Jun. 2021 Ver.2.0
TDK Corporation
Multilayer Diplexer
For LTE
DPX Series
P/N:
2.0x1.25mm [EIA 0805] TYPE
DPX201880DT-4061A2
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ SHAPES AND DIMENSIONS
Dimensions (mm)
L
W
T
a
b
c
d
e
2.00 1.25 0.90 0.65 0.35 0.30 0.20 0.20
+/-0.15 +/-0.15 +/-0.10 +/-0.15 +/-0.15 +/-0.15 +/-0.15 +/-0.15
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
(4)
(5)
(6)
High-Band Port
GND
Low-Band Port
■ TERMINATION FINISH
Material
Sn plate
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
VSWR (Low-Band Port)
Attenuation (dB)
Frequency (MHz)
698
960
1447
698
960
1447
1710
1880
2170
to
to
to
to
to
to
to
to
to
960
1447
1511
960
1447
1511
1880
2170
2700
Characteristic Impedance (ohm)
Ta = +25+/-5°C
TDK Spec
Min. Typ. Max.
0.63 0.85
0.71 0.85
0.98 1.60
1.12 1.92
1.21 1.92
1.21 1.92
10 15.0
10 15.0
10 15.0
50 (Nominal)
High-Band
Parameter
Insertion Loss (dB)
VSWR (High-Band Port)
Attenuation (dB)
Ta = +25+/-5°C
Frequency (MHz)
1710
1880
2170
1710
1880
2170
698
960
1447
to
to
to
to
to
to
to
to
to
1880
2170
2700
1880
2170
2700
960
1447
1511
TDK Spec
Min. Typ. Max.
1.02 1.60
0.29 1.00
0.52 1.00
1.35 1.92
1.40 1.92
1,86 2.32
7
9.0
7
9.0
10 15.0
50 (Nominal)
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
( Measurement )
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Low-Band
High-Band
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +85 °C
–40 to +85 °C
Frequency (MHz)
CW
1
698 to 1511
CW
1
1710 to 2700
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ FREQUENCY CHARACTERISTICS
Insertion Loss (Low-Band)
Insertion Loss (High-Band)
Attenuation (Low-Band)
Attenuation (High-Band)
Isolation
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ RECOMMENDED LAND PATTERN
unit : mm
■ EVALUATION BOARD
Material & Layer
Copper Surface Pattern
Teflon
Copper Bottom GND
Thickness
0.05 mm
0.35 mm
0.05 mm
unit : mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Jun. 2021 Ver.2.0
TDK Corporation
DPX201880DT-4061A2
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
K
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
1.45 2.2
8.0
D
3.5
+/-0.05 +/-0.05 +0.3/-0.1 +/-0.05
G
F
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
K
t
1.15 0.25
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX201880DT-4061A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.15949
- 10+0.92589
- 30+0.82577
- 100+0.70082
- 500+0.64520
- 1000+0.61182
- 国内价格
- 1+3.70315
- 10+3.54574
- 25+3.43277
- 50+3.31804
- 100+3.14677
- 250+2.63109
- 500+2.04226
- 1000+1.94502
