L08P100D15M1
L08P100D15M1
    TAMURA
    Current Sensor 100A 1 Channel Hall Effect, Open Loop Bidirectional Module, Single Pass Through
L08P100D15M1 数据手册
Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L08P***D15 Series Features: Advantage:            Open Loop type Printed circuit board mounting 5 pin PCB connection Bipolar power supply Insulated plastic case according to UL94V0 Excellent accuracy Very good linearity Low temperature drift No insertion loss High Immunity To External Interference Current overload capability Specifications TA=25ºC, VCC=±15V, RL=10kΩ Parameters Symbol L08P050D15 L08P100D15 L08P150D15 L08P200D15 If 50AT 100AT 150AT 200AT Ifmax ≥ ±150AT ≥ ±300AT ≥ ±450AT ≥ ±450AT Primary nominal current Saturation current Rated output voltage Vo 4V ±0.040V (at If) Offset voltage1 Vof ≤ ±0.030V (at If = 0A) Output Linearity2(0A~If) εL ≤ ±1% (at If) Power supply voltage VCC ±15V±5% Consumption current Icc 12mA typ. tr ≤10μs (at di/dt = 100A / μs) Response time3 Thermal drift of gain4 TcVo ≤ ±0.1% / ºC ≤ ±0.05% / ºC Thermal drift of offset TcVof ≤ ±2mV / ºC ≤ ±1mV / ºC VOH ≤ 30mV ≤ 20mV Hysteresis error(at If=0A→If→0A) Insulation voltage Vd AC2500V for 1minute (sensing current 0.5mA), inside of through hole  terminal Insulation resistance RIS ≥ 500MΩ (at DC500V), inside of through hole  terminal Ambient operation temperature TA -10ºC~+80ºC -20ºC~+85ºC TS Ambient storage temperature 1 2 3 After removal of core hysteresis— Without offset — Time between 10% input current full scale and 90% of sensor output full scale — Thermal drift of offset 4 Without Electrical Performances Frequency characteristic(L08P0200D15) 6 2 Output voltage (V) Attenuation (dB) 4 0 -2 -4 -6 -8 -10 0.1 1 10 Frequency characteristic(kHz) @ If=25AT(Arms) L08PXXXD15revC, March 2012 100 12 10 8 6 4 2 0 -2 -4 -6 -8 -10 -12 -800 Saturation characteristic(L08P0200D15) TA=25ºC Pulsed -600 -400 -200 0 200 Input current (A) Tamura reserve the right to modify its products in order to improve them without prior notice 400 600 800 Issued by Module Components Div, TAMURA CORPORATION Hall Effect Current Sensors L08P***D15 Series Mechanical dimensions in mm 10 D15 Lot No 2.5 7 11 6 L08 19 39 4.5 R1 NOTES 1. Unit is mm 2. Tolerance is 0.5mm 34 φ1 6 6 10 1.5 19.5 10 2.5 5 - φ1.2 φ2 Terminal number 3.5 3.5 6 2 - φ2.5 6 5 - □0.64 24.5 19 Circuit board hole dimension (View of solder side) Terminal number: 1. +VCC(+15V) 2. -VCC(-15V) 3. VOUT 4. GND 5. NC(No connection) Electrical connection diagram VOUT -VCC +VCC -If GND +If Package & Weight Information L08PXXXD15revC, March 2012 Weight Pcs/box Pcs/carton Pcs/pallet 20g 50 500 9000 Tamura reserve the right to modify its products in order to improve them without prior notice
L08P100D15M1 价格&库存
很抱歉,暂时无法提供与“L08P100D15M1”相匹配的价格&库存,您可以联系我们找货
