EFS22D67-03
EFS22D67-03
    TDK(东电化)
    表面电势传感器 传感器 输出
EFS22D67-03 数据手册
S E N S O R S December 2023 Surface Potential Sensors EFS series (2/5) S E N S O R S Product compatible with RoHS directive Surface Potential Sensors Overview of the EFS series FEATURES A new feedback surface voltage sensor that supports the improved image quality color copiers and next generation color printers with a reliability of ±0.05V or below. This voltage sensor is constructed using TDK’s unique, high precision, highly stable detection circuit which feeds the detected photosensitive drum surface potential back to the electrical field line control chopper and probe shield cover. While completely eliminating the effects of the causes of disturbances in the electric field intervening between the photosensitive drum and the detection electrode, it shows extremely stable and precise output performance where the adverse effects of temperature fluctuations and detection distance (probe positioning) are greatly reduced. A unique optimized structure and circuit design have achieved the world’s smallest class of miniaturization and weight reduction, as well as greater performance in response to market needs. Extremely stable output performance is maintained for long periods of time through accurate driving made possible with the unique structural design and superelastic alloy chopper consisting of the piezoelectric element with optimized conversion efficiency. Quick responsiveness to high-speed and high image quality needs. APPLICATION Surface potential measurements in photosensitive drums for copiers and paper for PPCs as well as applications for laser beam printers and various equipment. PRODUCT LINEUP ASSEMBLY Power supply voltage Power consumption current Detector voltage range Vcc (V) 24±10% 24±10% Idc (mA) 150max. 150max. Ve (V) –1000 to 0 0 to +1000 Part No. EFS22D67-03 EFS31D57-03  Detector voltage guaranteed accuracy range (V) –900 to 0 0 to +900 Output voltage V0 (V) 0 to 4.5±0.05 0 to 4.5±0.05 Response time Detector distance (ms) 20max. 20max. (mm) 2.0 to 3.0 2.0 to 3.0 Outputs –1/200 of Ve. Outputs 1/200 of Ve.  RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20231211 / sensor_surface-potential_efs_en.fm (3/5) S E N S O R S Assembly・Minus Electric potential detection EFS22D67-03 SHAPE & DIMENSIONS 60 0.5 Probe Lead wire Insulating tube CN2 Surface mounted with parts 40 0.2 Pin No. 4 3 2 1 CN1 6.0 5 50 0.2 50 0.5 6 0.2 5 CN1 S4B-PH-KLC-H(LF)(SN) JST Connector (I/O pins) 670 15 2 1 : GND(Vcc) 2 : GND(SIGNAL) 3 : SIGNAL OUT 4 : Vcc 3.5 max. 50 1 Dimensions in mm ※CN1 connector is reverse type. Please be careful when making connections. 1 Parts domain 18 max. 6 0.2 4- 4 ELECTRICAL CHARACTERISTICS Power supply voltage Power consumption current Detector voltage range Vcc (V) 24±10% Idc (mA) 150max. Ve (V) –1000 to 0 Part No. EFS22D67-03  Detector voltage guaranteed accuracy range Output voltage V0 (V) 0 to 4.5±0.05 (V) –900 to 0 Response time Detector distance (ms) 20max. (mm) 2.0 to 3.0 Outputs –1/200 of Ve. OUTPUT VOLTAGE VS. DETECTOR VOLTAGE MEASURING CIRCUIT CHARACTERISTICS (TYPICAL) High voltage DC power supply Electrode 5.0 Probe Pin No. 1 2 3 4 Fixed block CN1 Output voltage(V) Detector distance: 2.5mm Fixed substrate 4.0 10kΩ 3.0 Output Vcc Edc 24V 2.0 A 10kΩ Multi-meter or Oscilloscope DC power supply ※CN1 connector is reverse type. Please be careful when making connections. 1.0 0.0 0 -200 -400 -600 -800 Detector voltage(V) -1000 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20231211 / sensor_surface-potential_efs_en.fm (4/5) S E N S O R S Assembly・Plus Electric potential detection EFS31D57-03 SHAPE & DIMENSIONS 70 0.5 5 5 60 0.2 Probe Lead wire Insulating tube CN2 50 0.2 6.0 Surface mounted with parts 60 0.5 6 0.2 CN1 575 15 2 CN1 DF1BZ-4P-2.5DSA HRS Connector (I/O pins) 3.5 max. 50 1 1 : Vcc 2 : SIGNAL OUT 3 : GND(SIGNAL) 4 : GND( Vcc) 1 Parts domain 18 max. 6 0.2 4- 4 Dimensions in mm ELECTRICAL CHARACTERISTICS Power supply voltage Power consumption current Detector voltage range Vcc (V) 24±10% Idc (mA) 150max. Ve (V) 0 to +1000 Part No. EFS31D57-03  Detector voltage guaranteed accuracy range Output voltage V0 (V) 0 to 4.5±0.05 (V) 0 to +900 Response time Detector distance (ms) 20max. (mm) 2.0 to 3.0 Outputs 1/200 of Ve. OUTPUT VOLTAGE VS. DETECTOR VOLTAGE MEASURING CIRCUIT CHARACTERISTICS (TYPICAL) High voltage DC power supply Electrode 5.0 Probe Pin No. 4 3 2 1 Fixed block CN1 Output voltage(V) Detector distance: 2.5mm Fixed substrate 4.0 10kΩ 3.0 Output Vcc Edc 24V 2.0 A 10kΩ Multi-meter or Oscilloscope DC power supply 1.0 0.0 0 200 400 600 800 Detector voltage(V) 1000 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20231211 / sensor_surface-potential_efs_en.fm (5/5) S E N S O R S EFS series Handling Precautions Please request a delivery specification form containing more detailed information on characteristics and specifications so as to ensure correct and safe use of the products. [Storage Environment] Check the standards concerning the storage conditions described in the delivery specifications of the products, and store them in accordance with the standards. [Usage Environment/Operating Conditions] As for usage environment conditions and operating conditions of the products, check the standards concerning the usage environment conditions and operating conditions described in the delivery specifications, and use the products in accordance with the standards. [Handling] The voltage in the circuit board and probe is high during operation. Take sufficient care to avoid electrical shock. Do not change the settings of the variable resistance mounted on the circuit board. Do not apply excessive mechanical shock such as dropping to the products. The circuit board and probe are adjusted at a 1:1 ratio. Do not change the configuration that it comes in. Other Requests/Notices We do not assume any responsibility for any damage caused by the use of our products exceeding the scope or conditions defined in the delivery specifications. Specifications of the products in this catalog are subject to change without notice due to improvements or other reasons. In addition, supply of the products may be cancelled without notice. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20231211 / sensor_surface-potential_efs_en.fm
EFS22D67-03 价格&库存
很抱歉,暂时无法提供与“EFS22D67-03”相匹配的价格&库存,您可以联系我们找货
