R F
C o m p o n e n t s
August 2018
Multilayer Low Pass Filter
For 470-770MHz
DEA160770LT-5018A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
Caution
The products in this catalog will be or have been
stopped production
Discontinue Issue Date
Jul. 6, 2018
Last Purchase Order Date
Dec. 17, 2018
Last Shipment Date
Mar. 29, 2019
Please refer to our Web site about replacement information.
RF Components
Conformity to RoHS Directive
For 470-770MHz
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
DEA160770LT-5018A1
SHAPES AND DIMENSIONS
[Top view]
1.60±0.15
0.50max.
(3)
(4)
[Bottom view]
0.50±0.10
Marking
0.10min.
(1)
0.80±0.10
(2)
Terminal functions
1 IN
2 GND
3 OUT
4 GND
0.20±0.10
0.20min.
Dimensions in mm
RECOMMENDED LAND PATTERN
0.80
1.40
0.50
0.60
0.50
Dimensions in mm
Th
e
2.20
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20180801 / rf_lpf_dea160770lt-5018a1_en.fm
RF Components
DEA160770LT-5018A1
ELECTRICAL CHARACTERISTICS
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Characteristic Impedance ()
・Ta: +25±5°C
Frequency Range
(MHz)
Min.
Typ.
Max.
470 to 770
470 to 770
1900 to 1950
10
40
0.34
19.0
53.9
50 (Nominal)
0.5
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
Item
TEMPERATURE RANGE
Storage temperature
(°C)
–40 to +85
Th
e
Operating temperature
(°C)
–40 to +85
RF Components
DEA160770LT-5018A1
FREQUENCY CHARACTERISTICS
0.0
1.0
ATTENUATION
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
INSERTION LOSS
4.0
5.0
Attenuation(dB)
Insertion Loss (dB)
2.0
30
40
6.0
50
7.0
8.0
450
650
850
1050
Frequency (MHz)
1250
1450
60
450
950
1450
1950
Frequency (MHz)
2450
2950
RETURN LOSS
–10
Return Loss(dB)
10
40
950
1450
1950
Frequency (MHz)
2450
2950
Th
e
50
450
RF Components
DEA160770LT-5018A1
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T1
t1
T3
t3
t2
t: Time
Preheating
Temp.
T1
150°C
t3
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
Th
e
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
pr
od
u
st cts
op w
pe il
d lb
pr e
od or
uc ha
tio ve
n
be
en
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
Th
e
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA160770LT-5018A1”相匹配的价格&库存,您可以联系我们找货
