Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
book, halfpage
M3D109
PBSS4350X
50 V, 3 A
NPN low VCEsat (BISS) transistor
Product specification
Supersedes data of 2003 Nov 21
2004 Nov 04
50 V, 3 A
PBSS4350X
FEATURES
QUICK REFERENCE DATA
• SOT89 (SC-62) package
SYMBOL
• Low collector-emitter saturation voltage VCEsat
VCEO
collector-emitter voltage
50
V
IC
collector current (DC)
3
A
• Higher efficiency leading to less heat generation
ICM
peak collector current
5
A
• Reduced printed-circuit board requirements.
RCEsat
equivalent on-resistance
130
• High collector current capability: IC and ICM
PARAMETER
MAX. UNIT
PINNING
APPLICATIONS
• Power management
PIN
DESCRIPTION
– DC/DC converters
1
emitter
– Supply line switching
2
collector
– Battery charger
3
base
– LCD backlighting.
• Peripheral drivers
– Driver in low supply voltage applications (e.g. lamps
and LEDs).
– Inductive load driver (e.g. relays,
buzzers and motors).
2
3
DESCRIPTION
1
NPN low VCEsat transistor in a SOT89 plastic package.
PNP complement: PBSS5350X.
sym042
3
2
1
MARKING
TYPE NUMBER
PBSS4350X
2004 Nov 04
MARKING CODE
Fig.1 Simplified outline (SOT89) and symbol.
S43
2
mΩ
50 V, 3 A
PBSS4350X
ORDERING INFORMATION
PACKAGE
TYPE NUMBER
NAME
PBSS4350X
SC-62
DESCRIPTION
VERSION
plastic surface mounted package; collector pad for good heat
transfer; 3 leads
SOT89
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
VCBO
collector-base voltage
open emitter
50
V
VCEO
open base
50
V
VEBO
emitter-base voltage
open collector
5
V
IC
note 4
3
A
ICM
limited by Tj(max)
5
A
IB
base current (DC)
0.5
A
Ptot
total power dissipation
note 1
550
mW
note 2
1
W
note 3
1.4
W
note 4
1.6
W
+150
°C
Tamb ≤ 25 °C
Tstg
storage temperature
−65
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Notes
1. Device mounted on a FR4 printed-circuit board; single-sided copper; tin-plated; standard footprint.
2. Device mounted on a FR4 printed-circuit board; single-sided copper; tin-plated; mounting pad for collector 1 cm2.
3. Device mounted on a FR4 printed-circuit board; single-sided copper; tin-plated; mounting pad for collector 6 cm2.
4. Device mounted on a ceramic printed-circuit board 7 cm2, single-sided copper, tin-plated.
2004 Nov 04
3
50 V, 3 A
PBSS4350X
MLE186
2
handbook, halfpage
Ptot
(W)
(1)
1.6
(2)
1.2
(3)
0.8
(4)
0.4
(1) Ceramic PCB; 7 cm2
mounting pad for collector.
(2) FR4 PCB; 6 cm2 copper
80
120
160
Tamb (°C)
(3) FR4 PCB; 1 cm2 copper
(4) Standard footprint.
Fig.2 Power derating curves.
2004 Nov 04
4
50 V, 3 A
PBSS4350X
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
Rth(j-a)
CONDITIONS
thermal resistance from junction to ambient
Rth(j-s)
VALUE
UNIT
note 1
225
K/W
note 2
125
K/W
note 3
90
K/W
note 4
80
K/W
16
K/W
in free air
thermal resistance from junction to soldering point
Notes
006aaa243
103
Zth
(K/W)
102
(1)
(2)
(3)
(4)
(5)
(6)
10
(7)
(8)
(9)
1
(10)
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; standard footprint.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.3 Transient thermal impedance as a function of pulse time; typical values.
2004 Nov 04
5
50 V, 3 A
PBSS4350X
006aaa244
103
Zth
(K/W)
102
(1)
(2)
(3)
(5)
(4)
(6)
10
(7)
(8)
(9)
1
(10)
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; mounting pad for collector 1 cm2.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.4 Transient thermal impedance as a function of pulse time; typical values.
006aaa245
103
Zth
(K/W)
102
(1)
(2)
(3)
(5)
10
(4)
(6)
(7)
(8)
(9)
1
(10)
10−1
10−5
10−4
10−3
10−2
10−1
1
10
102
103
tp (s)
Mounted on FR4 printed-circuit board; mounting pad for collector 6 cm2.
(1) δ = 1.
(2) δ = 0.75.
(3) δ = 0.5.
(4) δ = 0.33.
(5) δ = 0.2.
(6) δ = 0.1.
(7) δ = 0.05.
(8) δ = 0.02.
(9) δ = 0.01.
(10) δ = 0.
Fig.5 Transient thermal impedance as a function of pulse time; typical values.
2004 Nov 04
6
50 V, 3 A
PBSS4350X
CHARACTERISTICS
Tamb = 25 °C unless otherwise specified.
SYMBOL
ICBO
PARAMETER
collector-base cut-off current
CONDITIONS
MIN.
TYP.
MAX.
UNIT
VCB = 50 V; IE = 0 A
100
nA
VCB = 50 V; IE = 0 A; Tj = 150 °C
50
µA
ICES
collector-emitter cut-off current
VCE = 50 V; VBE = 0 V
100
nA
IEBO
emitter-base cut-off current
VEB = 5 V; IC = 0 A
100
nA
hFE
DC current gain
VCE = 2 V
IC = 0.1 A
300
IC = 0.5 A
300
IC = 1 A; note 1
300
700
IC = 2 A; note 1
200
100
IC = 0.5 A; IB = 50 mA
80
mV
IC = 1 A; IB = 50 mA
160
mV
IC = 2 A; IB = 100 mA
280
mV
IC = 2 A; IB = 200 mA; note 1
260
mV
IC = 3 A; IB = 300 mA; note 1
370
mV
IC = 3 A; note 1
VCEsat
voltage
RCEsat
100
130
mΩ
VBEsat
base-emitter saturation voltage
1.1
V
1.2
V
1.1
V
VBEon
base-emitter turn-on voltage
VCE = 2 V; IC = 1 A
fT
transition frequency
IC = 100 mA; VCE = 5 V; f = 100 MHz
100
MHz
Cc
collector capacitance
VCB = 10 V; IE = ie = 0 A; f = 1 MHz
25
pF
Note
1. Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
2004 Nov 04
7
50 V, 3 A
PBSS4350X
MLE181
800
MLE180
1.2
handbook, halfpage
handbook, halfpage
hFE
VBE
(1)
(V)
600
(1)
0.8
(2)
(2)
400
(3)
(3)
0.4
200
10−1
1
102
10
10−1
103
104
IC (mA)
1
VCE = 2 V.
(1) Tamb = 100 °C.
(2) Tamb = 25 °C.
(3) Tamb = −55 °C.
VCE = 2 V.
(1) Tamb = −55 °C.
(2) Tamb = 25 °C.
(3) Tamb = 100 °C.
Fig.6
Fig.7
DC current gain as a function of collector
current; typical values.
MLE183
1
10
102
Base-emitter voltage as a function of
collector current; typical values.
MLE184
1
handbook, halfpage
103
104
IC (mA)
handbook, halfpage
VCEsat
VCEsat
(V)
(V)
10−1
10−1
(1)
(1)
(2)
(2)
(3)
10−2
10−3
10−1
1
10
102
10−2
(3)
10−3
10−1
103
104
IC (mA)
IC/IB = 20.
(1) Tamb = 100 °C.
(2) Tamb = 25 °C.
(3) Tamb = −55 °C.
Tamb = 25 °C.
(1) IC/IB = 100.
(2) IC/IB = 50.
(3) IC/IB = 10.
Fig.8
Fig.9
Collector-emitter saturation voltage as a
function of collector current; typical values.
2004 Nov 04
8
1
10
102
103
104
IC (mA)
50 V, 3 A
PBSS4350X
MLE185
1.4
MLE182
103
handbook, halfpage
handbook, halfpage
RCEsat
(Ω)
VBEsat
102
(V)
1
(1)
10
(2)
1
(3)
0.6
(1)
10−1
0.2
10−1
1
10
102
(2)
10−2 −1
10
103
104
IC (mA)
IC/IB = 20.
1
102
10
(3)
103
104
IC (mA)
IC/IB = 20.
(1) Tamb = −55 °C.
(2) Tamb = 25 °C.
(3) Tamb = 100 °C.
(1) Tamb = 150 °C.
Fig.10 Base-emitter saturation voltage as a
MLE179
5
handbook, halfpage
handbook, halfpage
IC
(1)
(mA)
(2)
(6)
(5)
(4)
(3)
(2)
(1)
IC
(A)
4
(3)
800
(3) Tamb = −55 °C.
Fig.11 Equivalent on-resistance as a function of
MLE178
1200
(2) Tamb = 25 °C.
(7)
(4)
(8)
3
(5)
(9)
(6)
(10)
(7)
400
2
(8)
(9)
1
(10)
0.8
1.2
1.6
2
VCE (V)
Tamb = 25 °C.
(1)
(2)
(3)
(4)
IB = 2600 µA.
IB = 2340 µA.
IB = 2080 µA.
IB = 1820 µA.
1.2
1.6
2
VCE (V)
Tamb = 25 °C.
(5)
(6)
(7)
(8)
IB = 1560 µA.
IB = 1300 µA.
IB = 1040 µA.
IB = 780 µA.
(9) IB = 520 µA.
(10) IB = 260 µA.
(1)
(2)
(3)
(4)
Fig.12 Collector current as a function of
collector-emitter voltage; typical values.
2004 Nov 04
0.8
0.4
IB = 120 mA.
IB = 108 mA.
IB = 96 mA.
IB = 84 mA.
(5)
(6)
(7)
(8)
IB = 72 mA.
IB = 60 mA.
IB = 48 mA.
IB = 36 mA.
(9) IB = 24 mA.
(10) IB = 12 mA.
Fig.13 Collector current as a function of
9
50 V, 3 A
PBSS4350X
PACKAGE OUTLINE
Plastic surface mounted package; collector pad for good heat transfer; 3 leads
SOT89
B
D
A
bp3
E
HE
Lp
1
2
3
c
bp2
w M
bp1
e1
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
bp1
bp2
bp3
c
D
E
e
e1
HE
Lp
w
mm
1.6
1.4
0.48
0.35
0.53
0.40
1.8
1.4
0.44
0.23
4.6
4.4
2.6
2.4
3.0
1.5
4.25
3.75
1.2
0.8
0.13
OUTLINE
VERSION
SOT89
2004 Nov 04
REFERENCES
IEC
JEDEC
JEITA
TO-243
SC-62
10
EUROPEAN
PROJECTION
ISSUE DATE
99-09-13
04-08-03
50 V, 3 A
PBSS4350X
DATA SHEET STATUS
LEVEL
DATA SHEET
STATUS(1)
PRODUCT
STATUS(2)(3)
Development
DEFINITION
I
Objective data
II
Preliminary data Qualification
This data sheet contains data from the preliminary specification.
Supplementary data will be published at a later date. Philips
Semiconductors reserves the right to change the specification without
notice, in order to improve the design and supply the best possible
product.
III
Product data
This data sheet contains data from the product specification. Philips
Semiconductors reserves the right to make changes at any time in order
to improve the design, manufacturing and supply. Relevant changes will
be communicated via a Customer Product/Process Change Notification
(CPCN).
Production
This data sheet contains data from the objective specification for product
development. Philips Semiconductors reserves the right to change the
specification in any manner without notice.
Notes
1. Please consult the most recently issued data sheet before initiating or completing a design.
2. The product status of the device(s) described in this data sheet may have changed since this data sheet was
published. The latest information is available on the Internet at URL http://www.semiconductors.philips.com.
3. For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status.
DEFINITIONS
DISCLAIMERS
Short-form specification The data in a short-form
specification is extracted from a full data sheet with the
same type number and title. For detailed information see
the relevant data sheet or data handbook.
Life support applications These products are not
designed for use in life support appliances, devices, or
systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips
Semiconductors customers using or selling these products
for use in such applications do so at their own risk and
agree to fully indemnify Philips Semiconductors for any
damages resulting from such application.
Limiting values definition Limiting values given are in
(IEC 60134). Stress above one or more of the limiting
values may cause permanent damage to the device.
These are stress ratings only and operation of the device
at these or at any other conditions above those given in the
Characteristics sections of the specification is not implied.
Exposure to limiting values for extended periods may
affect device reliability.
Right to make changes Philips Semiconductors
reserves the right to make changes in the products including circuits, standard cells, and/or software described or contained herein in order to improve design
and/or performance. When the product is in full production
(status ‘Production’), relevant changes will be
Notification (CPCN). Philips Semiconductors assumes no
responsibility or liability for the use of any of these
products, conveys no licence or title under any patent,
copyright, or mask work right to these products, and
makes no representations or warranties that these
products are free from patent, copyright, or mask work
right infringement, unless otherwise specified.
Application information Applications that are
described herein for any of these products are for
illustrative purposes only. Philips Semiconductors make
no representation or warranty that such applications will be
suitable for the specified use without further testing or
modification.
2004 Nov 04
11
Philips Semiconductors – a worldwide company
Contact information
For additional information please visit http://www.semiconductors.philips.com.
Fax: +31 40 27 24825
For sales offices addresses send e-mail to: sales.addresses@www.semiconductors.philips.com.
SCA76
© Koninklijke Philips Electronics N.V. 2004
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R75/03/pp12
Date of release: 2004
Nov 04
Document order number:
9397 750 13883
