BRA2500003
BRA2500003
    TXC(台晶)
    SMD7050_6P
    XTAL OSC VCXO 125.0000MHZ CMOS
BRA2500003 数据手册
come visit our site http://www.txccorp.com SMD CMOS VCXO Single End Output 7.0 x 5.0 x 1.3 mm BR Series Oscillators Series Think of Frequency Think of Features .Voltage Controlled Crystal Oscillator (VCXO). H Y1 0 C R 600 CB TX 153. .Fundamental solution. .CMOS output, output frequencies 50 MHz to 200 MHz. .Wide pull range and good linearity. .Excellent low phase noise and jitter. .Tri-State function available. .Main applications : SDH/ SONET, Ethernet, Base Stations. .RoHS Compliant / Pb Free. Item / Type BR Output Type CMOS Output Load 15 pF, or specify Oscillation Mode Fundamental Supply Voltage (VDD) 3.3 V Frequency Range 50 ~ 200 MHz Operating Temperature Range - 10 ~ +70 ℃ , - 40 ~ + 85 ℃, or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) 0.1 VDD / 0.9 VDD Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 5 nS Max. Supply Current 60 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Absolute Pulling Range ( APR ) * ± 50 ppm Min , or specify Nominal Control Voltage 0.5 VDD Control Voltage Range 0 ~ VDD Linearity 10% Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1pS Max. Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications * APR=(Pull Range) - (Frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, and aging.) Dimensions Units: mm 81
BRA2500003 价格&库存
很抱歉,暂时无法提供与“BRA2500003”相匹配的价格&库存,您可以联系我们找货
