CGA5H2X7R2A224KT0Y0U
    TDK(东电化)
    贴片电容(MLCC) 1206 220nF ±10% 100V X7R
CGA5H2X7R2A224KT0Y0U 数据手册
CGA4J3X7R1A475K125AB TDK Item Description : CGA4J3X7R1A475KT**** Equivalent C2012X7R1A475K for Automotive DC Bias Characteristic 5 Application & Main Feature 0 Cap. Change/% Automotive Grade ( General (Up to 50V) ) Series CGA4(2012) [EIA CC0805] -5 -10 -15 -20 -25 -30 -35 -40 -45 0 2 4 6 8 10 12 DC Bias/V 2.00mm 1.25mm 1.25mm 0.20mm 0.50mm +/-0.2mm +/-0.2mm +/-0.2mm Min. Min. Temperature Characteristic Temperature Characteristics 20 10 100 0 10 1 0.1 0.01 Rated Voltage 0.001 0.001 0.1 -30 -40 -50 -60 -70 1 10 100 -80 1000 -60 -40 |Z| Capacitance Tolerance ESR 20 40 60 80 100 120 140 TCBias(1/2Rated) Ripple Temperature Rise Characteristics 25 Temperature Rise/degC 100 Dissipation Factor 7.5% Max. 10 AEC-Q200 Yes 20 15 10 5 0 1 0.001 0 Temp.Chara. Cap. vs. Freq. Characteristic K (+/-10%) -20 Temperature/degC Frequency/MHz 4.7uF 21Mohm Min. -20 -90 0.01 Capacitance Insulation Resistance -10 -80 1A (10Vdc) Cap./uF Characterization Sheet ( Multilayer Ceramic Chip Capacitors ) X7R (-55 to 125 degC +/-15%) |Z|, ESR vs. Freq. Characteristics 1000 Cap. Change/% L W T B G |Z|, ESR/ohm Dimensions 0.01 0.1 1 10 100 1000 0 1 2 100kHz All specifications are subject to change without notice. 3 4 5 Current/Arms Frequency/MHz 500kHz 1MHz January 4, 2016
CGA5H2X7R2A224KT0Y0U 价格&库存
很抱歉,暂时无法提供与“CGA5H2X7R2A224KT0Y0U”相匹配的价格&库存,您可以联系我们找货
    • 10+0.53635
    • 100+0.42876
    • 300+0.37497
    • 1000+0.33462
    库存:1955
    • 1+1.53797
    • 30+1.48015
    • 100+1.36451
    • 500+1.24888
    • 1000+1.19106
