T R A N S F O R M E R S
Pulse transformers
For LAN interface (10GBASE-T)
ALT series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ALT4532H type
FEATURES
The ALT series contains wound chip type pulse transformers developed for LANs.
Compatible with 10GBASE-T.
High-quality product that uses auto winding.
Conforms to the RoHS directive.
Operating temperature range: –40 to +85°C (including self-temperature rise)
APPLICATION
LAN interfaces of various devices including network devices, communication equipment, digital consumer electronics, etc.
PART NUMBER CONSTRUCTION
ALT
4532
H
121
T
10G
Series name
L×W×H dimensions
4.5×3.2×2.9 mm
Product internal
code
Inductance
(µH min.)
at 100kHz/No bias
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Turn ratio
1CT : 1CT
Inductance
[No bias, 100kHz]
(µH)min.
120
Insertion loss
Inter-winding stray capacitance
[100kHz]
Thickness T
(pF)max.
(mm)max.
35
2.9
Part No.
(dB)max.
0.5 at 1-150MHz
1.0at 150-500MHz
ALT4532H-121-T10G
Measurement equipment
Measurement item
Product No.
Inductance
4284A
Insertion loss
E5071C
4284A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20210630
trans_alt4532h_en.fm
ALT4532H type
INSERTION LOSS VS. FREQUENCY CHARACTERISTICS
0.0
Insertion loss (dB)
1.0
2.0
3.0
4.0
5.0
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
E5071C
(2/4)
20210630
ALT4532H type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
4.5±0.2
3
5
3.2±0.2
2
(2)
2.0±0.5
4
6
2.9mm max.
ø100+1.0/-1.5
(0.4)
1
(0.9)
(0.9)
ø13.0+0.5/-0.2
Dimensions in mm
13.5±0.5
(ø21)
ø330+2.0/-2.5
RECOMMENDED LAND PATTERN
0.41
Sprocket
hole
12±0.2
4±0.1
1.75±0.1
2±0.1
B
1.2
ø1.55±0.05
0.3±0.05
0.5
0.65
0.41
TAPE DIMENSIONS
Dimensions in mm
ø1.6±0.1
K
A
8±0.1
CIRCUIT DIAGRAM
3
5.5±0.05
1.39
0.70 1.35
1.39
Dimensions in mm
Dimensions in mm
4
5
Type
ALT4532H
A
(3.6)
B
(4.9)
K
(3.05)
2
1
6
PACKAGE QUANTITY
There is no directivity.
Package quantity
2,000 pcs/reel
RECOMMENDED REFLOW PROFILE
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Preheating
Soldering
Natural
cooling
Peak
245°C
Temperature
230°C
Operating
Storage
Individual
temperature range
temperature range
weight
–40 to +85°C
–40 to +85°C
160 mg
Operating temperature range includes self-temperature rise.
The storage temperature range is for after the assembly.
230°C
180°C
5s max.
150°C
60 to 120s
10 to 30s
Time
(3/4)
20210630
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20210630
很抱歉,暂时无法提供与“ALT4532H-121-T10G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.08712
- 10+9.97077
- 25+9.43279
- 100+8.33750
- 250+8.25413
- 500+8.08123
- 1000+7.42740
