RPM960-H14
Photo Link Module
IrDA Infrared Communication Module
RPM960-H14
RPM960-H14 is an infrared communication module for IrDA Ver. 1.3 (Low Power). The infrared LED, PIN photo diode, and LSI are all integrated into one single package. This module is designed for low power consumption. The very small package makes it a perfect fit for mobile devices.
Features 1) Infrared LED, PIN photo diode, LED driver and receiver frequency formation circuit built in. Improvement of EMI noise protection because of Shield Case. 2) Applied to SIR (2.4k to 115.2kbps) and MIR (0.576,1.152Mbps). 3) Surface mounting type. 4) Power down function built in. 5) Adjustable transmission distance by LED load resistance value.
Applications Cellular phone, PDA, DVC, Digital still camera, Printer, Handy terminal and etc.
Absolute maximum ratings (Ta=25°C)
Parameter Supply Voltage Input Voltage Operation Temperature Storage Temperature LED Peak Current Power Dissipation Symbol Vcc/LEDVCC/VIO Vin(3,4,5pin) Topr Tstg Ifp Pd Limits 6.5 ∗1 −0.3 to VIO+0.3 −25 to 85 −30 to 100 400 ∗2 300 ∗3 Units V V °C °C mA mW
∗1) This applies to all pins on the basis of ground pin (8pin). ∗2) LED Peak Current : < 90 µs, On duty < 25% ∗3) When glass-epoxy board (70x70x1.6mm) mounted. In case of operating environment is over 25°C, 4mW
would be reduced per each 1˚C stepping up.
Recommended operating conditions
Parameter Symbol VCC Supply voltage LEDVCC VIO Min. 2.4 2.7 1.8 Typ. 3.0 3.0 3.0 Max. 3.6 5.5 VCC Units V V V
Rev.C
1/5
RPM960-H14
Photo Link Module
Block diagram and application circuit
R1
LEDA
1
LEDVCC
2
LEDC
TXD TXD
3
RXD
4
RXD
AMP
POWER DOWN
PWDOWN PWDOWN
5
AMP
6
VCC C1
VCC
7
VIO VIO
AMP
GND
8
GND
VCC(6pin) and LEDVCC(1pin) can be used on either common power source or different one.
Recommended values
Part symbol C1 R1 Recommended value 6.8µF, Ceramic or tantalum Ex.) TCFGA1A685M8R (ROHM) 5.6Ω ±5%,1/4 W(LEDVCC=3.0V) Notice Bigger capacitance is recommended with much noise from power supply. More than 50cm distance, more than 10µW/cm at detecting side.(vs ver1.1)
2
In case of using R1 with different condition from the above, formula is as follows : LED resistance value : R1[Ω], LED's average consumption current : ILED[mA], Supply voltage : LEDVCC[V] necessar y d[cm] (Including LED's distribution within ±15 deg) R1=T (LEDVCC−1.45) / d −5[Ω] ILED=Duty (LEDVCC−1.36) / (R1+4) [A]
2
∗ At ILED / Duty < 180 mA
Duty : LED duty at emitting, T=17000
Rev.C
2/5
RPM960-H14
Photo Link Module
Terminal description
Pin No Terminal Circuit Function
LED Anode Terminal Other power source can be used difference between LEDVCCand VCC. LED current depends on LED load resistance value. Include internal current limiter (max.400mA). LED Cathode Terminal
1
1 LEDA
LED
2
2
LEDC VIO
This terminal must be left open. Transmitting Data Input Terminal H:LED radiant (PWDOWN='L') CMOS Logic Level Input. Holding TXD="H"status, LED will be turned off at approximately 48 µs.
Receiving Data Output Terminal
3
TXD
600k
VIO PWDOWN VIO
300k
When PWDOWN(5pin)='H', the RXD output will be pulled up to VIO at approximately 300 kΩ.
4
RXD
VIO
Power-down Control Terminal H: POWERDOWN L : OPERATION
5
PWDOWN
When input is "H", it will stop the receiving circuit, Pin−PD current and transmitting LED operation. VCC Supply voltage for Transceiver circuits. For preventing from infection, connect a capacitor between GND(8pin). VIO Supply voltage for I / 0 pins (PWDOWN,RXD,TXD).
6
VCC
7
8
VIO
GND
GROUND
Shield Case
Connect to Ground.
Rev.C
3/5
RPM960-H14
Photo Link Module
Electrical characteristics (Unless otherwise noted, VCC=3V, LEDVCC=3V, VIO=3V, Ta=25°C)
Parameter Consumption current 1 Consumption current 2 Transmission rate PWDOWN input high voltage PWDOWN input low voltage PWDOWN input high current PWDOWN input low current
< Transmitter >
Symbol ICC1 ICC2
Min. 270 − 2.4 2/3∗VIO 0
−1.0 −1.0
Typ. 440 0.01 − − −
0 0 − − 5 0 170
260
Max. 610 0.2 1152
VIO
Unit µA µA kbps V V
µA µA
Conditions PWDOWN=OV, At no input light PWDOWN=VIO, At no input light
VPDH VPDL IPDH IPDL
1/3∗VIO
1.0 1.0
VIO = 1.8 to 3.6 V (VIO < VCC) − PWDOWN=VIO
PWDOWN=0V
TXD input high voltage TXD input low voltage TXD input high current TXD input low current LED anode current 1
LED anode current 2
VTXH VTXL ITXH ITXL ILED1
ILED2
2/3∗VIO
0 2.5 −1.0 −
180
VIO
V V µA µA
mA
1/3∗VIO 10
1.0 − 400
TXD=VIO TXD=0 V
R1=5.6Ω R1=5.6Ω LEDVCC=5.5V
mA
< Receiver >
RXD output high voltage RXD output low voltage RXD output rise time RXD output fall time RXD output pulse width
RXD output pulse edge jitter
VRXH VRXL tRR tFR twRXD
Tjrxd
VIO−0.4 0 − − 228
− − 20 20 380
VIO 0.4 − − 532
160
V V ns ns ns
ns
IRXH= −200µA IRXL= 200µA CL=15pF CL=15pF CL=15pF, 2.4k to 1.152 Mbps
1.152 Mbps
Receiver latency time
tRT
100
200
µs
Optical characteristics (Unless otherwise noted, VCC=3V, LEDVCC=3V, VIO=3V, Ta=25°C)
Parameter Peak wave length Intensity1 Half−angle Rise time / Fall time Optical over shoot Edge jitter Optical pulse width Minimum irradiance in angular Maximum irradiance in augular Input half−angle Maximum emitting time Tj Twe Eemin Eemax θD / 2 TLEDmax Symbol λP IE1 θL / 2 Tr / Tf Min. 850 25 − − − −25 172 − 500 ±15 16 Typ. 870 63 ±18 − − − 217 9 − − 48 Max. 900 200 − 40 25 25 256 14 − − 120 Unit nm mW / Sr deg ns % ns ns µW / cm2 tTXD=217 ns −15 deg < θ L < 15 deg − − 10% to 90% < −15 deg − θ L < 15 deg − R1=5.6Ω Conditions
mW / cm2 −15 deg < θ L < 15 deg − − deg µs TXD=VIO
1. This product is not designed for protection against radioactive rays. 2. This product dose not include laser transmitter. 3. This product includes one PIN photo diode. 4. This product dose not include optical load.
Rev.C
4/5
RPM960-H14
Photo Link Module
Notes 1) LEDVCC (1pin), VCC (6pin) and VIO (7pin) • Other power source can be used difference between LEDVCC and VCC and VIO. (VIO < VCC+0.3V) 2) Caution in designing board lay-out To get maximum potential from RPM960-H14, please keep in mind following instruction. • The line of RXD (4pin) should be connected at backside via through hole close to RPM960-H14 pin lead. Better not to be close to photo diode side (8pin side). ⇒This is to minimize feedback supplied to photo diode from RXD. • Better to be placed at more than 1.0cm radius from photo diode (8pin side) and also away from the parts which generate noise, such as DC / DC converter. • As for C1 between 6 and 8 pins, it should be placed close to RPM960-H14. 3) Notes • Please be sure to set up the TXD (3pin) input to be “L” (under 0.6V) except transmitting data. (For < 90µ sec. ON duty < 25%). • Powerdown current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode. • Please use by the signal format which is specified by IrDA Ver1.3 (Low Power) except 4 Mbps. There might be on error if used by different signal format. 4) Eye safe • EN60825-1 (IEC60825-1 amendment2), Class1 Eye safe.
External dimensions (Unit : mm)
R1.0 8.0
R1.1 2.2
2.2
LED
1.1 1.4 2.8 4.0 A
PinPD
1.0
0.78
0.15±0.1 0.76 2.59
0.15±0.1 2.9
2.67
A Part Size (Shield Case underside size)
0.37±0.1 0.95 P0.95×7=6.65 0.6 0.48
0.6±0.1
(0.13)
0.68±0.1
NOTE 1.TOLERANCE : ±0.2mm 2.COPLANARITY : 0.1mmMAX UNIT : mm ETH396
0.75
1
8
2.2
Rev.C
5/5
Appendix
Notes
No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design.
The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction.
Appendix1-Rev1.1
