MBR30100CT
MBR30100CT
    SMCDIODESOLUTIONS(桑德斯)
    TO-220-3
    DIODE ARRAY SCHOTTKY 100V TO220
MBR30100CT 数据手册
MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products MBR30100CT /MBRB30100CT /MBR30100CT-1 SCHOTTKY RECTIFIER Applications: • • • • Switching power supply Converters Free-Wheeling diodes Reverse battery protection Features: • • • • • • • • • 150 °C TJ operation Center tap configuration Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request MBR30100CT TO-220AB Case styles MBRB30100CT D2PAK MBR30100CT-1 TO-262 Mechanical Dimensions: In Inches / mm TO-220AB • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Symbol A A1 A2 b b1 c c1 D D1 E E1 E2 e H L L1 L2 L3 e e1 e2 e3 Dimensions in millimeters Min. Typical Max. 4.55 0 2.59 0.71 0.36 1.17 8.55 6.40 10.01 7.6 9.98 14.6 2.00 1.17 0 4.70 0.10 2.69 0.81 1.27 0.38 1.27 8.70 0.61 1.37 8.85 10.16 10.31 10.08 2.54 15.1 2.30 1.27 10.18 0.25BSC 5° 4° 4° D2PAK TO-262 • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • 4.85 0.25 2.89 0.96 15.6 2.70 1.40 2.20 8° MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Marking Diagram: Where XXXXX is YYWWL MBR B 30 100 CT/CT-1 SSG YY WW L MBR30100CT = Device Type = Package type = Forward Current (30A) = Reverse Voltage (100V) = Configuration = SSG = Year = Week = Lot Number MBRB30100CT Cautions:Molding resin Epoxy resin UL:94V-0 Ordering Information: Device Package TO-220AB (Pb-Free) D²PAK (Pb-Free) MBR30100CT MBRB30100CT Shipping 50pcs / tube 800pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our Tape and Reel Packaging Specification. Maximum Ratings: Characteristics Peak Inverse Voltage Average Forward Current(per device) Peak Repetitive Forward Current(per leg) Peak One Cycle NonRepetitive Surge Current (per leg) Symbol VRWM IF(AV) IFRM IFSM Condition 50% duty cycle @TC = 133°C, rectangular wave form Rated VR square wave, 20KHz TC = 133°C Max. 100 30 Units V A 20 A 8.3 ms, half Sine pulse 200 A • China - Germany - Korea - Singapore - United States • • http://www.smc-diodes.com - sales@ smc-diodes.com • MBR30100CT MBRB30100CT MBR30100CT-1 Technical Data Data Sheet N0039, Rev. B Green Products Electrical Characteristics: Characteristics Forward Voltage Drop (per leg) * Symbol VF1 VF2 Reverse Current (per leg) * IR1 IR2 Junction Capacitance (per leg) Max. Voltage Rate of Change * CT dv/dt Condition @ 15 A, Pulse, TJ = 25 °C @ 30 A, Pulse, TJ = 25 °C @ 15 A, Pulse, TJ = 125 °C @ 30 A, Pulse, TJ = 125 °C @VR = rated VR TJ = 25 °C @VR = rated VR TJ = 125 °C @VR = 5V, TC = 25 °C fSIG = 1MHz - Max. 0.85 1.05 0.70 0.85 1.00 Units V 15.0 mA 500 pF 10,000 V/μs Specification -55 to +150 -55 to +150 2.0 Units °C °C 50 °C/W 0.50 °C/W V mA Pulse Width < 300µs, Duty Cycle
MBR30100CT 价格&库存
很抱歉,暂时无法提供与“MBR30100CT”相匹配的价格&库存,您可以联系我们找货
