°C)
TA=-40~-30°C
VCC=+3.3V±5%
LOAD_R//C=(10kΩ//10pF)±10%
TA=Room ambient
@90% of final Vout level
VCONT=+0.5V~+2.5V(Ref.+1.5V)
min.
0.8
40/60
Limits
typ
max.
+1.5
60/40
unit
Notes
mA
VP-P
1
±1.5
ppm
2
±0.5
ppm
±1.0
ppm
±0.2
±0.2
±1.0
2.0
ppm
ppm
ppm/year
ms
±9
500
±15
-130
ppm
kΩ
dBc/Hz
7
Relative to f0 level offset 1kHz
Notes
1. Clipped sine wave (DC-coupled)
2. Please leave after reflow in 2h or more at room ambient.
3. Positive slope (Frequency becomes high in proportion to frequency control voltage.)
TITLE
3
Remark
DSA321SDA TYPE SPECIFICATION
Date
2012/09/19
Spec. No.
1XTV20000CDA
DAISHINKU CORP.
Rev.
Page
1/2
DM-Z0002: Style-010
8. Outline, Pin Connections
Outline
(1)
Pin Connections
Pin No.
#1
#2
#3
#4
(2)
D
(3)
Marking
(1) Frequency
(2) Model code
(3) Date code
#1 Index
Connection
VCONT
GND
Output
VCC
20.00 (MHz, 4digits)
S
Year (1digit) +Week (2digits)
e.g.2012/01/01
201
unit: mm
Dimensional Tolerance: ±0.15
(Unless otherwise noted)
9. Measurement Circuit
1000pF
T.P.
mA
#3
#4
10000pF
Power
Supply
Vcc
VC-TCXO
V
VCONT
Output
GND
#1
VCONT
TITLE
LOAD_C
LOAD_R
#2
LOAD_R=10kΩ
LOAD_C=10pF (Include Jig stray capacitance)
Remark
Date
2012/09/19
Spec. No.
1XTV20000CDA
DAISHINKU CORP.
Rev.
Page
2/2
DM-Z0002: Style-010
很抱歉,暂时无法提供与“1XTV20000CDA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.21440
- 10+5.85360
- 30+5.17320
- 100+4.50360
