The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
August 2016
Multilayer Diplexer
For 1572-1578MHz / 2400-2500MHz
DPX252500DT-5217A1
2.5x2.0mm [EIA 1008]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Diplexer
Conformity to RoHS Directive
DPX252500DT-5217A1
SHAPES AND DIMENSIONS
2.50±0.15
0.90±0.10
2.00±0.15
[Top view]
0.40±0.10
[Bottom view]
0.90±0.15
1
2
3
8
9
4
7
6
5
0.55±0.15
0.30±0.10
Marking
Terminal functions
1 High-band
2 GND
3 Low-band
4 GND
5 GND
6 Common
7 GND
8 GND
9 GND
0.40±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
EVALUATION BOARD
0.55 0.40
0.80
DPX252500DT-5217A1
0.40
0.80
PORT01_Common
PORT03_HIGH
0.80
PORT02_LOW
0.90
2.90
Dimensions in mm
Material, Layer
Top Resist
Copper Surface Pattern
FR-4
Copper Inner GND
FR-4
Copper Bottom GND
Thickness
Resist
0.035mm
0.10mm
0.018mm
0.30mm
0.035mm
Line width should be designed to match 50Ω
characteristic impedance, depending on PCB
material and thickness.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20160825 / rf_dpx_dpx252500dt-5217a1_en.fm
RF Components
DPX252500DT-5217A1
ELECTRICAL CHARACTERISTICS
LOW-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Characteristic Impedance ()
Frequency Range
(MHz)
Min.
Typ.
Max.
1572 to 1578
1572 to 1578
1572 to 1578
2400 to 2500
9.54
25
0.37
23
33
50 (Nominal)
0.60
0.80 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2500
2400 to 2500
2400 to 2500
700 to 960
1572 to 1578
1710 to 1990
2110 to 2170
4800 to 5000
7200 to 7500
9600 to 10000
9.54
35
35
33
25
35
35
25
2.12
22
40
39
37
31
41
54
42
50 (Nominal)
2.70
3.00 (–40 to +85°C)
・Ta: +25±5°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DPX252500DT-5217A1
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
LOW-BAND
Insertion Loss
0.0
1.0
Insertion Loss(dB)
Insertion Loss(dB)
1
1.5
2.0
3
4
2.5
3.0
600
800
1000
1200
1400
Frequency(MHz)
1600
1800
5
2200
2000
10
Return Loss(dB)
40
2500
Frequency(MHz)
2600
2700
2800
2300
2400
2500
Frequency(MHz)
2600
2700
2800
600
800
1000
1200
1400
Frequency(MHz)
1600
1800
50
2200
2000
Attenuation
10
Attenuation(dB)
Attenuation
Attenuation(dB)
2400
40
50
30
40
30
40
50
50
60
60
70
2300
Return Loss
Return Loss
Return Loss(dB)
2
4000
6000
Frequency(MHz)
8000
10000
70
4000
6000
Frequency(MHz)
8000
10000
RF Components
DPX252500DT-5217A1
COMMON
Return Loss
Isolation
10
Isolation(dB)
Return Loss(dB)
30
40
50
40
60
50
4000
6000
Frequency(MHz)
8000
10000
70
4000
6000
Frequency(MHz)
8000
10000
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DPX252500DT-5217A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.69775
- 50+0.57164
- 150+0.50859
- 500+0.46129
- 2000+0.42346
- 4000+0.40455
- 国内价格 香港价格
- 2000+2.961352000+0.35809
