MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KZM
Low impedance, 105℃
KZN
Series
Higher ripple
・Long-Life version of KZH series
・Endurance with ripple current : 6,000 to 10,000 hours at 105℃
・Newly innovative electrolyte is employed to minimize ESR
・Rated voltage range : 6.3 to 50Vdc, Nominal capacitance range : 27 to 10,000µF
・Non solvent resistant type
・RoHS2 Compliant
KZM
Longer life
KZH
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +105℃
6.3 to 50Vdc
±20% (M)
I=0.01CV or 3µA, whichever is greater.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V
tanδ (Max.)
0.22 0.19 0.16 0.14 0.12 0.10
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
Z (-25℃) / Z (+20℃)
2max.
Z (-40℃) / Z (+20℃)
3max.
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
(at 20℃, 120Hz)
(at 20℃ after 2 minutes)
(at 20℃, 120Hz)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified period of time at 105℃.
Time
φ5 &φ6.3 : 6,000hours φ8 : 8,000hours φ10 to φ18 : 10,000hours
Capacitance change
≦±25% of the initial value (6.3, 10Vdc : ≦± 30%)
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 500 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Capacitance change
≦±25% of the initial value (6.3, 10Vdc : ≦±30%)
D.F. (tanδ)
Leakage current
Endurance
Shelf Life
◆DIMENSIONS [mm]
F±0.5
Code : E
φD'
φd
Sleeve(PET : Brown)
F±0.5
●Terminal
L'
15min.
4min.
(φ5 to φ10)
(φ12.5 to φ18)
φD 5
φd 0.5
2.0
F
φD'
L'
6.3
0.5
2.5
10 12.5 16
8
0.6 0.6 0.6 0.8
3.5 5.0 5.0 7.5
φD+0.5max.
L+1.5max.
18
0.8
7.5
Gas escape end seal
Vent
(Exceptφ5 &φ6.3)
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KZM AAA E AA AAA M AAA N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 100µF:101, 1,000µF:102)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3, 10V:100)
Series code
Category
Please refer to "Product code guide (radial lead type)"
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Frequency(Hz)
Capacitance(µF)
27
220
680
2,200
4,700
to
to
to
to
to
180
560
1,800
3,900
10,000
120
0.40
0.50
0.60
0.75
0.85
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
Note : The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
Low impedance, 105℃
KZMSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
Cap
(µF)
Case size
φD×L(mm)
tanδ
220
470
820
1,200
1,200
1,500
1,800
2,200
2,700
3,900
4,700
5,600
6,800
6,800
8,200
10,000
150
330
680
1,000
1,000
1,500
1,500
1,800
2,200
3,300
3,900
4,700
4,700
5,600
6,800
8,200
100
220
470
680
680
1,000
1,000
1,500
1,800
2,200
2,700
3,300
3,300
3,900
4,700
5,600
5× 11
6.3×11
8×11.5
8×15
10 ×12.5
8×20
10 ×16
10× 20
10× 25
12.5× 20
12.5× 25
12.5× 30
12.5× 35
16 × 20
16 × 25
18 × 25
5× 11
6.3×11
8× 11.5
8× 15
10 ×12.5
8× 20
10 ×16
10 ×20
10 ×25
12.5× 20
12.5× 25
12.5× 30
16 ×20
12.5× 35
16 ×25
18 ×25
5× 11
6.3×11
8×11.5
8×15
10× 12.5
8× 20
10× 16
10 × 20
10 × 25
12.5× 20
12.5× 25
12.5× 30
16 ×20
12.5×35
16 ×25
18 ×25
0.22
0.22
0.22
0.22
0.22
0.22
0.22
0.24
0.24
0.26
0.28
0.30
0.32
0.32
0.36
0.40
0.19
0.19
0.19
0.19
0.19
0.19
0.19
0.19
0.21
0.23
0.23
0.25
0.25
0.27
0.29
0.33
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.16
0.18
0.18
0.20
0.20
0.20
0.22
0.24
Impedance
(Ω max./100kHz)
20℃
-10℃
0.22
0.094
0.056
0.045
0.039
0.029
0.028
0.020
0.018
0.017
0.015
0.013
0.012
0.015
0.013
0.012
0.22
0.094
0.056
0.045
0.039
0.029
0.028
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.012
0.22
0.094
0.056
0.045
0.039
0.029
0.028
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.012
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.031
0.038
0.035
0.031
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.031
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.031
Rated ripple current
(mArms/105℃, 100kHz)
Part No.
345
540
945
1,250
1,330
1,500
1,760
1,960
2,250
2,480
2,900
3,450
3,570
3,250
3,630
3,650
345
540
945
1,250
1,330
1,500
1,760
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
3,650
345
540
945
1,250
1,330
1,500
1,760
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
3,650
EKZM6R3E□□221ME11D
EKZM6R3E□□471MF11D
EKZM6R3E□□821MHB5D
EKZM6R3E□□122MH15D
EKZM6R3E□□122MJC5S
EKZM6R3E□□152MH20D
EKZM6R3E□□182MJ16S
EKZM6R3E□□222MJ20S
EKZM6R3E□□272MJ25S
EKZM6R3E□□392MK20S
EKZM6R3E□□472MK25S
EKZM6R3E□□562MK30S
EKZM6R3E□□682MK35S
EKZM6R3E□□682ML20S
EKZM6R3E□□822ML25S
EKZM6R3E□□103MM25S
EKZM100E□□151ME11D
EKZM100E□□331MF11D
EKZM100E□□681MHB5D
EKZM100E□□102MH15D
EKZM100E□□102MJC5S
EKZM100E□□152MH20D
EKZM100E□□152MJ16S
EKZM100E□□182MJ20S
EKZM100E□□222MJ25S
EKZM100E□□332MK20S
EKZM100E□□392MK25S
EKZM100E□□472MK30S
EKZM100E□□472ML20S
EKZM100E□□562MK35S
EKZM100E□□682ML25S
EKZM100E□□822MM25S
EKZM160E□□101ME11D
EKZM160E□□221MF11D
EKZM160E□□471MHB5D
EKZM160E□□681MH15D
EKZM160E□□681MJC5S
EKZM160E□□102MH20D
EKZM160E□□102MJ16S
EKZM160E□□152MJ20S
EKZM160E□□182MJ25S
EKZM160E□□222MK20S
EKZM160E□□272MK25S
EKZM160E□□332MK30S
EKZM160E□□332ML20S
EKZM160E□□392MK35S
EKZM160E□□472ML25S
EKZM160E□□562MM25S
□□ : Enter the appropriate lead forming or taping code.
CAT. No. E1001U
Low impedance, 105℃
KZMSeries
◆STANDARD RATINGS
WV
(Vdc)
25
35
50
Cap
(µF)
Case size
φD×L(mm)
tanδ
68
150
330
390
470
560
680
820
1,000
1,500
1,800
2,200
2,200
2,700
3,300
3,900
47
100
220
270
330
390
470
560
680
1,000
1,200
1,500
1,500
1,800
2,200
2,700
27
56
100
120
150
180
220
270
330
470
560
680
820
820
1,000
1,500
5× 11
6.3× 11
8×11.5
8×15
10× 12.5
8×20
10× 16
10× 20
10× 25
12.5 ×20
12.5 ×25
12.5 ×30
16× 20
12.5 ×35
16× 25
18× 25
5×11
6.3 ×11
8×11.5
8×15
10 ×12.5
8×20
10 ×16
10 ×20
10 ×25
12.5 ×20
12.5 ×25
12.5 ×30
16 ×20
12.5 ×35
16 ×25
18 ×25
5×11
6.3×11
8×11.5
8×15
10× 12.5
8× 20
10 × 16
10 × 20
10 ×25
12.5×20
12.5×25
12.5×30
12.5×35
16 ×20
16 ×25
18 ×25
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.16
0.16
0.16
0.18
0.18
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.14
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
Impedance
(Ω max./100kHz)
20℃
-10℃
0.22
0.094
0.056
0.045
0.039
0.029
0.028
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.012
0.22
0.094
0.056
0.045
0.039
0.029
0.028
0.020
0.018
0.017
0.015
0.013
0.015
0.012
0.013
0.012
0.34
0.14
0.074
0.061
0.061
0.046
0.042
0.030
0.028
0.027
0.023
0.021
0.019
0.023
0.021
0.019
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.031
0.80
0.35
0.19
0.15
0.14
0.11
0.10
0.060
0.054
0.043
0.038
0.033
0.038
0.031
0.035
0.031
1.18
0.50
0.22
0.18
0.18
0.14
0.12
0.090
0.085
0.068
0.059
0.052
0.051
0.059
0.056
0.051
Part No.
345
540
945
1,250
1,330
1,500
1,760
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
3,650
345
540
945
1,250
1,330
1,500
1,760
1,960
2,250
2,480
2,900
3,450
3,250
3,570
3,630
3,650
238
385
724
950
979
1,190
1,370
1,580
1,870
2,050
2,410
2,860
2,960
2,730
3,010
3,290
EKZM250E□□680ME11D
EKZM250E□□151MF11D
EKZM250E□□331MHB5D
EKZM250E□□391MH15D
EKZM250E□□471MJC5S
EKZM250E□□561MH20D
EKZM250E□□681MJ16S
EKZM250E□□821MJ20S
EKZM250E□□102MJ25S
EKZM250E□□152MK20S
EKZM250E□□182MK25S
EKZM250E□□222MK30S
EKZM250E□□222ML20S
EKZM250E□□272MK35S
EKZM250E□□332ML25S
EKZM250E□□392MM25S
EKZM350E□□470ME11D
EKZM350E□□101MF11D
EKZM350E□□221MHB5D
EKZM350E□□271MH15D
EKZM350E□□331MJC5S
EKZM350E□□391MH20D
EKZM350E□□471MJ16S
EKZM350E□□561MJ20S
EKZM350E□□681MJ25S
EKZM350E□□102MK20S
EKZM350E□□122MK25S
EKZM350E□□152MK30S
EKZM350E□□152ML20S
EKZM350E□□182MK35S
EKZM350E□□222ML25S
EKZM350E□□272MM25S
EKZM500E□□270ME11D
EKZM500E□□560MF11D
EKZM500E□□101MHB5D
EKZM500E□□121MH15D
EKZM500E□□151MJC5S
EKZM500E□□181MH20D
EKZM500E□□221MJ16S
EKZM500E□□271MJ20S
EKZM500E□□331MJ25S
EKZM500E□□471MK20S
EKZM500E□□561MK25S
EKZM500E□□681MK30S
EKZM500E□□821MK35S
EKZM500E□□821ML20S
EKZM500E□□102ML25S
EKZM500E□□152MM25S
CAT. No. E1001U
