RGA222M1ECC-1320G
RGA222M1ECC-1320G
    LELON(立隆电子)
    AEC-D12.5X20MM_TM
    2200UF ±20% 25V
RGA222M1ECC-1320G 数据手册
Lelon P/N: RGA222M1ECC-1320G LELON ELECTRONICS CORP. Page: 1 / 1 2200 μF / 25 V – 12.5φ × 20L RGA : 日鑫股份有限公司 CUSTOMER CUSTOMER P/N: RGA222M1ECC-1320G PRODUCT DIMENSIONS Unit: mm φD L F φd+/-0.05 α β Items 12.5 20 5.0 0.6 2.0 0.5 Performance Rated Voltage VR 25 V Capacitance CR 2200 µF (120 Hz, 20℃) Category Temperature Range -40℃ ~ +105℃ Capacitance Tolerance -20 % ~ +20 % Surge Voltage VS (120 Hz, 20℃) 28.8 VDC ILEAK ≦ 550 µA Leakage Current (20℃) Tan δ Ripple Current (IAC, R /rms) Low Temperature Characteristics at 120 Hz ≦ 0.16 (120 Hz, 20℃) 1000 mA (120 Hz, 105℃) Z(-25℃) / Z(+20℃) 2 Z(-40℃) / Z(+20℃) 4 Impedance ratio Ripple Current (A) and Frequency Multipliers Endurance and Shelf Life Test After 2 minutes Frequency (Hz) 60(50) 120 500 1k 10k up Multipliers 0.80 1.00 1.10 1.12 1.15 Items Endurance Shelf Life Test Test Time 2,000 Hrs at 105℃, VR, IAC, R 1,000 Hrs at 105℃ Cap. Change Within ±20 % of initial value Within ±20 % of initial value Tan δ Less than 200% of specified value Less than 200% of specified value Leakage Current Within specified value Within specified value During dip or wave soldering, temperature at the capacitors terminals should be less than 260 ± 5 ℃, 10 ± 1 seconds. Solder heat-resistance Standards JIS C 5101-4, IEC 60384-4 Remarks RoHS Compliance, Halogen-free * Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in Lelon's catalog for further details. Publication Date September 8, 2022 Approval Signatures: Revision Date Version No. 1 Please return one copy with your approval RDD0366A, A4, 100309 Approved Checked Designed R&D R&D R&D SEP. 8, 2022 SEP. 8. 2022 SEP. 8. 2022 H. Y. Huang J.H.Xiong Z. X. Sun
RGA222M1ECC-1320G 价格&库存
很抱歉,暂时无法提供与“RGA222M1ECC-1320G”相匹配的价格&库存,您可以联系我们找货
RGA222M1ECC-1320G
  • 5+0.68818
  • 50+0.53655
  • 200+0.45706
库存:49
