Multilayer Diplexers
For GSM850/PCS Tx & Rx
DPX Series
Type:
DPX205850DT-4032A1 (2.0u1.25u0.95mm)
DPX201990DT-4114A2 (2.0u1.25u0.95mm)
DPX201990DT-4014A2 (2.0u1.25u0.95mm)
Issue date:
December 2010
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/6)
Multilayer Chip Diplexers
DPX Series DPX205850DT-4032A1
SHAPES AND DIMENSIONS
2.0±0.15
5
4
1
2
3
1.25±0.15
6
Terminal functions
1 GND
2 ANT
3 GND
4 High Band
5 GND
6 Low Band
0.3±0.2
0.95±0.1
0.65±0.2
0.2±0.2 0.35±0.2
Dimensions in mm
RECOMMENDED PC BOARD PATTERNS
0.58
0.77
0.932
ø0.3 thruough hole
0.32
0.33
Land
Solder resist
Dimensions in mm
ELECTRICAL CHARACTERISTICS
Item
Insertion loss
Attenuation
Temperature range
Port
ANT Lo-band
ANT Hi-band
ANT Lo-band
ANT Hi-band
Frequency range
800 to 2170MHz
2400 to 5850MHz
2400 to 5850MHz
800 to 2170MHz
Operating
Storage
(dB)
(dB)
(dB)
(dB)
(°C)
(°C)
Minimum value
8.0
8.0
–40
–40
Typical value
1.51
1.36
12.7
11.5
Maximum value
3.0
3.0
+85
+85
• Ta: +25°C
specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
001-02 / 20101204 / e741_multi_dpx03
(2/6)
3
4
1500
2500
3500
4500
Frequency (MHz)
Return loss(dB)
COMMON PORT RETURN LOSS
–5
–10
–15 1
–20
–25
–30
–35
–40
–45
–50
500
2500
3500
4500
Frequency (MHz)
–5
Return loss (dB)
S11
1: 800MHz
–13.4dB
4 2: 2170MHz
–21.9dB
3: 2400MHz
–20.0dB
4: 5850MHz
–7.1dB
3
Lo-BAND PORT RETURN LOSS
–10
–15
5500
2
1500
1
–20
2
–25
S22
4 1: 800MHz
–13.5dB
2: 2170MHz
–21.1dB
3: 2400MHz
–2.4dB
4: 5850MHz
0.6dB
–5
–10
–15
–20
–25 1
–30
–35
–40
–45
–50
500
2
1500
–5
–10
–15
–20
1
–25
–30
–35
–40
–45
–50
500
2500
3500
4500
Frequency (MHz)
S23
2
1: 800MHz
–19.0dB
2: 2170MHz
–12.8dB
3: 2400MHz
–13.7dB
4: 5850MHz
–38.9dB
3
4
1500
2500
3500
4500
Frequency (MHz)
Hi-PORT RETURN LOSS
–5
S31
4 1: 800MHz
–20.3dB
2: 2170MHz
–11.5dB
3: 2400MHz
–1.36dB
4: 5850MHz
–1.12dB
3
ISOLATION
5500
–30
–35
500
Attenuation (dB)
1: 800MHz
–0.38dB
2: 2170MHz
–1.51dB
3: 2400MHz
–12.7dB
4: 5850MHz
–38.3dB
2
Isolation(dB)
–5 1
–10
–15
–20
–25
–30
–35
–40
–45
–50
500
Hi-BAND PORT ATTENUATION
Return loss (dB)
Attenuation (dB)
FREQUENCY CHARACTERISTICS
Lo-BAND PORT ATTENUATION S21
1
S33
1: 800MHz
–0.2dB
4 2: 2170MHz
–1.7dB
3: 2400MHz
–16.5dB
4: 5850MHz
–7.3dB
2
–10
–15
3
–20
5500
–25
–30
1500
2500
3500
4500
Frequency (MHz)
5500
–35
500
1500
2500
3500
4500
Frequency (MHz)
5500
(3/6)
DPX Series DPX201990DT-4114A2
2.0±0.15
5
4
1.25±0.15
6
3
0.3±0.2
0.95±0.1
1
2
0.65±0.2
0.2±0.2 0.35±0.2
Terminal functions
1 GND
2 ANT
3 GND
4 Lo-Band
5 GND
6 Hi-Band
Dimensions in mm
0.7
0.8
0.6
Land pattern
ø0.15 Through-hole(6)
0.35
0.3
Dimensions in mm
Line width be designed to match 50: characteristic impedance
depending on PCB material and thickness.
Item
Insertion loss
Return loss
Attenuation
Port
Lo-band
Hi-band
Lo-band
Hi-band
ANT
Hi-band
Lo-band
Lo-band
Lo-band
[–40 to +85°C]
[–40 to +85°C]
[25°C]
[25°C]
Frequency range
824 to 894MHz
1850 to 1990MHz
824 to 894MHz
1850 to 1990MHz
824 to 894, 1850 to 1990MHz
824 to 894MHz
1850 to 1990MHz
1648 to 1788MHz(AGSM 2f0)
2472 to 2682MHz(AGSM 3f0)
Power capability
Temperature range
Operating
Storage
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(W)
(°C)
(°C)
Minimum value
10.0
19.0
20.0
10.0
28.0
–40
–40
Typical value
Maximum value
0.5
0.55
0.45
0.5
3.0
+85
+85
(4/6)
1: 824.000MHz
–49.54dB
2: 894.000MHz
–31.59dB
3: 1850.000MHz
–0.38dB
6: 1990.000MHz
–0.27dB
34
2
1
1300
2300 3300 4300
Frequency (MHz)
5300
1: 824.000MHz
–16.26dB
2: 894.000MHz
–16.50dB
3: 1850.000MHz
–17.86dB
4: 1990.000MHz
–22.99dB
Return loss(dB)
–5
–10
–15
12
3
–25
4
–30
1300
2300 3300 4300
Frequency (MHz)
Hi-BAND PORT RETURN LOSS
Return loss (dB)
–5
5300
–10
–15
–20
3
–25
4
5300
S23
1: 824.000MHz
–42.79dB
2: 894.000MHz
–30.66dB
3: 1850.000MHz
–33.76dB
4: 1990.000MHz
–29.05dB
4
3
1300
2300 3300 4300
Frequency (MHz)
5300
S33
1: 824.000MHz
–16.14dB
2: 894.000MHz
–16.28dB
3: 1850.000MHz
–0.80dB
4: 1990.000MHz
–0.55dB
34
–10
–15
–20
1: 824.000MHz
–0.29dB
2: 894.000MHz
–0.33dB
3: 1648.000MHz
–17.91dB
4: 1788.000MHz
–33.29dB
5: 1850.000MHz
–31.70dB
6: 1990.000MHz
–28.81dB
7: 2472.000MHz
–33.28dB
8: 2882.000MHz
–38.15dB
1
–5
–30
–35
300
2
1: 824.000MHz
–0.36dB
2: 894.000MHz
–0.42dB
3: 1850.000MHz
–17.78dB
4: 1990.000MHz
–23.65dB
12
–5
–10
–15
–20
–25
–30
–35
–40
–45
–50
300
Lo-PORT RETURN LOSS
S22
Return loss (dB)
–35
300
S31
–5
–10
–15
–20
3
–25
6
–30
5
–35
7
4
–40
8
–45
–50
300
1300 2300 3300 4300
Frequency (MHz)
ISOLATION
S11
–20
Attenuation (dB)
–5
–10
–15
–20
–25
–30
–35
–40
–45
–50
300
Lo-BAND PORT
Attenuation (dB)
Attenuation (dB)
Hi-BAND PORT S21
12
–25
–30
1300
2300 3300 4300
Frequency (MHz)
–35
300
5300
1300
2300 3300 4300
Frequency (MHz)
5300
SMITH CHARTS
S11
S22
S33
S21
S31
(5/6)
For AGSM/PCS Tx/Rx
DPX Series DPX201990DT-4014A2
2.0±0.15
5
0.95±0.1
4
1.25±0.15
6
1
2
0.65±0.2
3
Terminal functions
1 GND
2 ANT
3 GND
4 HIGH
5 GND
6 LOW
0.3±0.2
0.2±0.2 0.35±0.2
Dimensions in mm
0.7
0.8
0.6
Land pattern
ø0.15 Through-hole
0.35
0.3
Dimensions in mm
Item
Insertion loss
Return loss
Attenuation
Port
Lo-band
Hi-band
Lo-band
Hi-band
ANT
Hi-band
Lo-band
Lo-band
Lo-band
[–40 to +85°C]
[–40 to +85°C]
[25°C]
[25°C]
Frequency range
824 to 894MHz
1850 to 1990MHz
824 to 894MHz
1850 to 1990MHz
824 to 894MHz
1850 to 1990MHz
Power capability
Temperature range
Operating
Storage
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(dB)
(W)
(°C)
(°C)
Minimum value
10.0
19.0
20.0
10.0
28.0
–40
–40
Typical value
Maximum value
0.5
0.55
0.45
0.5
3.0
+85
+85
(6/6)
5300
Return loss(dB)
–10
–15
12
–25
3
–30
–35
300
1300
2300 3300 4300
Frequency (MHz)
5300
Return loss (dB)
1: 824.000MHz
–17.31dB
2: 894.000MHz
–17.80dB
3: 1850.000MHz
–0.77dB
4: 1990.000MHz
–0.57dB
34
–10
–15
12
–25
–5
–30
–35
300
–5
–10
–15
–20
–25
–30
–35
–40
–45
–50
300
S31
1: 824.000MHz
–38.76dB
2: 894.000MHz
–2.81dB
3: 1850.000MHz
–0.33dB
4: 1990.000MHz
–0.29dB
34
2
1
1300
2300 3300 4300
Frequency (MHz)
5300
S23
2
4
1
3
1300
1: 824.000MHz
–37.14dB
2: 894.000MHz
–27.80dB
3: 1850.000MHz
–37.54dB
4: 1788.000MHz
–29.13dB
2300 3300 4300
Frequency (MHz)
Hi-PORT RETURN LOSS
S22
–5
–20
Attenuation (dB)
1: 824.000MHz
–17.49dB
2: 894.000MHz
–17.89dB
3: 1850.000MHz
–25.85dB
4: 1990.000MHz
–40.51dB
–5
–5
–10
–15
–20
–25
–30
–35
–40
–45
–50
300
ISOLATION
S11
–20
1: 824.000MHz
–0.29dB
2: 894.000MHz
–0.32dB
3: 1648.000MHz
–14.38dB
4: 1788.000MHz
–29.87dB
5: 1850.000MHz
–32.30dB
6: 1990.000MHz
–28.26dB
Attenuation (dB)
–5
–10
–15
3
–20
–25
6
–30
4
–35
5
–40
–45
–50
300
1300 2300 3300 4300
Frequency (MHz)
Hi-BAND PORT
Return loss (dB)
Attenuation (dB)
Lo-BAND PORT S21
5300
S33
1: 824.000MHz
–0.38dB
2: 894.000MHz
–0.44dB
3: 1850.000MHz
–20.77dB
4: 1990.000MHz
–23.40dB
12
–10
–15
–20
3
–25
4
–30
1300
2300 3300 4300
Frequency (MHz)
–35
300
5300
1300
2300 3300 4300
Frequency (MHz)
5300
SMITH CHARTS
S11
S22
S33
S21
S31
很抱歉,暂时无法提供与“DPX201990DT-4014A2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2000+2.659972000+0.32191
- 国内价格 香港价格
- 1+10.047111+1.21590
- 10+8.8692410+1.07335
- 25+8.0115625+0.96956
- 100+7.01037100+0.84839
- 250+6.15207250+0.74452
- 500+5.43672500+0.65795
- 1000+4.292211000+0.51944
