ROTARY SELECTORSS-10
SWITCHES
構造図
RoHS compliant
SS-10/S-2050
INTERNAL STRUCTURE
1
SS-10 series
7
2
6
3
5
Part name
4
Material
Flammability
■ FEATURES
①
Rotor
● RoHS compliant
● Compact-size DIP pin configuration
● Protected against dust and washable after soldering
● Self-cleaning mechanism
②
“O” ring
③
Base
④
Terminal pin
⑤
Contact
Copper alloy, Gold-plated
⑥
P.C.B.
Gold-plated epoxy board
⑦
Housing
Polybutyleneterephthalate
Polyoxymethylene
Silicone rubber
UL94HB
UL94HB
■ PART NUMBER DESIGNATION
SS-10 - 1 6 S P - L - A E W
Series name
Form of packaging
W:Tray packaging
Blank:Plastic bag
No. of poles
1:1 pole
2:2 poles
Terminal pin
No. of contacts
E:Au (Lead-free)
3:3 contacts (2 poles only)
5:5 contacts (1 pole only)
6:6 contacts (1 pole only)
Schematic ※ 1
Contact timing
A:Without OFF position
Blank:With OFF position
N:Non-shorting (1pole 6 contacts with OFF, 2 poles 3 contacts)
S:Shorting (1 pole 5 contacts, 1 pole 6 contacts without OFF)
Shape of rotor
L:With knob (extended shaft)
Blank:Without knob
Setting position
P:Top setting
※ 1:The designation for schematic is only aplicable to SS-10-16 □□ .
The other partnumbers (ex. S-2050, SS-10-15SPEW) are without OFF position.
※ Please refer to the LIST OF PART NUMBERS when placing orders.
SS-10/S-2050
ROTARY SELECTOR SWITCHES
■ LIST OF PART NUMBERS
Circuit type
Shape
With knob
1 pole 4 contacts
Without knob
Side
setting
With knob
Without knob
1 pole 5 contacts
With knob
Without knob
With OFF
With knob
Top
setting
1 pole
6 contacts
Non-shorting
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Tray packaging
Plastic bag
Without knob
Top
setting
Contact timing
Form of packaging
Without knob
Without OFF
With knob
Without knob
2 poles 3 contacts
With knob
Pieces in package
Shorting
S-2050W
S-2050
S-2150W
S-2150
S-2051W
S-2051
S-2151W
S-2151
SS-10-15SP-EW
SS-10-15S-PE
SS-10-15SP-L-EW
SS-10-15SP-L-E
SS-10-16NP-EW
SS-10-16NP-E
SS-10-16NP-L-EW
SS-10-16NP-L-E
SS-10-16SP-AEW
SS-10-16SP-AE
SS-10-16SP-L-AEW
SS-10-16SP-L-AE
SS-10-23NP-EW
SS-10-23NP-E
SS-10-23NP-L-EW
SS-10-23NP-L-E
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
50 pcs./tray
25 pcs./pack
: Not manufactured
※ Verify the above part numbers when placing orders.
Tray version can be supplied only in tray nuits.
■ SCHEMATIC DIAGRAMS
1
ON
1 1
1
1
1
1
6
C
C
SS-10-16SP-AE
SS-10-16SP-L-AE
C
C
1
C
ON 1
C
1
ON
ON
C
C
C
2
3
1
1
2
2
3
3
1
3
Schematic
2 3 4
1
2
C
ON
5
C
C
C
C
31
1
42
2
53
3
64
4
5
5
6
6
C
Switching specifications
2 3 4
2
3
1
6
ON
ON
1
1
2 3 4
C
1
C
1
ON
ON C
● 1 pole 6 contacts (Without OFF)
Series
1
5
6 6
5 5
ON
C
1
(OFF)
2
(OFF)
C
C
1
C
1
6
6
C
C
1
5
2
C
C
1
1
5
C
C
4
C
3
SS-10-23NP-L-E
1
C
SS-10-16NP-E
5
1
C
5
Schematic(OFF)
C
4
ON
ON
2 3 4
2 3 4
2 3 4
1
C
1
1
1
C
C
1
1
1
1
C
1
ON ON
● 1 pole 6 contacts (With OFF)
SS-10-16NP-L-E
1
4
ON
Series
C
3
2
3
1
4
2
SS-10-23NP-E
5
3
3
1
4
C
2
3
C
C
C
1
Schematic
2
2
3
3
C
1
C
5
C
5
S-2151
2
1
SS-10-15SP-E
3
2
4
SS-10-15SP-L-E
3
2
2 3 4
2 3 4
1
S-2051
C
Switching
specifications
Series
1
2
3
4
2
1
S-2150
Schematic
4
3
4
S-2050
2 3 4
Switching
specifications
Series
3
2
2
Schematic
5
Switching
specifications
Series
● 2 poles 3 contacts
● 1 pole 5 contacts
1
● 1 pole 4 contacts
2
1
3
12
4
23
5
34
6
45
56
6
SS-10/S-2050
SS-10端子接続
SS-10端子接続
■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS
S-2050
S-2150
2
2
C
C
C
C
5
5
1
1
4
4
Dimension is common to SS-10-15, SS-10-16 and
SS-10-23 series.
2
2
C
C
C
C
2
2
1
1
3
3
8 – φ 0.8 hole
8 – φ 0.8 hole
2.54±0.1
2.54±0.1
SS – 10 case
SS – 10 case
■ STANDARD SPECIFICATIONS
Circuit type
Contact rating
Non-switching
Switching
Minimum
− 25 ~ 70 °C
Contact timing
Storage temperature range
Sealing
Net weight
Contact resistance
Washable by “O” ring
※ Please refer to page 150, 151
Approx. 0.84 g (without knob)
Approx. 0.94 g (with knob)
■ MECHANICAL CHARACTERISTICS
No. of positions
3, 4, 5, 6
Adjustment torque
40 mN·m {408 gf·cm} maximum
Stopper strength
50 mN·m {510 gf·cm} minimum
36°
Stepping angle
Terminal strength
Solderability
Soldering heat
4 contacts
(12 pole
poles 3 contacts )
30° (1 pole 5 contacts)
22.5° (1 pole 6 contacts, with OFF)
28° (1 pole 6 contacts, without OFF)
C
C
5 – φ 0.8 hole
5 – φ 0.8 hole
2.54±0.1
2.54±0.1
S – 2050 case
SS––2150
2050 case
case
S – 2150 case
Operating face
2.54±0.1 Operating face
5 – φ 0.8 hole
2.54±0.1
5 – φ 0.8 hole
S – 2051 case
SS––2151
2051 case
case
S – 2151 case
■ ELECTRICAL CHARACTERISTICS
1 pole 4 contacts
1 pole 5 contacts
1 pole 6 contacts
2 poles 3 contacts
Operating temperature range
4 3 2 1
4 3 2 1
4 3 2 1
4 3 2 1
C
C
7.62±0.1
7.62±0.1
P.C.B. dimensions
(Bottom view)
3
3
1
1
Operating face
Operating face
2.54±0.1
2.54±0.1
3
3
6
6
7.62±0.1
7.62±0.1
1
1
4
4
2.54±0.1
2.54±0.1
C
C
5
5
2.54±0.1
2.54±0.1
3 2
3 2
NC C
NC C
Terminal pin layout
(Bottom view)
S-2051
S-2151
5.08±0.1
5.08±0.1
SS-10-15 SS-10-16 SS-10-23
Insulation resistance
Dielectric strength
DC50 V 100 mA
DC5 V 100 mA
DC20 mV 1 μ A
Shorting
Non-shorting
100 m Ω maximum
100 M Ω (DC100 V) minimum
AC300 V, 60 s
■ ENVIRONMENTAL CHARACTERISTICS
Vibration
Shock
Humidity (Steady state)
Load life
(Amplitude) 1.5 mmor
(Acceleration) 98 m/s2,
10-500-10 Hz, 3 directions for 2 h each
490 m/s2, 11 ms
6 directions for 3 times each
40 °C, Relative humidity 90 ~ 95 %, 240 h
500 cycles minimum
DC5 V, 100 mA
15 N {1.53 kgf} minimum
High temperature exposure
70 °C, 240 h
245 ± 3 °C, 2 ~ 3 s
Low temperature exposure
− 25 °C, 96 h
Flow soldering
260 ± 3 °C, 5 ~ 6 s, two times maximum
Manual soldering
380 ± 10 °C, 3 ~ 4 s
{ } : Reference only
(Unit: mm)
Thermal shock
− 25 (0.5 h) ~ 70 °C (0.5 h), 5 cycles
SS-10/S-2050
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance: ± 0.3 (Unit: mm)
● SS-10-15SP-E
● SS-10-15SP-L-E
Part No., Production date code &
Lead-free Identification mark
5
2
C
3
NC
6.6
3
NC
C
3
6
2.54
7.62
1
2.54
2
1
28
Straight knurl M = 0.2
0.7 W × 1 D
8 – 0.5 ± 0.1
t = 0.2
2.54
2.54
2.54
5
8 – 0.5 ± 0.1
t = 0.2
2.54
6
4
C
5
2
C
3
6
● SS-10-16NP-L-E
6.6
C
3
6
2.54
2.54
2
.5
22
0.7 W × 1 D
4
C
5
2
C
3
6
● SS-10-23NP-L-E
Part No., Production date code & Lead-free Identification mark
4.5 ± 0.5
6.6
1
2.54
2.54
3
0.7 W × 1 D
2.54
C
7.62
1
8 – 0.5 ± 0.1
t = 0.2
2
3.9
2
3
36
2.54
8 – 0.5 ± 0.1
t = 0.2
2.54
4.5 ± 0.5
123
1
C
SS –1 0
123
SS –1 0
36˚
7
10
7.62
2.54
7
10
6
● SS-10-23NP-E
7.62
1
2.54
5
3.9
2.54
2.54
C
8 – 0.5 ± 0.1
t = 0.2
2.54
4
345
0.7 W × 3.2 L × 1 D
4.5 ± 0.5
12
345
1
SS–1 0
12
SS–1 0
.5
22
7
10
7.62
8 – 0.5 ± 0.1
t = 0.2
4.5 ± 0.5
10
7
10
6
10
4
● SS-10-16NP-E
10
C
4.5 ± 0.5
23 4 5
1
C
SS–1 0
23 4 5
SS–1 0
28
7
10
7.62
3.9
4.5 ± 0.5
10
7
1
10
5
2
6
0.7 W × 3.2 L × 1 D
10
10
4
C
● SS-10-16SP-L-AE
0.7 W × 3.2 L × 1 D
2.54
30
0.7 W × 1 D
● SS-10-16SP-AE
1
2.54
4
7.62
8 – 0.5 ± 0.1
t = 0.2
2.54
0.7 W × 3.2 L × 1 D
4.5 ± 0.5
3.9
2.54
2.54
1
C
8 – 0.5 ± 0.1
t = 0.2
2.54
30
7
10
7.62
SS –1 0
SS –1 0
10
6.6
4. 5 ± 0.5
10
7
10
3
C
2
2
C
3
1
SS-10/S-2050
外形図
S-2150 外形図
● S-2050
● S-2150
0.7 W × 3.2 L × 1 D
Part No. & Production date code
0.7 W × 1 D
4.5 ± 0.5
6.6
10
7
4.5 ± 0.5
10
7.62
2.54
2.54
7.62
4
● S-2051
0.7 W × 1 D
0.7 W × 3.2 L × 1 D
3
2
1
C
5 – 0.5 ± 0.1
t = 0.2
2.54
2.54
6
4
3
2.54
2
1
C
5 – 0.5 ± 0.1
t = 0.2
5.08
2.54
18.1
6.6
φ 3.9
1
23
10
4
3.5 ± 0.5
10
3.5 ± 0.5
4
1
36
10
4
23
11.5
36
10
2.54
2.54
● S-2151
2.54
3
C
2
1
36
2.54
5–0.5 ± 0.1
t = 0.2
36
1
5–0.5 ± 0.1
t = 0.2
2
10
2.54
C
4
4
形図
3
23
23
10
1
4
φ 3.9
1
12.6
5.08
2.54
7
S-1000長軸用ツマミ付き
SS-10/S-2050
■ SWITCHES WITH KNOB AS EXTENDED SHAFT
(Unit: mm)
10
φ 5.5
1
φ 9.5
0.7
The large knob is common to S-1000A, S-2000A, SA-5000, and SS-10 series.
※ Knob can’t be dettached due to being fixed. Simple knob can’t be sold.
■ PACKAGING SPECIFICATIONS
● Tray version is packaged in 50 pcs. per tray. Orders will
be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs.
etc.
● Tray version is boxed with 10 trays.
● The smallest unit of bulk pack in a plastic bag is 10 pcs.
per pack.
Orders will be accepted for unit of minimum 10 pcs., i.e.,
10, 20, 30 pcs., etc.
● Boxing of bulk in a plastic bag is performed with 25 pcs.
(standard 50 pcs.) per box.
: The switch with a large knob for manual adjustment is
available as a semi-standard item.
