DEA203500BT-2213A1-H
    TDK(东电化)
    3.5GHz 频率 带通 RF 滤波器 (射频) 200MHz 带宽 1dB 0805(2012 公制),6 PC 板
DEA203500BT-2213A1-H 数据手册
April. 2017 Ver.3.1a TDK Corporation Multilayer Band Pass Filter For LTE DEA Series P/N: 2.0x1.25mm [EIA 0805] TYPE DEA203500BT-2213A1-H All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies April. 2017 Ver.3.1a TDK Corporation   DEA203500BT-2213A1-H ■ SHAPES AND DIMENSIONS [Bottom View] [Top View] (6) (5) (1) (5) (6) (4) (4) (2) (3) (3) (2) Dimensions (mm) L W T 2.00 1.25 0.65 +/-0.15 +/-0.10 (1) Max a 0.275 b c d e f 0.25 0.60 0.95 0.10 0.20 +/-0.10 +/-0.10 +/-0.10 +/-0.15 +/-0.05 +/-0.05 Terminal functions Input/Output Port (1) GND (2) GND (3)     (4) (5) (6) Input/Output Port GND GND       DC Cut No. There is NOT a DC Cut between the IN & OUT & GND. ■ TEMPERATURE RANGE Operating temperature Storage temperature –40 to +85 °C –40 to +85 °C ■ TERMINATION FINISH Material Ag All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies April. 2017 Ver.3.1a TDK Corporation   DEA203500BT-2213A1-H ■ ELECTRICAL CHARACTERISTICS Parameter Insertion Loss (dB) Insertion Loss (dB) ( –40 to +85 °C ) Return Loss (dB) Attenuation (dB) Frequency (MHz) 3400 to to to 3400 to to to 3400 to to to 500 to 880 to 1710 to 2300 to 4800 4900 5150 6250 6800 7200 10200 Power Handling (W) Characteristic Impedance (ohm) Ta = +25+/-5°C to to to to to to to 3600 3600 3600 2170 960 1785 2700 4400 4900 5150 5925 6550 7200 9000 10800 ( Measurement ) TDK Spec Min. Typ. Max. 0.84 1.00 0.94 1.10 10 22.2 40 40.7 40 43.6 40 40.7 32 34.5 6.1 19.2 25 34.3 30 38.7 35 44.6 40 45.2 40 48.5 35 50.1 35 46.4 1 50 (Nominal) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   April. 2017 Ver.3.1a TDK Corporation DEA203500BT-2213A1-H ■ FREQUENCY CHARACTERISTICS Insertion Loss Return Loss Attenuation All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   April. 2017 Ver.3.1a TDK Corporation DEA203500BT-2213A1-H ■ FREQUENCY CHARACTERISTICS Attenuation All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   April. 2017 Ver.3.1a TDK Corporation DEA203500BT-2213A1-H ■ RECOMMENDED LAND PATTERN ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies April. 2017 Ver.3.1a TDK Corporation   DEA203500BT-2213A1-H ■ PACKAGING STYLE Reel Dimensions Carrier Tape K Sprocket hole Loading Direction C A D E J B t H Dimensions (mm) A B C 1.45 2.2 8.0 +/-0.05 D 3.5 +/-0.05 +0.3/-0.1 +/-0.05 G F E 1.75 F 4.0 G 2.0 H 4.0 J 1.5 K 0.8 t 0.25 +/-0.1 +/-0.1 +/-0.05 +/-0.1 +0.1/-0 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DEA203500BT-2213A1-H 价格&库存
很抱歉,暂时无法提供与“DEA203500BT-2213A1-H”相匹配的价格&库存,您可以联系我们找货
  • 1+2.736161+0.33191
  • 10+2.5900310+0.31418
  • 25+2.5056625+0.30395
  • 50+2.4244150+0.29409
  • 100+2.29848100+0.27882
  • 250+1.92228250+0.23318
  • 500+1.49185500+0.18097
  • 1000+1.420751000+0.17235
    • 10+1.04895
