Jan. 2022 Ver.6.0
TDK Corporation
Multilayer Diplexer
For 698-2170MHz / 2400-5850MHz
DPX Series
P/N:
2.0x1.25mm [EIA 0805] TYPE
DPX205850DT-4054B5
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ SHAPES AND DIMENSIONS
[TopView]
(6)
[BottomView]
(5)
(4)
(W)
(e)
(1)
(2)
(3)
(T)
(L)
[Side View]
(a)
(b) (c) (d)
Dimensions (mm)
L
W
T
a
b
c
d
e
2.00 1.25 0.90 0.65 0.35 0.30 0.20 0.20
+/-0.15 +/-0.15 +/-0.10 +/-0.10 +/-0.20 +/-0.20 +/-0.20 +/-0.20
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
(4)
(5)
(6)
High-Band Port
GND
Low-Band Port
■ TERMINATION FINISH
Material
Sn plate
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
Return Loss@Low-Band (dB)
Attenuation (dB)
Frequency (MHz)
698
1560
1710
1920
1990
698
1560
1710
1920
1990
698
1560
1710
2400
2500
5150
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
960
1610
1920
1990
2170
960
1610
1920
1990
2170
960
1610
2170
2500
2690
5850
Characteristic Impedance (ohm)
Ta = +25+/-5°C
TDK Spec
Min. Typ. Max.
0.23 0.40
0.35 0.50
0.48 0.65
0.53 0.80
0.98 1.30
0.50
0.60
0.80
1.00
1.55
10
16
10
16
10
17
10 15.0
10 12.0
25 36.0
50 (Nominal)
High-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
Return Loss@High-Band (dB)
Attenuation (dB)
Ta = +25+/-5°C
Frequency (MHz)
2400
2500
5150
2400
2500
5150
2400
2500
5150
698
1560
1710
to
to
to
to
to
to
to
to
to
to
to
to
2500
2690
5850
2500
2690
5850
2500
2690
5850
960
1610
2170
TDK Spec
Min. Typ. Max.
1.27 1.70
0.76 1.00
0.27 0.50
2.00
1.20
0.60
10
23
10
17
10
14
18 23.0
15 19.0
12 15.0
50 (Nominal)
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Low-Band
High-Band
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +85 °C
–40 to +85 °C
Frequency (MHz)
CW
1
698 to 2170
CW
1
2400 to 5850
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ FREQUENCY CHARACTERISTICS
S21
High-Band Port Attenuation
2500
2570
2620
2690
5150
5850
5
Attenuation[dB]
10
15
MHz
MHz
MHz
MHz
MHz
MHz
MHz
16.1
15.7
13.0
12.2
11.7
36.5
51.4
dB
dB
dB
dB
dB
dB
dB
25
30
35
S31
10
Attenuation[dB]
Low-Band Port Attenuation
15
30
35
40
40
45
45
50
50
2000
3000
4000
5000
6000
7000
1000
2000
3000
S21
High-Band Port Insertion Loss
698
746
824
894
960
0.5
1
1.5
MHz
MHz
MHz
MHz
MHz
0.18
0.19
0.20
0.22
0.23
dB
dB
dB
dB
dB
2
2.5
600
8000
2400
2500
2570
2620
2690
MHz
MHz
MHz
MHz
MHz
1.27
0.76
0.73
0.73
0.71
dB
dB
dB
dB
dB
S31
0.5
1
1.5
2
2.5
700
800
900
1000
1100
1200
2100
1300
2200
2300
2400
1
1.5
2
2.5
3
1600
1700
1800
1900
2000
2100
2200
1560
1575
1610
1710
1850
1910
1920
1990
2110
2170
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
0.34
0.33
0.35
0.38
0.44
0.48
0.48
0.53
0.68
0.98
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
1
15
30
35
40
45
50
3000
4000
5000
6000
7000
8000
4600
4800
5000
5200
698
746
824
894
960
1560
1575
1610
1710
1850
1910
1920
1990
2110
2170
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
18.5
17.9
17.2
16.6
16.0
16.7
17.0
17.6
19.9
25.3
27.2
27.4
25.4
19.8
17.1
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
15
30
35
40
45
50
3000
4000
5000
Frequency[MHz]
5800
MHz
MHz
MHz
MHz
MHz
MHz
MHz
23.8
25.7
21.1
19.3
16.5
14.7
21.1
dB
dB
dB
dB
dB
dB
dB
698
746
824
894
960
1560
1575
1610
1710
1850
1910
1920
1990
2110
2170
2400
2500
2570
2620
2690
5150
5850
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
22.5
23.0
24.0
25.3
27.2
19.6
19.3
18.5
16.6
15.2
15.0
15.0
15.6
20.9
19.8
19.0
17.1
14.2
13.4
13.0
35.1
45.9
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
6000
S33
5
10
15
30
35
40
45
50
2000
3000
4000
Isolation (Low - High)
10
2000
5600
7000
8000
698
746
824
894
960
1560
1575
1610
1710
1850
1910
1920
1990
2110
2170
2400
2500
2570
2620
2690
5150
5850
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
18.4
18.0
17.2
16.7
16.1
16.1
16.3
16.8
18.4
22.9
26.6
27.5
47.0
22.4
17.9
22.0
34.7
27.8
24.9
22.1
16.1
14.3
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
5000
6000
7000
8000
S23
10
15
Isolation[dB]
S11
5
1000
5400
Frequency[MHz]
2500
2570
2620
5150
5850
2
2.5
Frequency[MHz]
Common Port Return Loss
0.18 dB
0.27 dB
1.5
High-Band Port Return Loss
5
2000
5150 MHz
5850 MHz
3
Return Loss[dB]
S22
10
1000
2800
Frequency[MHz]
0.5
Frequency[MHz]
Low-Band Port Return Loss
2600
Insertion Loss[dB]
1500
2500
Frequency[MHz]
Frequency[MHz]
Insertion Loss[dB]
7000
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
3
3
Return Loss[dB]
6000
22.9
23.4
24.6
26.0
28.0
20.8
20.4
19.5
17.4
15.4
15.0
14.9
15.2
22.2
24.4
Insertion Loss[dB]
Insertion Loss[dB]
Return Loss[dB]
5000
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
Frequency[MHz]
Frequency[MHz]
Low-Band Port Insertion Loss
4000
698
746
824
894
960
1560
1575
1610
1710
1850
1910
1920
1990
2110
2170
30
35
40
45
50
2000
3000
4000
5000
Frequency[MHz]
6000
7000
8000
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ RECOMMENDED LAND PATTERN
Unit[mm]
4
0 45
5
■ EVALUATION BOARD
Material & Layer
Copper Surface Pattern
Teflon
Copper Bottom GND
4
Thickness
0.05 mm
0.35 mm
0.05 mm
unit : mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
TDK Corporation
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
Jan. 2022 Ver.6.0
TDK Corporation
DPX205850DT-4054B5
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
K
Sprocket hole
Loading Direction
E
J
B
B
t
G
H
Dimensions (mm)
A
B
C
1.45 2.25 8.0
+/-0.1
D
3.5
+/-0.1 +/-0.20 +/-0.05
E
1.75
+/-0.1
F
4.0
G
2.0
+/-0.1 +/-0.05
F
Unit : mm
H
4.0
J
1.5
K
1.2
t
0.25
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
C
D
A
RF Components
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
很抱歉,暂时无法提供与“DPX205850DT-4054B5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 600+1.11989
- 3100+1.05865
- 国内价格
- 600+0.88973
- 3100+0.85048
- 国内价格
- 5+1.64841
- 50+1.34039
- 150+1.20842
- 500+1.04382
