RPM960-H14E3
RPM960-H14E3
    ROHM(罗姆)
    IC IRDA IR COMMUNICATION MODULE
RPM960-H14E3 数据手册
RPM960-H14 RPM960-H14 Photo Link Module IrDA Infrared Communication Module RPM960-H14 RPM960-H14 is an infrared communication module for IrDA Ver. 1.3 (Low Power). The infrared LED, PIN photo diode, and LSI are all integrated into one single package. This module is designed for low power consumption. The very small package makes it a perfect fit for mobile devices. zFeatures 1) Infrared LED, PIN photo diode, LED driver and receiver frequency formation circuit built in. Improvement of EMI noise protection because of Shield Case. 2) Applied to SIR (2.4k to 115.2kbps) and MIR (0.576,1.152Mbps). 3) Surface mounting type. 4) Power down function built in. 5) Adjustable transmission distance by LED load resistance value. zApplications Cellular phone, PDA, DVC, Digital still camera, Printer, Handy terminal and etc. zAbsolute maximum ratings (Ta=25°C) Parameter Supply Voltage Input Voltage Symbol Limits Units 6.5 ∗1 Vcc/LEDVCC/VIO Vin(3,4,5pin) V −0.3 to VIO+0.3 V Operation Temperature Topr −25 to 85 °C Storage Temperature Tstg −30 to 100 °C LED Peak Current Ifp 400 ∗2 Power Dissipation Pd 300 ∗3 mA mW ∗1) This applies to all pins on the basis of ground pin (8pin). ∗2) LED Peak Current : < 90 µs, On duty < 25% ∗3) When glass-epoxy board (70x70x1.6mm) mounted. In case of operating environment is over 25°C, 4mW would be reduced per each 1˚C stepping up. zRecommended operating conditions Parameter Symbol Min. Typ. Max. Units VCC 2.4 3.0 3.6 V Supply voltage LEDVCC 2.7 3.0 5.5 V VIO 1.8 3.0 VCC V Rev.C 1/5 RPM960-H14 Photo Link Module zBlock diagram and application circuit R1 LEDA 2 1 LEDVCC LEDC TXD 3 TXD RXD PWDOWN PWDOWN 5 POWER DOWN VCC VCC AMP 6 AMP 4 RXD AMP 7 C1 VIO VIO GND 8 GND VCC(6pin) and LEDVCC(1pin) can be used on either common power source or different one. zRecommended values Part symbol Recommended value Notice C1 6.8µF, Ceramic or tantalum Ex.) TCFGA1A685M8R (ROHM) Bigger capacitance is recommended with much noise from power supply. R1 5.6Ω ±5%,1/4 W(LEDVCC=3.0V) More than 50cm distance, more than 10µW/cm at detecting side.(vs ver1.1) 2 In case of using R1 with different condition from the above, formula is as follows : LED resistance value : R1[Ω], LED's average consumption current : ILED[mA], Supply voltage : LEDVCC[V] necessary d[cm] (Including LED's distribution within ±15 deg) 2 + + R1=T (LEDVCC−1.45) / d −5[Ω] ILED=Duty (LEDVCC−1.36) / (R1+4) [A] Duty : LED duty at emitting, T=17000 ∗ At ILED / Duty < 180 mA Rev.C 2/5 RPM960-H14 Photo Link Module zTerminal description Pin No Terminal Circuit Function LED Anode Terminal Other power source can be used difference between LEDVCCand VCC. LED current depends on LED load resistance value. Include internal current limiter (max.400mA). 1 1 LEDA LED 2 LED Cathode Terminal 2 LEDC This terminal must be left open. Transmitting Data Input Terminal H:LED radiant (PWDOWN='L') CMOS Logic Level Input. Holding TXD="H"status, LED will be turned off at approximately 48 µs. VIO 3 TXD 600k Receiving Data Output Terminal VIO VIO PWDOWN When PWDOWN(5pin)='H', the RXD output will be pulled up to VIO at approximately 300 kΩ. 4 RXD 300k VIO Power-down Control Terminal H: POWERDOWN L : OPERATION 5 PWDOWN CMOS Logic Level Input. When input is "H", it will stop the receiving circuit, Pin−PD current and transmitting LED operation. 6 VCC VCC Supply voltage for Transceiver circuits. For preventing from infection, connect a capacitor between GND(8pin). 7 VIO VIO Supply voltage for I / 0 pins (PWDOWN,RXD,TXD). 8 GND GROUND − Shield Case Connect to Ground. Rev.C 3/5 RPM960-H14 Photo Link Module zElectrical characteristics (Unless otherwise noted, VCC=3V, LEDVCC=3V, VIO=3V, Ta=25°C) Parameter Typ. Max. 270 440 610 µA PWDOWN=OV, At no input light − 0.01 0.2 µA PWDOWN=VIO, At no input light 2.4 − 1152 kbps Symbol Min. Consumption current 1 ICC1 Consumption current 2 ICC2 Transmission rate Unit Conditions PWDOWN input high voltage VPDH 2/3∗VIO − VIO V PWDOWN input low voltage VPDL 0 − 1/3∗VIO V VIO = 1.8 to 3.6 V (VIO < − VCC) PWDOWN input high current IPDH −1.0 0 1.0 µA PWDOWN=VIO PWDOWN input low current IPDL −1.0 0 1.0 µA PWDOWN=0V TXD input high voltage VTXH 2/3∗VIO − VIO V TXD input low voltage VTXL 0 − 1/3∗VIO V VIO = 1.8 to 3.6 V (VIO < − VCC) TXD input high current ITXH 2.5 5 10 µA TXD=VIO TXD input low current ITXL −1.0 0 1.0 µA TXD=0 V LED anode current 1 ILED1 − 170 − mA R1=5.6Ω LED anode current 2 ILED2 180 260 400 mA R1=5.6Ω LEDVCC=5.5V RXD output high voltage VRXH VIO−0.4 − VIO V IRXH= −200µA RXD output low voltage VRXL 0 − 0.4 V IRXL= 200µA RXD output rise time tRR − 20 − ns CL=15pF RXD output fall time tFR − 20 − ns CL=15pF twRXD 228 380 532 ns CL=15pF, 2.4k to 1.152 Mbps Tjrxd − − 160 ns 1.152 Mbps tRT − 100 200 µs < Transmitter > < Receiver > RXD output pulse width RXD output pulse edge jitter Receiver latency time zOptical characteristics (Unless otherwise noted, VCC=3V, LEDVCC=3V, VIO=3V, Ta=25°C) Parameter Symbol Min. Typ. Max. Unit Peak wave length λP 850 870 900 nm Intensity1 IE1 25 63 200 mW / Sr Half−angle θL / 2 − ±18 − deg Rise time / Fall time Tr / Tf − − 40 ns − − 25 % Tj −25 − 25 ns ns Optical over shoot Edge jitter Optical pulse width Conditions −15 deg < −θ L < − 15 deg R1=5.6Ω 10% to 90% Twe 172 217 256 Minimum irradiance in angular Eemin − 9 14 µW / Maximum irradiance in augular Eemax 500 − − mW / cm2 −15 deg < −θL< − 15 deg θD / 2 ±15 − − deg TLEDmax 16 48 120 µs Input half−angle Maximum emitting time cm2 tTXD=217 ns −15 deg < −θ L < − 15 deg TXD=VIO 1. This product is not designed for protection against radioactive rays. 2. This product dose not include laser transmitter. 3. This product includes one PIN photo diode. 4. This product dose not include optical load. Rev.C 4/5 RPM960-H14 Photo Link Module zNotes 1) LEDVCC (1pin), VCC (6pin) and VIO (7pin) • Other power source can be used difference between LEDVCC and VCC and VIO. (VIO < VCC+0.3V) 2) Caution in designing board lay-out To get maximum potential from RPM960-H14, please keep in mind following instruction. • The line of RXD (4pin) should be connected at backside via through hole close to RPM960-H14 pin lead. Better not to be close to photo diode side (8pin side). ⇒This is to minimize feedback supplied to photo diode from RXD. • Better to be placed at more than 1.0cm radius from photo diode (8pin side) and also away from the parts which generate noise, such as DC / DC converter. • As for C1 between 6 and 8 pins, it should be placed close to RPM960-H14. 3) Notes • Please be sure to set up the TXD (3pin) input to be “L” (under 0.6V) except transmitting data. (For < 90µ sec. ON duty < 25%). • Powerdown current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode. • Please use by the signal format which is specified by IrDA Ver1.3 (Low Power) except 4 Mbps. There might be on error if used by different signal format. 4) Eye safe • EN60825-1 (IEC60825-1 amendment2), Class1 Eye safe. zExternal dimensions (Unit : mm) R1.0 R1.1 8.0 2.2 2.2 PinPD 2.59 A Part Size (Shield Case underside size) 2.2 8 0.37±0.1 0.95 0.75 2.67 1 0.15±0.1 0.76 0.78 0.15±0.1 1.1 1.4 2.8 4.0 A 2.9 1.0 LED P0.95×7=6.65 (0.13) 0.48 0.68±0.1 0.6±0.1 0.6 NOTE 1.TOLERANCE : ±0.2mm 2.COPLANARITY : 0.1mmMAX UNIT : mm ETH396 Rev.C 5/5 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM960-H14E3 价格&库存
很抱歉,暂时无法提供与“RPM960-H14E3”相匹配的价格&库存,您可以联系我们找货
