MBR3020CT
THRU MBR30200CT
30.0 AMP SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 200 Volts
CURRENT
30.0 Amperes
FEATURES
* Low forward voltage drop
* High current capability
* High reliability
* High surge current capability
* Good for switching mode application
TO-220AB
.412
(10.5)
MAX.
.108
(2.75)
3.8 f +.2
HOLE THRU
.248
(6.3)
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Lead: Lead solderable per MIL-STD-202,
method 208 guranteed
* Polarity: As Marked
* Mounting position: Any
.180
(4.6)
.050
(1.27)
.595
(15.1)
MAX.
.550
(14.0)
.158
(4.0) MIN.
MAX.
.051 MAX.
(1.3)
.040 MAX.
(1.0)
.100
(2.54)
.120
(3.05)
PIN 1
PIN 3
CASE
PIN 2
Positive CT
Suffix "C"
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
MBR3020CT MBR3045CT MBR3060CT MBR3080CT MBR30100CTMBR30150CT MBR30200CT UNITS
32
45
60
42
60
80
56
80
at Rated DC Blocking Voltage
Ta=100 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JC (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
150
105
150
200
140
200
0.55
250
0.85
0.2
0.7
50
570
2.5
-65 +150
-65
+150
V
V
V
A
30
at Tc=125 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 30A
Maximum DC Reverse Current
Ta=25 C
100
70
100
0.92
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Case.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (MBR3020CT THRU MBR30200CT)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
CT
30
45
25
60
80
100
120
140
160
180
200
CASE TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
-M
MB
R3
02
00
C
T
BR
30
10
0C
T
-M
T
T
0C
06
0C
R3
02
MB
R3
TR3
01
50
C
8.0
MB
R3
08
0C
T
5
MB
10
30
MB
15
BR
50
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
30
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
250
.01
200
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
8.3ms Single Half
Tj=25 C
Sine Wave
100
JEDEC method
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
1400
1200
1000
800
600
400
10
Tj=100 C
1.0
Tj=75 C
.1
Tj=25 C
200
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“MBR30100CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.57543
- 30+1.52110
- 100+1.41245
- 500+1.30380
- 1000+1.24948
