Issued by Module Components Div, TAMURA CORPORATION
Hall Effect Current Sensors L08P***D15 Series
Features:
Advantage:
Open Loop type
Printed circuit board mounting
5 pin PCB connection
Bipolar power supply
Insulated plastic case according
to UL94V0
Excellent accuracy
Very good linearity
Low temperature drift
No insertion loss
High Immunity To External Interference
Current overload capability
Specifications
TA=25ºC, VCC=±15V, RL=10kΩ
Parameters
Symbol
L08P050D15
L08P100D15
L08P150D15
L08P200D15
If
50AT
100AT
150AT
200AT
Ifmax
≥ ±150AT
≥ ±300AT
≥ ±450AT
≥ ±450AT
Primary nominal current
Saturation current
Rated output voltage
Vo
4V ±0.040V (at If)
Offset voltage1
Vof
≤ ±0.030V (at If = 0A)
Output Linearity2(0A~If)
εL
≤ ±1% (at If)
Power supply voltage
VCC
±15V±5%
Consumption current
Icc
12mA typ.
tr
≤10μs (at di/dt = 100A / μs)
Response time3
Thermal drift of gain4
TcVo
≤ ±0.1% / ºC
≤ ±0.05% / ºC
Thermal drift of offset
TcVof
≤ ±2mV / ºC
≤ ±1mV / ºC
VOH
≤ 30mV
≤ 20mV
Hysteresis error(at If=0A→If→0A)
Insulation voltage
Vd
AC2500V for 1minute (sensing current 0.5mA), inside of through hole terminal
Insulation resistance
RIS
≥ 500MΩ (at DC500V), inside of through hole terminal
Ambient operation temperature
TA
-10ºC~+80ºC
-20ºC~+85ºC
TS
Ambient storage temperature
1
2
3
After removal of core hysteresis— Without offset — Time between 10% input current full scale and 90% of sensor output full scale —
4
Without
Electrical Performances
Frequency characteristic(L08P0200D15)
6
2
Output voltage (V)
Attenuation (dB)
4
-4
-6
-8
-10
0.1
1
10
Frequency characteristic(kHz)
@ If=25AT(Arms)
L08PXXXD15revC, March 2012
100
12
10
8
6
4
2
-4
-6
-8
-10
-12
-800
Saturation characteristic(L08P0200D15)
TA=25ºC Pulsed
-600
-400
-200
Input current (A)
Tamura reserve the right to modify its products in order to improve them without prior notice
400
600
800
Mechanical dimensions in mm
10
D15
Lot No
2.5
7
11
6
L08
19
39
4.5
R1
NOTES
1. Unit is mm
2. Tolerance is 0.5mm
34
φ1
6
6
10
1.5
19.5
10
2.5
5 - φ1.2
φ2
Terminal number
3.5
3.5
6
2 - φ2.5
6
5 - □0.64
24.5
19
Circuit board hole dimension
(View of solder side)
Terminal number:
1. +VCC(+15V)
2. -VCC(-15V)
3. VOUT
4. GND
5. NC(No connection)
Electrical connection diagram
VOUT
-VCC
+VCC -If
GND
+If
Package & Weight Information
Weight
Pcs/box
Pcs/carton
Pcs/pallet
20g
50
500
9000
很抱歉,暂时无法提供与“L08P100D15”相匹配的价格&库存,您可以联系我们找货
