Jul. 2016
Ver.2.0
TDK Corporation
Multilayer Diplexer
For 2.4GHz W-LAN & Bluetooth / 5GHz W-LAN
DPX Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DPX165850DT-8040A3
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jul. 2016
Ver.2.0
TDK Corporation
DPX165850DT-8040A3
■ SHAPES AND DIMENSIONS
(c)
(e)
(d) (a) (b)
Dimensions (mm)
L
W
T
a
b
c
d
e
1.60 0.80 0.60 0.30 0.10 0.15 0.25 0.55
+/-0.15 +/-0.15 +/-0.10 +/-0.15 +/-0.10 +/-0.10 +/-0.10 +/-0.10
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
High-Band
Port
(4)
GND
(5)
(6)
Low-Band Port
■ TEMPERATURE RANGE
Operating temperature Storage temperature
–40 to +85 °C
–40 to +85 °C
■ TERMINATION FINISH
Material
Ag
Jul. 2016
Ver.2.0
TDK Corporation
DPX165850DT-8040A3
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Insertion Loss (dB)
2400 to
TDK Spec
Min. Typ. Max.
2500 0.59 0.75
Attenuation (dB)
4800 to
7200 to
5000 23.0 29.0
7500 30.0 49.0
Parameter
Frequency (MHz)
Ta = +25+/-5°C
High-Band
Parameter
Insertion Loss (dB)
Attenuation (dB)
TDK Spec
Min. Typ. Max.
5850 1.48 1.90
Frequency (MHz)
5150 to
2400
3400
3600
7200
7250
10600
15300
to 2500 25.0
to 3900 15.0
to 3600 19.0
to 7200 19.0
to 7550 23.0
to 11700 30.0
to 16200 20.0
34.0
20.0
30.0
27.0
29.0
42.0
27.0
Ta = +25+/-5°C
We recommend to terminate for all port with 50ohm at all times.
Jul. 2016
Ver.2.0
TDK Corporation
DPX165850DT-8040A3
■ FREQUENCY CHARACTERISTICS
Insertion Loss (Low-Band)
Insertion Loss (High-Band)
Return Loss (Low-Band)
Return Loss (high-Band)
Attenuation (Low-Band)
Attenuation (High-Band)
Isolation
Common port Return Loss
Jul. 2016
Ver.2.0
TDK Corporation
DPX165850DT-8040A3
■ RECOMMENDED LAND PATTERN
Note:
Line width be designed to match 50 Ohm characteristic impedance,
depending on PCB material and thickness.
■ EVALUATION BOARD
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Jul. 2016
Ver.2.0
TDK Corporation
DPX165850DT-8040A3
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Working
Temp.
Time
T3
t2
230°C
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX165850DT-8040A3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.775501+0.35350
- 10+2.4723010+0.31490
- 25+2.2390025+0.28520
- 50+2.0991050+0.26730
- 100+1.95910100+0.24950
- 250+1.72590250+0.21980
- 500+1.51600500+0.19310
- 1000+1.201101000+0.15300
- 4000+1.149804000+0.14640
