26506-ELV
26506-ELV
    AVENTOOLS(艾文)
    LAMP MAG 3 DIOPTER 115V 78 LEDS
26506-ELV 数据手册
Maxi-Vue Magnifying Lamp ESD Safe Ideal for viewing small parts The Maxi-Vue magnifying lamp is designed for precise inspection of parts in research and development, quality control and production where attention to detail is vital. The 6.25 x 4.25 inch, 3-diopter magnifying lens tilts independently of the light source for precise positioning. The 24 white LED lights on either side (total 48) provide shadowless illumination and are rated for over 20,000 hours of normal use. The 30 UV lights, operating at 395-400 nm, allow you to detect fluoresces in adhesives, laminates and conformal coating; forgery analysis; currency verification; gemstones and mineral inspection; and much more. MAXI-VUE MAGNIFYING LAMP ESD SAFE MAGNIFICATION LENS DIAMETER ADJUSTABLE ARM LENGTH COLOR LIGHTING 1.75X (3-Diopter) 6.25 x 4.25 Inches 32 Inches Black 48SMD LEDs (24 per side) 30 UV SMD LEDs (operating at 395-400 nm) The housing is mounted to an internal spring balanced arm with a 32 inch reach that will set in any LED LIFE Minimum 20,000 hours position. Unit operates at 115-240 VAC and comes complete with mounting clamp and a 5 fout WEIGHT 10 LB power cord and 1 year warranty. Features Part # Description • Magnifying lens tilts independently of light source for precise positioning 26506-ELV Maxi-Vue Magnifying Lamp ESD Safe • 3 diopter crystal clear magnifying glass • 32” spring balanced arm stays put in any position • 48 SMD white LEDs for shadowless illumination • LEDs rated for over 20,000 hours of use • 30 UV SMD LEDs operating at 395-400 nm • ESD Safe sales@aveninc.com aveninc.com 734.973.0099
26506-ELV 价格&库存
很抱歉,暂时无法提供与“26506-ELV”相匹配的价格&库存,您可以联系我们找货
