SIT3372AC-1B2-28NB75.000000T
    SITIME
    SMD3225_6P
    XTAL OSC VCXO 75.0000MHZ LVPECL
SIT3372AC-1B2-28NB75.000000T 数据手册
SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Description Features The SiT3372 is a 1 MHz to 220 MHz differential MEMS VCXO engineered for low-jitter applications. Utilizing SiTime’s unique DualMEMS® temperature sensing and TurboCompensation® technology, the SiT3372 delivers exceptional dynamic performance by providing resistance to airflow, thermal gradients, shock and vibration. This device also integrates multiple on-chip regulators to filter power supply noise, eliminating the need for a dedicated external LDO. ◼ The SiT3372 can be factory programmed for any combination of frequency, stability, voltage, output signaling, and pull range. Programmability enables designers to optimize clock configurations while eliminating long lead times and customization costs associated with quartz devices where each frequency is custom built. The wide frequency range and programmability makes this device ideal for telecom, networking, and industrial applications that require a variety of pullable frequencies and operate in noisy environments. ◼ ◼ ◼ ◼ ◼ Any frequency between 1 MHz and 220 MHz accurate to 6 decimal places (For frequencies 220.000001 MHz to 725 MHz, refer to SiT3373) Widest pull range options: ±25, ±50, ±80, ±100, ±150, ±200, ±400, ±800, ±1600, ±3200 ppm 0.225 ps RMS phase jitter (typ) over 12 kHz to 20 MHz bandwidth Frequency stability as low as ±15 ppm Wide temperature range support from -40°C to 105°C Industry-standard packages: 7.0 x 5.0 mm, 5.0 x 3.2 mm, 3.2 x 2.5 mm packages Applications ◼ ◼ Cable Modem Termination System (CMTS), Video, Broadcasting System, Audio, Industrial Sensors, Remote Radio Head (RRH) SATA, SAS, 10/40/100/400 Gbps Ethernet, Fibre Channel, PCI-Express Refer to Manufacturing Notes for proper reflow profile, tape and reel dimension, and other manufacturing related information. Block Diagram 3.2 x 2.5 mm Package Pinout Figure 1. SiT3372 Block Diagram Rev 1.07 VIN 1 6 VDD NC 2 5 OUT- GND 3 4 OUT+ Figure 2. Pin Assignments (Top view) (Refer to Table 6 for Pin Descriptions) 20 July 2021 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Ordering Information SiT3372AC -1B2-33NH122.123456T Part Family Packaging “SiT3372” “T”, “Y”, “D” or “E” Refer to table below for packing method [1] Leave Blank for Bulk Revision Letter “A” is the revision of Silicon Frequency 1.000000 MHz to 220.000000 MHz Temperature Range “C”: Extended Commercial, -20 to 70°C “ I ” : Industrial, -40 to 85°C “B”: -40 to 95°C “E”: Extended Industrial, -40 to 105°C [2] Pull Range Options “M”: ±25 ppm “B”: ±50 ppm “C”: ±80 ppm “E”: ±100 ppm “G”: ±150 ppm “H”: ±200 ppm “X”: ±400 ppm “Y”: ±800 ppm “Z”: ±1600 ppm “U”: ±3200 ppm Signalling Type “1”: LVPECL “2”: LVDS “4”: HCSL Package Size “B”: 3.2 x 2.5 mm “C”: 5.0 x 3.2 mm with center pad “E”: 7.0 x 5.0 mm with center pad [3] Feature Pin “N”: No Connect “E”: Output Enable Frequency Stability “H”: “2”: “9”: “3”: ±15 ppm ±25 ppm ±35 ppm ±50 ppm Voltage Supply “25”: 2.5 V ±10% “28”: 2.8 V ±10% “30”: 3.0 V ±10% “33”: 3.3 V ±10% Notes: 1. Bulk is available for sampling only. 2. Contact SiTime for custom pull range options. 3. “E”: Output Enable function is only available in 7.0 x 5.0 mm and 5.0 x 3.2 mm packages. Table 1. Ordering Codes for Supported Tape & Reel Packing Method Device Size (mm x mm) 8 mm T&R (3ku) 8 mm T&R (1ku) 7.0 x 5.0 – – 5.0 x 3.2 – – 3.2 x 2.5 D E T Rev 1.07 12 mm T&R (3ku) 12 mm T&R (1ku) 16 mm T&R (3ku) 16 mm T&R (1ku) – – T Y T Y – – Y – – Page 2 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO TABLE OF CONTENTS Description ................................................................................................................................................................................... 1 Features....................................................................................................................................................................................... 1 Applications ................................................................................................................................................................................. 1 Block Diagram ............................................................................................................................................................................. 1 Ordering Information .................................................................................................................................................................... 2 Electrical Characteristics.............................................................................................................................................................. 4 Waveform Diagrams .................................................................................................................................................................. 10 Timing Diagrams ........................................................................................................................................................................ 11 Termination Diagrams................................................................................................................................................................ 12 LVPECL .............................................................................................................................................................................. 12 LVDS .................................................................................................................................................................................. 13 HCSL .................................................................................................................................................................................. 13 Dimensions and Patterns ― 3.2 x 2.5 mm................................................................................................................................. 14 Dimensions and Patterns ― 5.0 x 3.2 mm................................................................................................................................. 14 Dimensions and Patterns ― 7.0 x 5.0 mm................................................................................................................................. 15 Additional Information ................................................................................................................................................................ 16 Revision History ......................................................................................................................................................................... 17 Rev 1.07 Page 3 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Electrical Characteristics Table 2. Electrical Characteristics – Common to LVPECL, LVDS and HCSL All Min and Max limits in the Electrical Characteristics tables are specified over temperature and rated operating voltage with standard output termination shown in the termination diagrams. Typical values are at 25°C and nominal supply voltage. Parameter Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 1 – 220 MHz Accurate to 6 decimal places Frequency Stability Frequency Stability F_stab -15 – +15 ppm -25 – +25 ppm -35 – +35 ppm -50 – +50 ppm Inclusive of initial tolerance, operating temperature, rated power supply voltage, load variations, and first year aging at 25 °C, with VIN voltage at Vdd/2. ±15 ppm is only guaranteed for pull range up to ±100 ppm. Temperature Range Operating Temperature Range T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial -40 – +95 °C -40 – +105 °C Extended Industrial Supply Voltage Supply Voltage Vdd 2.97 3.3 3.63 V 2.7 3.0 3.3 V 2.52 2.8 3.08 V 2.25 2.5 2.75 V Voltage Control Characteristics Pull Range PR ±25, ±50, ±80, ±100, ±150, ±200, ±400, ±800, ±1600, ±3200 ppm See the APR (Absolute Pull Range) Table 11. Contact SiTime for custom pull range options Upper Control Voltage VC_U 90% – – Vdd Voltage at which maximum frequency deviation is guaranteed Lower Control Voltage VC_L – – 10% Vdd Voltage at which minimum frequency deviation is guaranteed Control Voltage Input Impedance VC_z – 10 – MΩ Control Voltage Input Bandwidth V_c – 10 – kHz Pull Range Linearity Lin – – 1.0 % Frequency Change Polarity – Contact SiTime for other input bandwidth options – Positive Slope Input Characteristics Input Voltage High VIH 70% – – Vdd Pin 2, OE Input Voltage Low VIL – – 30% Vdd Pin 2, OE Input Pull-up Impedance Z_in – 100 - kΩ Pin 2, OE logic high or logic low Output Characteristics Duty Cycle DC 45 – 55 % Startup and OE Timing Startup Time OE Enable/Disable Time Rev 1.07 T_start – – 3.0 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 3.8 µs f = 156.25 MHz. Measured from the time OE pin reaches rated VIH and VIL to the time clock pins reach 90% of swing and high-Z. See Figure 9 and Figure 10 Page 4 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 3. Electrical Characteristics – LVPECL Specific Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – 78 92 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – 53 61 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low I_driver – – 33 mA Maximum average current drawn from OUT+ or OUT- Current Consumption Maximum Output Current Output Characteristics Output High Voltage VOH Vdd-1.15 – Vdd-0.7 V See Figure 5 Output Low Voltage VOL Vdd-2.0 – Vdd-1.5 V See Figure 5 V_Swing 1.2 1.6 2.0 V See Figure 6 Tr, Tf – 225 290 ps 20% to 80%, see Figure 6 Output Differential Voltage Swing Rise/Fall Time Jitter – 7.0 x 5.0 mm package RMS Period Jitter[4] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.225 0.270 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.225 0.300 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm package RMS Period Jitter[4] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.225 0.275 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.225 0.340 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Notes: 4. Measured according to JESD65B. Rev 1.07 Page 5 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 4. Electrical Characteristics – LVDS Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – 73 84 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – 55 62 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low Current Consumption Output Characteristics VOD 250 – 450 mV See Figure 7 ΔVOD – – 50 mV See Figure 7 VOS 1.125 – 1.375 V See Figure 7 Delta VOS ΔVOS – – 50 mV See Figure 7 Rise/Fall Time Tr, Tf – 400 470 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, see Figure 8 RMS Period Jitter[5] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.215 0.265 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.215 0.300 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Differential Output Voltage Delta VOD Offset Voltage Jitter – 7.0 x 5.0 mm package Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm package RMS Period Jitter[5] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.235 0.275 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.235 0.320 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Notes: 5. Measured according to JESD65B. Rev 1.07 Page 6 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 5. Electrical Characteristics – HCSL Parameter Symbol Min. Typ. Max. Unit Condition Current Consumption Idd – 83 97 mA Excluding Load Termination Current, Vdd = 3.3 V or 2.5 V OE Disable Supply Current I_OE – 55 62 mA OE = Low Output Disable Leakage Current I_leak – 0.15 – A OE = Low Current Consumption Output Characteristics Output High Voltage VOH 0.60 – 0.90 V See Figure 5 Output Low Voltage VOL -0.05 – 0.08 V See Figure 5 V_Swing 1.2 1.4 1.80 V See Figure 6 Rise/Fall Time Tr, Tf – 360 495 ps Measured with 2 pF capacitive loading to GND, 20% to 80%, See Figure 6 RMS Period Jitter[6] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.220 0.270 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.220 0.300 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Output Differential Voltage Swing Jitter – 7.0 x 5.0 mm package Jitter – 5.0 x 3.2 mm and 3.2 x 2.5 mm package RMS Period Jitter[6] T_jitt – 1.0 1.6 ps f = 100, 156.25 or 212.5 MHz, Vdd = 3.3 V or 2.5 V RMS Phase Jitter (random) T_phj – 0.230 0.275 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -20 to 70°C and -40 to 85°C – 0.230 0.340 ps f = 156.25 MHz, Integration bandwidth = 12 kHz to 20 MHz, all Vdd levels, includes spurs, pull range = ±100 ppm. Temperature ranges -40 to 95°C and -40 to 105°C – 0.1 – ps f = 156.25 MHz, IEEE802.3-2005 10 GbE jitter mask integration bandwidth = 1.875 MHz to 20 MHz, includes spurs, all Vdd levels Notes: 6. Measured according to JESD65B. Rev 1.07 Page 7 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 6. Pin Description Pin Symbol 1 VIN Functionality Input No Connect (NC) 2 NC/OE Output Enable (OE) Control Voltage No Connect: Leave floating or connect to GND for better heat dissipation. NC for all 3.2 x 2.5 mm package options. H[7,8]: specified frequency output L: output is high impedance. Only output driver is disabled. OE function only available on 7050 package. Pin 2 on 3225 package is NC. 3 GND Power Vdd Power Supply Ground 4 OUT+ Output Oscillator output 5 OUT- Output Complementary oscillator output 6 VDD Power Power supply voltage [9] Top View Top View VIN 1 6 VDD VIN 1 6 VDD NC/OE [7] 2 5 OUT- NC [8] 2 5 OUT- GND 3 4 OUT+ GND 3 4 OUT+ Figure 3. Pin Assignments (7.0 x 5.0 mm and 5.0 x 3.2 mm packages) Figure 4. Pin Assignments (3.2 x 2.5 mm package) Notes: 7. A pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. 8. OE mode is only available in the 7050 and 5032 packages. 3225 package is NC. 9. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. Rev 1.07 Page 8 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 7. Absolute Maximum Ratings Attempted operation outside the absolute maximum ratings may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Parameter Min. Max. Unit -0.5 4.0 V Vdd + 0.3V V 150 °C Maximum Junction Temperature 145 °C Soldering Temperature (follow standard Pb-free soldering guidelines) 260 °C Continuous Power Supply Voltage Range (Vdd) Input Voltage, Maximum (any input pin) Input Voltage, Minimum (any input pin) -0.3 Storage Temperature -65 V Table 8. Thermal Considerations[10] Package JA, 4 Layer Board (°C/W) JC, Bottom (°C/W) 3225, 6-pin 80 30 5032, 6-pin 53[11] 20 7050, 6-pin 52[11] 19 Notes: 10. Refer to JESD51 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. 11. Value for JA assumes the center pad is soldered down. Table 9. Maximum Operating Junction Temperature[12] Max Operating Temperature (ambient) Maximum Operating Junction Temperature: 3225 Package Maximum Operating Junction Temperature: 5032, 7050 Packages 70°C 105°C 95°C 85°C 130°C 110°C 95°C 130°C 120°C 105°C 145°C 130°C Notes: 12. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 10. Environmental Compliance Test Conditions Value Unit MIL-STD-883F, Method 2002 10,000 g Mechanical Vibration Resistance MIL-STD-883F, Method 2007 70 g Soldering Temperature (follow standard Pb free soldering guidelines) MIL-STD-883F, Method 2003 260 °C Moisture Sensitivity Level MSL1 @ 260°C Electrostatic Discharge (HBM) HBM, JESD22-A114 2,000 V Charge-Device Model ESD Protection JESD220C101 750 V Parameter Mechanical Shock Resistance JESD78 Compliant Latch-up Tolerance Rev 1.07 Page 9 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Waveform Diagrams OUT- VOH OUT+ VOL GND Figure 5. LVPECL, HCSL Voltage Levels per Differential Pin (i.e. OUT+, or OUT-) V 80% 80% V_ Swing 0V t 20% 20% Tr Tf Figure 6. LVPECL, HCSL Voltage Levels across Differential Pair (i.e. OUT+ minus OUT-) Rev 1.07 Page 10 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Waveform Diagrams (continued) OUT- VOD OUT+ VOS GND Figure 7. LVDS Voltage Levels per Differential Pin (OUT+, or OUT-) V 80% 80% 0V t 20% 20% Tr Tf Figure 8. LVDS Differential Waveform (i.e. OUT+ minus OUT-) Timing Diagrams Vdd OE Voltage Vdd VIH VIL T_oe_hw OE Voltage T_oe_hw OUT- OUT- 90% HZ HZ OUT+ OUT+ GND GND Figure 9. Hardware OE Enable Timing Rev 1.07 Figure 10. Hardware OE Disable Timing Page 11 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Termination Diagrams LVPECL OUT+ Shunt Bias Termination network 0.1μF Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 0.1μF RB RB VDD 50 Ω 50 Ω RB 3.3 V 100 Ω VT 2.5 V 48.7 Ω Figure 11. LVPECL with AC-coupled termination VDD Thevenin-equivalent Termination network R1 R1 LVPECL OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- VDD R1 R2 R2 3.3 V 127 Ω 82.5 Ω 2.5 V 250 Ω 62.5 Ω R2 Figure 12. LVPECL DC-coupled load termination with Thevenin equivalent network Y-Bias Termination network LVPECL OUT+ Zo = 50Ω D+ OUT- Zo = 50Ω D- R1 VDD R1 R2 R3 3.3 V 50 Ω 50 Ω 50 Ω 2.5 V 50 Ω 50 Ω 18 Ω R2 C1 0.1μF R3 Figure 13. LVPECL with Y-Bias termination OUT+ Shunt Bias Termination network Zo = 50Ω D+ OUT- Zo = 50Ω D- LVPECL 50 Ω 50 Ω VT=VDD-2V Figure 14. LVPECL with DC-coupled parallel shunt load termination Rev 1.07 Page 12 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Termination Diagrams (continued) LVDS LVDS Zo = 50Ω OUT+ OUT+ 100 Ω Zo = 50Ω OUT- OUT- Figure 15. LVDS single DC termination at the load LVDS 0.1μF Zo = 50Ω OUT+ OUT+ 100 Ω 100 Ω 0.1μF Zo = 50Ω OUT- OUT- Figure 16. LVDS double AC termination with capacitor close to the load LVDS Zo = 50Ω OUT+ OUT+ 100 Ω 100 Ω Zo = 50Ω OUT- OUT- Figure 17. LVDS double DC termination HCSL R1 OUT+ OUT- Zo = 50Ω D+ Zo = 50Ω D- R2 50Ω 50Ω R1 = R2 = 33 Ω Figure 18. HCSL interface termination Rev 1.07 Page 13 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Dimensions and Patterns ― 3.2 x 2.5 mm Package Size – Dimensions (Unit: mm)[13] 3.2 x 2.5 x 0.85 mm Recommended Land Pattern (Unit: mm)[14] 3.2 x 2.5 x 0.85 mm 1.00 1.6 2.25 0.65 1.05 Dimensions and Patterns ― 5.0 x 3.2 mm Package Size – Dimensions (Unit: mm)[13] 5.0 x 3.2 x 0.85 mm[15] Recommended Land Pattern (Unit: mm)[14] 5.0 x 3.2 x 0.85 mm[15] Notes: 13. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of the device. 14. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. 15. The center pad is internally connected to the GND pin. Soldering down the center pad to the GND is recommended for best thermal dissipation , but is optional. Rev 1.07 Page 14 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Dimensions and Patterns ― 7.0 x 5.0 mm Package Size – Dimensions (Unit: mm)[16] 7.0 x 5.0 x 0.85 mm[18] Recommended Land Pattern (Unit: mm)[17] 7.0 x 5.0 x 0.85 mm[18] Notes: 16. Top Marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the as sembly location of the device. 17. A capacitor of value 0.1 µF or higher between VDD and GND is required. An additional 10 µF capacitor between VDD and GND is required for the best phase jitter performance. 18. The center pad is internally connected to the GND pin. Soldering down the center pad to the GND is recommended for best thermal dissipation, but is optional. Rev 1.07 Page 15 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Table 11. APR Table Absolute pull range (APR) = Nominal pull range (PR) - frequency stability (F_stab)-aging[19] Frequency Stability Nominal Pull Range ±15 ±25 ±35 ±50 – APR (ppm) ±25 ±5 – – ±50 ±30 ±20 ±10 – ±80 ±60 ±50 ±40 ±25 ±100 ±80 ±70 ±60 ±45 ±150 – ±120 ±110 ±95 ±200 – ±170 ±160 ±145 ±400 – ±370 ±360 ±345 ±800 – ±770 ±760 ±745 ±1600 – ±1570 ±1560 ±1545 ±3200 – ±3170 ±3160 ±3145 Note: 19. Aging includes solder down shift and 20-year aging. Additional Information Table 12. Additional Information Document Description Download Link ECCN #: EAR99 Five character designation used on the commerce Control List (CCL) to identify dual use items for export control purposes. — HTS Classification Code: 8542.39.0000 A Harmonized Tariff Schedule (HTS) code developed by the World Customs Organization to classify/define internationally traded goods. — Part number Generator Tool used to create the part number based on desired features. https://www.sitime.com/part-number-generator Time Machine II MEMS oscillator programmer http://www.sitime.com/support/time-machine-oscillator-programmer Manufacturing Notes Tape & Reel dimension, reflow profile and other manufacturing related info https://www.sitime.com/sites/default/files/gated/Manufacturing-Notesfor-SiTime-Products.pdf Qualification Reports RoHS report, reliability reports, composition reports http://www.sitime.com/support/quality-and-reliability Performance Reports Additional performance data such as phase noise, current consumption and jitter for selected frequencies http://www.sitime.com/support/performance-measurement-report Termination Techniques AN10029 Termination design recommendations http://www.sitime.com/support/application-notes Layout Techniques AN10006 Layout recommendations http://www.sitime.com/support/application-notes Evaluation Boards SiT6085EB, SiT6086EB and SiT6097EB for Differential Oscillators https://www.sitime.com/support/user-guides Rev 1.07 Page 16 of 17 www.sitime.com SiT3372 1 MHz to 220 MHz Ultra-low Jitter Differential VCXO Revision History Table 13. Revision History Revision Release Date 1.0 13-Oct-2017 Change Summary Initial release 1.03 10-May-2018 Updated the Part Ordering info with added 5.0 x 3.2 mm package 1.04 29-Oct-2018 ±15 ppm option 1.05 7-Jun-2020 Formatting updates Corrected typos Updated package Dimensions Drawings Updated Table 8 Thermal Considerations for 5032 package Added Evaluation Boards SiT6085EB reference in Additional Information Rearranged layout, added Description, Block Diagram and TOC Added HTS classification code Clarified ±15 ppm pull range up to ±100 ppm Modified maximum junction temperatures Removed I_driver HCSL specification as not applicable 1.06 17-Mar-2021 Updated L1 and Dimple Width package dimensions for 3.2 x 2.5 mm package Updated trademarks and changed rev table date format 1.07 20-Jul-2021 Updated pin direction in package dimensions for 3.2 x 2.5 mm package SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439 © SiTime Corporation 2017-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liabi lity for any loss, damage or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or (iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress. Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below. CRITICAL USE EXCLUSION POLICY BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE. SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly prohibited. Rev 1.07 Page 17 of 17 www.sitime.com
物料型号: SiT3372
器件简介: - SiT3372是一款1 MHz至220 MHz的差分MEMS VCXO,专为低抖动应用设计。 - 采用SiTime的DualMEMS®温度传感和TurboCompensation®技术,提供出色的动态性能,抵抗气流、热梯度、冲击和振动的影响。 - 设备集成了多个片上调节器以滤除电源噪声,无需外部LDO。
引脚分配: - 3.2 x 2.5 mm封装的引脚分配如图2所示,包括VIN(电源输入)、NC(无连接)、OUT+(输出正)、GND(地)、OUT-(输出负)和VDD(电源)。
参数特性: - 频率范围:1 MHz至220 MHz,精确到小数点后六位。 - 拉频范围:±25至±3200 ppm。 - 相位抖动:典型值为0.225 ps RMS,带宽为12 kHz至20 MHz。 - 频率稳定性:低至±15 ppm。 - 工作温度范围:-40°C至105°C。
功能详解: - SiT3372可以工厂编程,以实现任何组合的频率、稳定性、电压、输出信号和拉频范围。 - 可编程性使设计人员能够优化时钟配置,同时消除石英器件的长交货期和定制成本。
应用信息: - 适用于电信、网络和工业应用,这些应用需要多种可拉频的频率,并且在嘈杂环境中运行。
封装信息: - 提供多种行业标准封装,包括7.0 x 5.0 mm、5.0 x 3.2 mm和3.2 x 2.5 mm。
SIT3372AC-1B2-28NB75.000000T 价格&库存
很抱歉,暂时无法提供与“SIT3372AC-1B2-28NB75.000000T”相匹配的价格&库存,您可以联系我们找货
