The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
July 2015
Multilayer Diplexer
For 2400-2500MHz / 4900-5850MHz
DPX165850DT-8017A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX165850DT-8017A1
SHAPES AND DIMENSIONS
[Top view]
0.60 +0.05
–0.10
1.60±0.10
(1)
(3)
(2)
Marking
0.30+0.10
–0.15
0.30+0.10
–0.15
0.15±0.10
0.65±0.15
0.15±0.10
Terminal functions
1 Low-band
2 Common
3 High-band
4 GND
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.30
1.10
0.60
0.50
0.12
0.10
Dimensions in mm
0.05
1.20
0.40
0.30
0.50
0.45
0.05
[Bottom view]
0.80+0.20
–0.10
(4)
0.10
0.05
0.05
Dimensions in mm
0.12
Land
Solder resist
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / rf_dpx_dpx165850dt-8017a1_en.fm
RF Components
DPX165850DT-8017A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2400 to 2500
4900 to 5850
12.74
19.4
23.1
50 (Nominal)
0.40
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5850
4900 to 5850
2400 to 2500
10.16
16.5
35.2
50 (Nominal)
0.60
Item
Frequency Range
(MHz)
Min.
Typ.
Max.
Return Loss (dB)
2400 to 2500
4900 to 5850
12.74
10.16
18.8
16.8
50 (Nominal)
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Characteristic Impedance (:)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
COMMON
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX165850DT-8017A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
LOW-BAND
Insertion Loss
1.5
2.0
2.5
1500
2000
2500
Frequency(MHz)
3000
3500
3.0
4000
4000
Return Loss
10
40
5000
5500
Frequency(MHz)
6000
6500
7000
40
50
1000
1500
2000
2500
Frequency(MHz)
3000
3500
50
4000
4000
Attenuation
4500
5000
5500
Frequency(MHz)
6000
6500
7000
Attenuation
10
Attenuation(dB)
40
40
50
1000
4500
Return Loss
Return Loss(dB)
Return Loss(dB)
2.0
2.5
3.0
1000
Attenuation(dB)
1.5
2000
3000
4000
5000
6000
Frequency(MHz)
7000
8000
9000
50
1000
2000
3000
4000
5000
6000
Frequency(MHz)
7000
8000
9000
RF Components
DPX165850DT-8017A1
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
50
1000
30
40
2000
3000
4000
5000
6000
Frequency(MHz)
7000
8000
9000
50
1000
2000
3000
4000
5000
6000
Frequency(MHz)
7000
8000
9000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX165850DT-8017A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.629581+0.82440
- 10+6.7690810+0.73142
- 25+6.1087825+0.66007
- 100+5.34628100+0.57768
- 250+4.69193250+0.50698
- 500+4.14622500+0.44801
- 1000+3.273361000+0.35370
