LAN Magnetics Solution for 1000BASE-T
Evaluation Board TDK Part number: ALT4532-EVA-01A
Contents
PCB area reduction from typical module to discrete placement
Typical module
TDK discrete placement
17.53
Module type
8.1
16.00
17.3
Units: mm
Placement area: 50% reduction
Evaluation Board configuration and detailed specification
Technical Specification of Pulse Transformer plus Common Mode
Filter combination for 1000BASE-T Solution
• LAN Transformer: ALT4532M-201-T001
• Common Mode Filter: ACM2012-900-2P-T002
Disclosure:
- Evaluation Board is provided for evaluation of TDK discrete solution purposes only.
Customer needs to implement connections into its PCB lay out design for mass production.
- Evaluation Board will be replaced if a working problem is found, without failure analysis.
Evaluation Board Configuration & Detailed Specification
Evaluation board – Ordering Part Number: ALT4532-EVA-01A
- Contains ALT4532M-201-T001 + ACM2012-900-2P-T002 solution for quick evaluation
- Allows SI/EMC test for our ALT4532 on the same land pattern as module
1000BASE-T Evaluation Board (Offers equivalent layout to Module type)
17.5
㉔
⑬
1.27
Common mode filter
ACM2012-900
14.6
Pulse transformer
ALT4532M-201
①
⑫
Units: mm
㉔㉓
㉒ ㉑⑳
⑲ ⑱⑰
⑯ ⑮⑭
⑬
①②
③ ④⑤
⑥ ⑦⑧
⑨ ⑩⑪
⑫
Evaluation Board Electrical diagram and pin out
13.97
17.53
1.27
1.27
16.51
Pad layout
12.70
16.00
12.20
Module type
0.76
Units: mm
Overview of ALT4532M-201-T001
FEATURES
• The ALT Series contains wound chip type pulse transformers developed for
LANs.
• Compatible with 100BASE-TX and 1000BASE-T.
• High-quality product that uses auto winding.
• Conforms to the RoHS directive.
GENERAL SPECIFICATIONS
CIRCUIT DIAGRAM
SHAPE & DIMENSIONS
RECOMMENDED LAND PATTERN
Units: mm
ELECTRICAL CHARACTERISTICS
□CHARACTERISTICS SPECIFICATION TABLE
Turns ratio
①⑥② : ⑤③④
1CT : 1CT
Inductance
[DC bias 8mA, 100kHz]
①-②
⑤-④
(μH)min.
Insertion loss
[0.1 to 100MHz]
①② - ⑤④
Inter-winding stray
capacitance
[100kHz]
(dB)max.
(pF)max.
200
1.5
35
OPERATING TEMPERATURE RANGE
Temperature range
Part No.
ALT4532M-201-T001
Operating
temperature*(℃)
Storage
temperature**(℃)
-40 to +85
-40 to +85
*Operating temperature range includes self-temperature rise.
**The Storage temperature range is for after the circuit board is mounted.
Part No.
ALT4532M-201-T001
Overview of ACM2012-900-2P-T002
FEATURES
• Downsized wound type chip common mode filter that
maintains required common mode filter characteristics.
• Impedance for common mode noise can clear 65Ω [100MHz],
and has excellent EMC suppression.
• Differential mode impedance is suppressed, so there is virtually
no affect on high speed signals.
• Conforms to the RoHS Directive.
CIRCUIT DIAGRAM
SHAPE & DIMENSIONS
1
4
2
3
0.4
0.4
0.4
0.75
1.1
0.75
Units: mm
Impedance
[100MHz]
DC resistance
[per 1 line]
Rated voltage
Insulation
resistance
Rated current
(Ω)
(Ω)max.
(V)max.
(MΩ)min.
(A)max.
90 typ.
0.19
DC 50
10
0.4
Temperature range
Part No.
ACM2012-900-2P-T002
Operating
temperature(℃)
Storage
temperature*(℃)
-40 to +85
-40 to +85
Part No.
ACM2012-900-2P-T002
Comparison with Conventional Module
Comparison between TDK Solution and Conventional module for Balance Parameter
** TDK solution offers excellent frequency performance.
ALT4532 +ACM2012
Hand Made Product
ALT4532
ACM2012
Full Automation
vs
Hand Made Product
很抱歉,暂时无法提供与“ALT4532-EVA-01A”相匹配的价格&库存,您可以联系我们找货
