SIT1569AC-J3-33E-0075.00000E
    SITIME(赛特时脉)
    XO-4P_1.54X0.84MM_SM
    MEMS OSC XO 75.0000KHZ LVCMOS
SIT1569AC-J3-33E-0075.00000E 数据手册
SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Applications µPower operating current: 3.3 µA (100 kHz) Factory-programmable frequency from 1 Hz to 462.5 kHz[1] ±50 ppm max all-inclusive frequency stability World’s smallest oscillator footprint: 1.2 mm2 1.5 mm x 0.8 mm CSP 0.6 mm max height No external bypass capacitors required Wide operating supply voltage range: 1.8 V to 3.3 V LVCMOS compatible output Pb-free, RoHS and REACH compliant ◼ ◼ ◼ ◼ Smart stylus Wearable biometric sensing Wireless chargers Portable medical Note: 1. For higher frequency applications, consider the SiT1576 or the SiT8021. Electrical Specifications Table 1. DC Electrical Characteristics[2] Conditions: Min/Max limits are over temperature, V DD = 1.8 V ±10%, unless otherwise stated. Typicals are at 25°C and VDD = 1.8 V. Parameters Symbol Min. Typ. Max. Unit Condition Frequency Output Frequency Range FOUT 1.0 462.5 k Hz Frequency Stability Initial Tolerance Frequency Stability F_tol -10 10 ppm TA = 25°C. Includes 2x reflow. F_stab -50 50 ppm All inclusive of over temperature, referenced to nominal frequency at 25°C, inclusive of VDD, aging, and load nsRMS 10,000 cycles, per JEDEC standard 65B, tested at 100 kHz Jitter RMS Period Jitter t_jitter 4 8.5 Power Supply Power Supply Voltage No Load Supply Current Start-up Time VDD 1.62 IDD 3.63 FOUT = 1 Hz 3 3.3 4.6 8 10 FOUT = 462.5 kHz 150 300 FOUT > 200 Hz, to first output pulse. 250 + 300 + 2.0 cycles 2.5 Cycles 500 + 2.5 Cycles t_start V 1.7 µA ms FOUT = 100 kHz 10 Hz < FOUT ≤ 200 Hz, to first output pulse. 1 Hz ≤ FOUT ≤ 10 Hz, to first output pulse. Operating Temperature Range Commercial Temperature -20 Industrial Temperature -40 70 °C 85 °C LVCMOS Output Rise-Fall Time tR/tF 10 Output Clock Duty Cycle DC 45 VOH - Output Voltage High VOH 90% VOL - Output Voltage Low VOL 40 70 ns 55 % 20-80%, 15 pF load, VDD = 1.8 V ±10% IOH = -50 µA, 15 pF load 10% IOL = 50 µA, 15 pF load Note: 2. For applications requiring lower jitter or improved frequency stability, consider the SiT1579, or contact SiTime for other product options. Rev 1.2 25 March 2021 www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Table 2. Pin Configuration Pin Symbol I/O 1 NC Internal Test Pin 2 CLK Out Output 3 VDD Power Supply 4 GND Power Supply Ground CSP Package (Top View) Functionality No Connect. Leave floating. Pin 1 is for internal testing and is designed to be left floating. NC 1 4 GND CLK Out 2 3 Vdd Oscillator clock output, LVCMOS compatible Connect to power supply between 1.8 V and 3.3 V ±10%. Under normal operating conditions, Vdd does not require external bypass/decoupling capacitor(s). The SiT1569 includes on-chip Vdd filtering. Connect to GND Figure 1. Pin Assignments Table 3. Absolute Maximum Ratings Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameters Test Conditions Value Continuous Power Supply Voltage Range (VDD) Continuous Maximum Operating Temperature Range Unit -0.5 to 4.0 V 105 °C ≤ 30 minutes 125 °C Human Body Model (HBM) ESD Protection JESD22-A114 2000 V Charge-Device Model (CDM) ESD Protection JESD22-C101 750 V Machine Model (MM) ESD Protection JESD22-A115 200 V g Short Duration Maximum Operating Temperature Range Latch-up Tolerance JESD78 Compliant Mechanical Shock Resistance Mil 883, Method 2002 20,000 Mechanical Vibration Resistance Mil 883, Method 2007 70 g 150 °C -65 to 150 °C 1508 CSP Junction Temperature Storage Temperature System Block Diagram VDD GND NVM Driver NC CLK Out Figure 2. SiT1569 Block Diagram Rev 1.2 Page 2 of 7 www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Detailed Description Frequency Stability The SiT1569 is the first ULP, factory-programmable oscillator in an ultra-small 1.5mm x 0.8mm (1508) chip-scale package (CSP), and part of a new family of ULP, ultra-small oscillators from SiTime. This device can be programmed for any frequency between 1 Hz and 462.5 kHz. The silicon MEMS technology makes it possible to produce the world's smallest, programmable reference clock in a chip-scale package. The SiT1569 oscillator is Factory trimmed to 32.768 kHz at room temperature. The result is a very accurate oscillator at room temperature and over temperature. Unlike quartz crystals that have a classic tuning fork parabola temperature curve with a 25°C turnover point with a 0.04 to 0.06 ppm/°C2 temperature coefficient (TCF), the SiT1569 temperature coefficient is calibrated at room temperature and corrected over temperature with an active temperature correction circuit. The result is 100 ms. Shorter gate times may lead to inaccurate measurements. Page 3 of 7 www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Typical Operating Curves (TA = 25°C, VDD = 1.8 V, supply current plots are no load, unless otherwise stated) No Vdd bypass 10 nF Vdd bypass Figure 3. LVCMOS Output Swing (VDD = 1.8 V) Figure 4. Power Supply Noise Rejection (PSNR) 2.5 2.4 2.4 2.3 2.3 2.2 2.2 2.1 VDD = 3.3 V 1.9 2 Current (µA) Current (µA) VDD = 3.3 V 2.1 2 1.8 VDD = 1.8 V 1.7 1.6 1.5 1.9 VDD = 1.8 V 1.8 1.7 1.6 1.5 1.4 1.4 1.3 1.3 1.2 1.2 1.1 1.1 1 1 -40 -20 0 20 40 60 80 -40 100 -20 0 20 40 60 80 100 Temperature (°C) Temperature (°C) Figure 6. Supply Current vs Temperature (FOUT = 100 Hz) Figure 5. Supply Current vs Temperature (FOUT = 1 Hz) 5 13.5 4.75 12.75 4.5 11.25 10.5 Current (µA) Current (µA) 4 3.75 3.5 3.25 VDD = 1.8 V 3 9.75 9 8.25 2.75 7.5 2.5 VDD = 1.8 V 6.75 2.25 2 6 -40 -20 0 20 40 60 80 100 -40 Temperature (°C) -20 0 20 40 60 80 100 Temperature (°C) Figure 8. Supply Current vs Temperature (FOUT = 440 kHz) Figure 7. Supply Current vs Temperature (FOUT = 100 kHz) Rev 1.2 VDD = 3.3 V 12 VDD = 3.3 V 4.25 Page 4 of 7 www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Dimensions and Patterns Package Size – Dimensions (Unit: mm) Recommended Land Pattern (Unit: mm) #4 #3 #2 #1 (soldermask openings shown with dashed line around NSMD pad) Recommended 4-mil (0.1mm) stencil thickness 4) The SiT1569 CSP includes a protective, opaque Manufacturing Guidelines 1) No Ultrasonic or Megasonic cleaning: Do not subject the SiT1569 to an ultrasonic or megasonic cleaning environment. Permanent damage or long term reliability issues may occur. 2) Applying board-level underfill and overmold is acceptable and will not impact the reliability of the device. 3) Reflow profile, per JESD22-A113D. Rev 1.2 Page 5 of 7 polymer top-coat. If the SiT1569 will see intense light, especially in the 1.0-1.2µm IR spectrum, we recommend a protective “glob-top” epoxy or other cover to keep the light from negatively impacting the frequency stability. 5) For additional manufacturing guidelines and marking/tape-reel instructions, refer to SiTime Manufacturing Notes. www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Ordering Information SiT1569AC -J3-33E-0000.000000Q Packaging Part Family “S”: 8 mm Tape & Reel, 10 ku reel “Q”: 8 mm Tape & Reel, 5 ku reel “D”: 8 mm Tape & Reel, 3 ku reel “E”: 8 mm Tape & Reel, 1 ku reel Samples in cut Tape “SiT1569” Revision Letter “A” is the revision Output Frequency Continuous frequency options from 1 Hz to 462.5 kHz Temperature Range “C”: Commercial, -20 to 70ºC “I”: Industrial, -40 to 85ºC Enter your desired frequency as shown below: 0462.500000 = 462.5 kHz 0100.000000 = 100.0 kHz 0010.000000 = 10.0 kHz 0001.000000 = 1.0 kHz 0000.100000 = 100.0 Hz 0000.010000 = 10.0 Hz 0000.001000 = 1.0 Hz 0000.001100 = 1.10 Hz 0000.005123 = 5.123 Hz Package Size “J”: 1.5 x 0.8 mm CSP Frequency Stability “3”: ±50 ppm Supply Voltage (Vdd): 18E: 1.8 V ±10% 25E: 2.5 V ±10% 30E: 3.0 V ±10% 33E: 3.3 V ±10% For applications that require operation over wide range, enter the option that corresponds to the highest supply voltage. Rev 1.2 Page 6 of 7 www.sitime.com SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator Table 4. Revision History Version Release Date Change Summary 0.25 13-Jan-2016 Initial Preliminary 0.5 28-Apr-2016 Updated max operating frequency Updated part number ordering 0.7 8-Jul-2016 0.9 28-Apr-2017 Updated min/max frequency stability, added RMS period jitter Update part numbering code Update min/max frequency stability Updated CSP package outline drawing (POD) Updated Supply Current max limits Updated logo and company address, other page layout changes 1.0 10-May-2017 Final Release 1.1 17-May-2018 Added additional typical operating curves Updated typical No Load Supply Current (Table 1) Corrected frequency range from ‘1 HZ – 460 KHz’ to ‘1 HZ – 462.5 KHz’ 1.2 25-Mar-2021 Added Option “D” for 3ku reels to the Ordering Information Updated hyperlinks, trademarks, date format and layout formatting SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439 © SiTime Corporation 2018-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev 1.2 Page 7 of 7 www.sitime.com
SIT1569AC-J3-33E-0075.00000E 价格&库存
很抱歉,暂时无法提供与“SIT1569AC-J3-33E-0075.00000E”相匹配的价格&库存,您可以联系我们找货
