BD62120AEFJ-EVK-101
BD62120AEFJ-EVK-101
    ROHM(罗姆)
    BD62120A 电机控制器/驱动器 电源管理 评估板
BD62120AEFJ-EVK-101 数据手册
User’s Guide DC Brushed Motor Driver 36V 1 Channel (1A/2A/3A) DC Brushed Motor Driver BD621x0AEFJ Evaluation Board Introduction This user’s guide will provide the necessary steps to operate the Evaluation Board of ROHM’s BD621x0AEFJ DC Brushed Motor Driver. This document includes the external parts, operating procedures and application data. Description This Evaluation Board was developed for ROHM’s family of DC Brushed Motor Driver: BD62130AEFJ (3A), BD62120AEFJ (2A) and BD62110AEFJ (1A). BD621x0AEFJ are built-in 1 channel H bridge motor drivers for DC brushed motors. This family of driver can drive high efficiency by a PWM signal directly to input pins. There are built in protection circuits in this IC. Each protection circuit operation contributes to set high reliability. Application Small appliances (Vacuum cleaners), Factory Automation, Robotics, Point of Sales (POS) machines, Gaming Machines, Scanners, Printers (Multi-function Printer, Laser Printer, Inkjet Printer, Photo Printer, FAX, Mini Printer), Plain Paper Copier (PPC), and any application that requires motor drivers for DC Brushed Motor. Evaluation board operating condition (default setting) Table 1. Evaluation board operating condition (default setting) Power supply voltage *1 Output current Peak output current Max Max Unit Parameter Unit Min Typ Max BD62110AEFJ 8 - 28 V 1 2 A BD62120AEFJ 8 - 28 V 2 3 A BD62130AEFJ 8 - 28 V 3 4 A *1 This indicates the voltage near the VCC pin. Be careful of voltage drop by the impedance of power line. © 2022 ROHM Co., Ltd. 1/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Evaluation board The name shown on the PCB denotes which variant of the ROHM motor driver chip is mounted. Figure 1. Top view of BD62110AEFJ-EVK-101 Figure 2. Top view of BD62120AEFJ-EVK-101 Figure 3. Top view of BD62130AEFJ-EVK-101 © 2022 ROHM Co., Ltd. 2/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Evaluation board setup Figure 4. Figure 5. Evaluation board setup – test points, connectors, and switches S1 and S2 Evaluation board setup – Switches S1 and S2 are used to connect IN1 and IN2 pin to either 5V (“H”) or as open (“L). When connected as open (“L”) and internal pulldown resistor will pull IN1 and IN2 to ground if nothing is connected to IN1 and IN2 test points. Figure 6. © 2022 ROHM Co., Ltd. Evaluation board setup – connection to a DC brushed motor via connector CN1 3/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Function explanation: Input and Output Table Table 2. Input and Output operation table Function explanation: Slow and Fast Decay external PWM operation Table 3. Slow and Fast Decay © 2022 ROHM Co., Ltd. 4/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Operating procedure: Using Switches to control IN1 and IN2 1. Connect a DC brushed motor to connector CN1 (or to OUT1 and OUT2 test points) using wires. 2. Connect power supply between VCC and GND test points. 3. Connect a separate 5V to 5V test point. 4. Operate the switches “S1” and “S2” based on Input and Output operation shown in Table 2. Operating procedure: Using external PWM signal to control IN1 and IN2 1. Connect a DC brushed motor to connector CN1 (or to OUT1 and OUT2 test points) using wires. 2. Connect power supply between VCC and GND test points. 3. Ensure that the switches S1 and S2 are pointed towards the “L” position (right side) so that IN1 and IN2 are not connected to 5V. See Figure 5 for description. 4. Connect an external microcontroller to IN1 and IN2 test points. 5. Operate the DC brushed motor based on Table 3 suggestion. Pin configuration Figure 7. Pin configuration Table 4. Pin Descriptions © 2022 ROHM Co., Ltd. 5/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Evaluation board schematic Figure 8. Evaluation board schematic Parts list Table 5. Parts list Reference Value Description C0 0.1µF CAP CER 0.1UF 50V X7R 0805 C1 100uF 63V 20% CAP ALUM 100UF 20% 63V RADIAL CN1 JUMPER CONN HEADER VERT 2POS 2.54MM S1, S2 SPDT On-On SWITCH SLIDE SPDT 500MA 12V TP_VCC, TP_5V Test_Pad TP_GND TP_OUT1, TP_OUT2, TP_IN1, TP_IN2 U1 Package Reference 0805 (2012 Metric) 5.0mm lead spacing, 10mm diameter 2 position 0.100" (2.54mm) MFG PART NUMBER WURTH 885012207098 WURTH 860010775014 WURTH 61300211121 WURTH 450301014042 Test_Pad_Compact_Red 2.54mm lead spacing, 10mm body length 1.6mm hole KEYSTONE 5005 Test_Pad Test_Pad_Compact_Black 1.6mm hole KEYSTONE 5006 Test_Pad Test_Pad_Compact_Whit e 1.6mm hole KEYSTONE 5007 BD62110AEFJ-E2 BD62120AEFJ-E2 BD62130AEFJ-E2 36V, DC Brushed Motor Driver (1A/2A/3A) HTTSOP-8J ROHM BD62110AEFJ-E2 BD62120AEFJ-E2 BD62130AEFJ-E2 © 2022 ROHM Co., Ltd. 6/8 No.65UG003E Rev.001 May 2022 BD621x0AEFJ-EVK-101 User’s Guide Board layout Evaluation board PCB information Material FR-4 Board thickness 1.575mm Copper thickness 1 oz Number of layers 2 Board size 50X50mm Minimum copper width 0.300mm Minimum air gap 0.350mm Minimum hole size 0.300mm The layout of BD621x0AEFJ-EVK-101 is shown below. Figure 9. Top Layer and Top Silk Screen Figure 10. Bottom Layer © 2022 ROHM Co., Ltd. 7/8 No.65UG003E Rev.001 May 2022 User’s Guide BD621x0AEFJ-EVK-101 Revision history Date Revision number May 1, 2022 001 © 2022 ROHM Co., Ltd. Description Initial release 8/8 No.65UG003E Rev.001 May 2022 Notice Notes 1) The information contained herein is subject to change without notice. 2) Before you use our Products, please contact our sales representative and verify the latest specifications : 3) Although ROHM is continuously working to improve product reliability and quality, semiconductors can break down and malfunction due to various factors. Therefore, in order to prevent personal injury or fire arising from failure, please take safety measures such as complying with the derating characteristics, implementing redundant and fire prevention designs, and utilizing backups and fail-safe procedures. ROHM shall have no responsibility for any damages arising out of the use of our Poducts beyond the rating specified by ROHM. 4) Examples of application circuits, circuit constants and any other information contained herein are provided only to illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. 5) The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM or any other parties. ROHM shall have no responsibility whatsoever for any dispute arising out of the use of such technical information. 6) The Products specified in this document are not designed to be radiation tolerant. 7) For use of our Products in applications requiring a high degree of reliability (as exemplified below), please contact and consult with a ROHM representative : transportation equipment (i.e. cars, ships, trains), primary communication equipment, traffic lights, fire/crime prevention, safety equipment, medical systems, servers, solar cells, and power transmission systems. 8) Do not use our Products in applications requiring extremely high reliability, such as aerospace equipment, nuclear power control systems, and submarine repeaters. 9) ROHM shall have no responsibility for any damages or injury arising from non-compliance with the recommended usage conditions and specifications contained herein. 10) ROHM has used reasonable care to ensurH the accuracy of the information contained in this document. However, ROHM does not warrants that such information is error-free, and ROHM shall have no responsibility for any damages arising from any inaccuracy or misprint of such information. 11) Please use the Products in accordance with any applicable environmental laws and regulations, such as the RoHS Directive. For more details, including RoHS compatibility, please contact a ROHM sales office. ROHM shall have no responsibility for any damages or losses resulting non-compliance with any applicable laws or regulations. 12) When providing our Products and technologies contained in this document to other countries, you must abide by the procedures and provisions stipulated in all applicable export laws and regulations, including without limitation the US Export Administration Regulations and the Foreign Exchange and Foreign Trade Act. 13) This document, in part or in whole, may not be reprinted or reproduced without prior consent of ROHM. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ ZZZURKPFRP ‹652+0&R/WG$OOULJKWVUHVHUYHG 5%
BD62120AEFJ-EVK-101 价格&库存
很抱歉,暂时无法提供与“BD62120AEFJ-EVK-101”相匹配的价格&库存,您可以联系我们找货
BD62120AEFJ-EVK-101
  • 1+524.772001+66.83650
BD62120AEFJ-EVK-101
  • 1+580.72791
