Adafruit 3.5" 320x480 Color TFT
Touchscreen Breakout
Created by lady ada
https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout
Last updated on 2022-07-18 04:21:16 PM EDT
©Adafruit Industries
Page 1 of 63
Table of Contents
Overview
5
Pinouts
7
• SPI Mode
• 8-Bit Mode
Wiring & Test
Assembling Header
Prepare the header strip:
Add the breakout board:
8-Bit Wiring & Test
10
13
8-Bit Wiring
Part 1 - Power & backlight test
Part 2 - Data Bus Lines
8-Bit Library Install
Prepare TFTLCD Library
SPI Wiring & Test
22
• SPI Mode Jumpers
• Wiring
• Install Arduino Libraries
Bitmaps (SPI Mode)
26
Adafruit GFX library
29
Touchscreen
30
• Download Library
• Touchscreen Paint (SPI mode)
• Touchscreen Paint (8-Bit mode)
CircuitPython Displayio Quickstart
Preparing the Breakout
Required CircuitPython Libraries
Code Example Additional Libraries
CircuitPython Code Example
Using Touch
Where to go from here
Python Wiring and Setup
33
40
Wiring
ILI9341 and HX-8357-based Displays
ST7789 and ST7735-based Displays
SSD1351-based Displays
SSD1331-based Display
Setup
Python Installation of RGB Display Library
DejaVu TTF Font
Pillow Library
Page 2 of 63
Python Usage
48
Turning on the Backlight
Displaying an Image
Drawing Shapes and Text
Displaying System Information
Troubleshooting
61
Downloads
62
• Datasheets & Files
• Schematic and PCB Print
Page 3 of 63
Page 4 of 63
Overview
Add some jazz & pizazz to your project with a color touchscreen LCD. This TFT
display is big (3.5" diagonal) bright (6 white-LED backlight) and colorful! 480x320
pixels with individual RGB pixel control, this has way more resolution than a black and
white 128x64 display, and double our 2.8" TFT. As a bonus, this display has a resistive
touchscreen attached to it already, so you can detect finger presses anywhere on the
screen.
Page 5 of 63
This display has a controller built into it with RAM buffering, so that almost no work is
done by the microcontroller. The display can be used in two modes: 8-bit or SPI. For
8-bit mode, you'll need 8 digital data lines and 4 or 5 digital control lines to read and
write to the display (12 lines total). SPI mode requires only 5 pins total (SPI data in,
data out, clock, select, and d/c) but is slower than 8-bit mode. In addition, 4 pins are
required for the touch screen (2 digital, 2 analog) or you can purchase and use our
resistive touchscreen controller (not included) to use I2C or SPI (http://adafru.it/1571).
Of course, we wouldn't just leave you with a datasheet and a "good luck!". For 8-bit
interface fans we've written a full open source graphics library that can draw pixels,
lines, rectangles, circles, text, and more (https://adafru.it/aHk). For SPI users, we have
a library as well (https://adafru.it/dQW), its separate from the 8-bit library since both
versions are heavily optimized. We also have a touch screen library that detects x, y
and z (pressure) (https://adafru.it/aT1) and example code to demonstrate all of it.
Page 6 of 63
Pinouts
The 3.5" TFT display on this breakout supports many different modes - so many that
the display itself has 50 pins. However, we think most people really only use 2
different modes, either "SPI" mode or 8-bit mode. Each 'side' of the display has all the
pins required for that mode. You can switch between modes, by rewiring the display,
but it cannot be used in two modes at the same time!
All logic pins, both 8-bit and SPI sides, are 3-5V logic level compatible, the 74LVX245
Page 7 of 63
chips on the back perform fast level shifting so you can use either kind of logic levels.
If there's data output, the levels are at at 3.3V
SPI Mode
This is what we think will be a popular mode when speed is not of the utmost
importance. It doesn't use as many pins (only 4 to draw on the TFT if you skip the
MISO pin), is fairly flexible, and easy to port to various microcontrollers. It also allows
using a microSD card socket on the same SPI bus. However, its slower than parallel 8bit mode because you have to send each bit at a time instead of 8-bits at a time.
Tradeoffs!
• GND - this is the power and signal ground pin
• 3-5V / Vin - this is the power pin, connect to 3-5VDC - it has reverse polarity
protection but try to wire it right!
• 3.3Vout - this is the 3.3V output from the onboard regulator
• CLK - this is the SPI clock input pin
• MISO - this is the SPI Microcontroller In Serial Out pin, its used for the SD card
mostly, and for debugging the TFT display. It isn't necessary for using the TFT
display which is write-only
• MOSI - this is the SPI Microcontroller Out Serial In pin, it is used to send data
from the microcontroller to the SD card and/or TFT
• CS - this is the TFT SPI chip select pin
• D/C - this is the TFT SPI data or command selector pin
• RST - this is the TFT reset pin. There's auto-reset circuitry on the breakout so
this pin is not required but it can be helpful sometimes to reset the TFT if your
setup is not always resetting cleanly. Connect to ground to reset the TFT
• Lite - this is the PWM input for the backlight control. It is by default pulled high
(backlight on) you can PWM at any frequency or pull down to turn the backlight
off
• Y+ X+ Y- X- these are the 4 resistive touch screen pads, which can be read with
analog pins to determine touch points. They are completely separated from the
TFT electrically (the overlay is glued on top)
• IM2 IM1 IM0 - these are interface control set pins. In general these breakouts
aren't used, and instead the onboard jumpers are used to fix the interface to SPI
Page 8 of 63
or 8-bit. However, we break these out for advanced use and also for our test
procedures
• Card CS / CCS - this is the SD card chip select, used if you want to read from the
SD card.
• Card Detect / CD - this is the SD card detect pin, it floats when a card is
inserted, and tied to ground when the card is not inserted. We don't use this in
our code but you can use this as a switch to detect if an SD card is in place
without trying to electrically query it. Don't forget to use a pullup on this pin if so!
8-Bit Mode
This mode is for when you have lots of pins and want more speed. In this mode we
send 8 bits at a time, so it needs way more pins, 12 or so (8 bits plus 4 control)!
• 3-5V (Vin)- this is the power pin, connect to 3-5VDC - it has reverse polarity
• CS - this is the TFT 8-bit chip select pin (it is also tied to the SPI mode CS pin)
• C/D - this is the TFT 8-bit data or command selector pin (it is also tied to the SPI
mode C/D pin)
• WR - this is the TFT 8-bit write strobe pin. It is also connected to the SPI CLK pin
• RD - this is the TFT 8-bit read strobe pin. You may not need this pin if you don't
want to read data from the display
• Backlite - this is the PWM input for the backlight control. It is by default pulled
high (backlight on) you can PWM at any frequency or pull down to turn the
backlight off
Page 9 of 63
• D0 thru D7 - these are the 8 bits of parallel data sent to the TFT in 8-bit mode. D
0 is the least-significant-bit and D7 is the MSB
Wiring & Test
We tried to make this TFT breakout useful for both high-pin microcontrollers that can
handle 8-bit data transfer modes as well as low-pincount micros like the Arduino UNO
and Leonardo that are OK with SPI.
Essentially, the tradeoff is pins for speed. SPI is about 2-4 times slower than 8-bit
mode, but that may not matter for basic graphics!
In addition, SPI mode has the benefit of being able to use the onboard microSD card
socket for reading images. We don't have support for this in 8-bit mode so if you want
to have an all-in-one image viewer type application, use SPI!
Assembling Header
Either way, if you're using a breadboard, you'll need to solder header onto one or two
of the sides. The procedure is the same for both sides
Page 10 of 63
Cut the strip to length if necessary. It will
be easier to solder if you insert it into a
breadboard - long pins down
Place the breakout board over the pins so
that the short pins poke through the
breakout pads
Page 11 of 63
breakout pads
Page 12 of 63
You're done! Check your solder joints
visually and continue onto the next steps
8-Bit Wiring & Test
8-Bit Wiring
Wiring up the 8-bit mode is kind of a pain, so we really only recommend doing it for
UNO (which we show) and Mega (which we describe, and is pretty easy since its 8
pins in a row). Anything else, like a Leonardo or Micro, we strongly recommend going
with SPI mode since we don't have an example for that. Any other kind of 'Arduino
compatible' that isn't an Uno, try SPI first. The 8-bit mode is hand-tweaked in the Adaf
ruit_TFTLCD pin_magic.h file. Its really only for advanced users who are totally cool
with figuring out bitmasks for various ports & pins.
Really, we'll show how to do the UNO but anything else? go with SPI!
Make sure you're soldering and connecting to the 8-bit side!
In these images we show using our 2.8" TFT but its the exact same pinout, just a tad
smaller!
Page 13 of 63
Begin by wiring up the 3-5VDC and GND pins.
Connect the 3-5V pin to 5V and GND to GND on your Arduino. I'm using the
breadboard rails but you can also just wire directly.
Power it up and you should see the white backlight come on
Page 14 of 63
Now that the backlight is working, we can get the TFT LCD working. There are many
pins required, and to keep the code running fairly fast, we have 'hardcoded' Arduino
digital pins #2-#9 for the 8 data lines.
However, they are not in that order! D0 and D1 go to digital #8 and #9, then D2-D7
connect to #2 thru #7. This is because Arduino pins #0 and #1 are used for serial data
so we can't use them
Begin by connecting D0 and D1 to digital #8 and 9 respectively as seen above. If
you're using a Mega, connect the TFT Data Pins D0-D1 to Mega pins #22-23, in that
order. Those Mega pins are on the 'double' header.
Page 15 of 63
Now you can connect the remaining 6 pins over. Connect D2-D7 on the TFT pins to
digital 2 thru 7 in that order. If you're using a Mega, connect the TFT Data Pins D2-D7
to Mega pins #24-29, in that order. Those Mega pins are on the 'double' header.
In addition to the 8 data lines, you'll also need 4 or 5 control lines. These can later be
reassigned to any digital pins, they're just what we have in the tutorial by default.
• Connect the third pin CS (Chip Select) to Analog 3
• Connect the fourth pin C/D (Command/Data) to Analog 2
• Connect the fifth pin WR (Write) to Analog 1
Page 16 of 63
• Connect the sixth pin RD (Read) to Analog 0
You can connect the seventh pin RST (Reset) to the Arduino Reset line if you'd like.
This will reset the panel when the Arduino is Reset. You can also use a digital pin for
the LCD reset if you want to manually reset. There's auto-reset circuitry on the board
so you probably don't need to use this pin at all and leave it disconnected
The RD pin is used to read the chip ID off the TFT. Later, once you get it all working,
you can remove this pin and the ID test, although we suggest keeping it since its
useful for debugging your wiring.
OK! Now we can run some code
We have example code ready to go for use with these TFTs. It's written for Arduino,
which should be portable to any microcontroller by adapting the C++ source.
Two libraries need to be downloaded and installed: the TFTLCD library (https://
adafru.it/aHk) and the GFX library. (https://adafru.it/aJa) You can install these libraries
through the Arduino library manager.
Open up the Arduino library manager:
Page 17 of 63
Search for the Adafruit GFX library and install it:
If using an older Arduino IDE (pre-1.8.10), also locate and install Adafruit_BusIO (newer
versions do this automatically).
Next, search for Adafruit TFTLCD and install it:
We also have a great tutorial on Arduino library installation at:
http://learn.adafruit.com/adafruit-all-about-arduino-libraries-install-use (https://
adafru.it/aYM)
In the Adafruit_TFTLCD Library folder, you may need to edit Adafruit_TFTLCD.h. On
about line 12, you will see
#define USE_ADAFRUIT_SHIELD_PINOUT
Make sure this line is commented out with a // in front (it should but if you're having
issues, its worth checking.
Next up, we originally designed this library for 320x240 TFTs. Since this is a 480x320,
we have to adjust the size the library is expecting. Open up Adafruit_TFTLCD.cpp
and find these lines:
Page 18 of 63
Comment out the 240 and 320 lines, and uncomment the 320 and 480 lines:
Save it, now you can upload the demo!
After restarting the Arduino software, you should see a new example folder called Ad
afruit_TFTLCD and inside, an example called graphicstest. Upload that sketch to your
Arduino.
Page 19 of 63
You may need to press the Reset button to reset the Arduino and TFT. You should see
a collection of graphical tests draw out on the TFT.
(The images below shows SPI wiring but the graphical output should be similar!)
Page 20 of 63
If you're having difficulties, check the serial console.The first thing the sketch does is
read the driver code from the TFT. It should be 0x8357 (for the HX8357D controller
inside)
If you Unknown Driver Chip then it's probably something with your wiring, double
check and try again!
Page 21 of 63
SPI Wiring & Test
Don't forget, we're using the SPI interface side of the PCB!
SPI Mode Jumpers
Before you start, we'll need to tell the display to put us in SPI mode so it will know
which pins to listen to. To do that, we have to connect the IM2 pin to 3.3V. The easiest
way to do that is to solder closed the IM2 jumper on the back of the PCB. Turn over
the PCB and find the solder jumper:
With your soldering iron, melt solder to close the jumper indicated IM2
Page 22 of 63
If you really don't want to solder, you can also wire the breakout pin to the 3vo pin,
just make sure you don't tie it to 5V by accident! For that reason, we suggest going
with the solder-jumper route.
Wiring
Wiring up the display in SPI mode is much easier than 8-bit mode since there's way
fewer wires. Start by connecting the power pins
• 3-5V Vin connects to the Arduino 5V pin
Page 23 of 63
• GND connects to Arduino ground
• CLK connects to SPI clock. On Arduino Uno/Duemilanove/328-based, thats Digit
al 13. On Mega's, its Digital 52 and on Leonardo/Due its ICSP-3 (See SPI
Connections for more details (https://adafru.it/d5h))
• MISO connects to SPI MISO. On Arduino Uno/Duemilanove/328-based, thats Dig
ital 12. On Mega's, its Digital 50 and on Leonardo/Due its ICSP-1 (See SPI
• MOSI connects to SPI MOSI. On Arduino Uno/Duemilanove/328-based, thats Dig
ital 11. On Mega's, its Digital 51 and on Leonardo/Due its ICSP-4 (See SPI
• CS connects to our SPI Chip Select pin. We'll be using Digital 10 but you can
later change this to any pin
• D/C connects to our SPI data/command select pin. We'll be using Digital 9 but
you can later change this pin too.
That's it! You do not need to connect the RST or other pins for now.
Three libraries need to be installed using the Arduino Library Manager…this is the
preferred and modern way. From the Arduino “Sketch” menu, select “Include Library”
then “Manage Libraries…”
Page 24 of 63
Type “gfx” in the search field to quickly find the first library — Adafruit_GFX:
If using an older Arduino IDE (pre-1.8.10), do the same for Adafruit_BusIO (newer
versions do this one automatically).
Repeat the search and install steps, looking for the Adafruit_HX8357 library.
afruit_HX8357 and inside, an example called graphicstest.
Page 25 of 63
Upload the graphicstest sketch to your Arduino. You may need to press the Reset
button to reset the Arduino and TFT. You should see a collection of graphical tests
read the driver configuration from the TFT, you should see the same numbers as
below
If you did not connect up the MISO line to the TFT, you wont see the read
configuation bytes so please make sure you connect up the MISO line for easy
debugging! Once its all working, you can remove the MISO line
Bitmaps (SPI Mode)
There is a built-in microSD card slot on the FeatherWing, and we can use that to load
bitmap images! You will need a microSD card formatted FAT16 or FAT32 (they almost
always are by default), and an SD card reader on whatever computer you’re currently
reading this with.
It's really easy to draw bitmaps. Lets start by downloading this image of Adabot and
friends:
Page 26 of 63
Download these two smaller images as well:
The files should be renamed (if needed) to “adabot.bmp”, “parrot.bmp” and “wales.bm
p”, respectively, and copied to the base directory of the microSD card (not inside a
folder).
(If it’s easier, you can also find these images in the “images” folder within the
Adafruit_ImageReader library folder.)
Page 27 of 63
You'll need to connect up the CCS pin to Digital 5 on your Arduino and swap the D/C
and CS pins as well. See the Fritzing diagram below.
3.5"_TFT_Breakout.fzz
https://adafru.it/FjB
Insert the microSD card into the socket in the shield. Now select the sketch file→exam
ples→Adafruit_ImageReader→FeatherWingHX8357 and upload this example to your
Feather + Wing. You will see the your electronic friends appear! (Plus parrots…and if
you’re using one of the more powerful Feather boards, a whole lot of dragons.)
The Adafruit_ImageReader library, which is being used here to display .BMP images,
is fully explained in its own page of the Adafruit_GFX guide (https://adafru.it/DpM).
Page 28 of 63
The Adafruit_GFX library for Arduino provides a common syntax and set of graphics
functions for all of our TFT, LCD and OLED displays. This allows Arduino sketches to
easily be adapted between display types with minimal fuss…and any new features,
performance improvements and bug fixes will immediately apply across our complete
offering of color displays.
The GFX library is what lets you draw points, lines, rectangles, round-rects, triangles,
text, etc.
Check out our detailed tutorial here http://learn.adafruit.com/adafruit-gfx-graphicslibrary (https://adafru.it/aPx)
It covers the latest and greatest of the GFX library. The GFX library is used in both 8bit and SPI modes so the underlying commands (drawLine() for example) are identical!
Page 29 of 63
Touchscreen
The LCD has a 3.5" 4-wire resistive touch screen glued onto it. You can use this for
detecting finger-presses, stylus', etc. You'll need 4 pins to talk to the touch panel, and
at least 2 must be analog inputs. The touch screen is a completely separate part from
the TFT, so be aware if you rotate the display or have the TFT off or reset, the touch
screen doesn't "know" about it - its just a couple resistors!
We have a demo for the touchscreen + TFT that lets you 'paint' simple graphics.
There's versions for both SPI and 8-bit mode and are included in the libraries. Just
make sure you have gone thru the TFT test procedure already since this builds on
that.
Remember, if you rotate the screen drawing with setRotation() you'll have to use
map() or similar to flip around the X/Y coordinates for the touchscreen as well! It
doesn't know about drawing rotation
Download Library
Begin by grabbing our analog/resistive touchscreen library from github (https://
adafru.it/aT1) (or just click the download button)
Page 30 of 63
Download Adafruit Touchscreen
Library
https://adafru.it/dd0
An additional 4 pins are required for the touchscreen. For the two analog pins, we'll
use A2 and A3. For the other two connections, you can pin any two digital pins but
we'll be using D8 and D7 since they are available.
Wire the additional 4 pins as follows:
• Y+ to Arduino A2
• X+ to Arduino D8
• Y- to Arduino D7
• X- to Arduino A3
Page 31 of 63
Load up the breakoutTouchPaint example from the Adafruit_HX8357 library and try
drawing with your fingernail! You can select colors by touching the 'pallette' of colors
on the right
Another 4 pins seems like a lot since already 12 are taken up with the TFT but you can
reuse some of the pins for the TFT LCD! This is because the resistance of the panel is
high enough that it doesn't interfere with the digital input/output and we can query
the panel in between TFT accesses, when the pins are not being used.
We'll be building on the wiring used in the previous drawing test for UNO
You can wire up the 4 touchscreen pins as follows. Starting from the top
• Y- connects to digital #9 (also D1)
• The next one down (X-) connects to Analog 2 (also C/D)
• The next one over (Y+) connects to Analog 3 (also CS)
• The last one (X+) connects to digital 8. (also D0)
The X- and Y+ pins pretty much have to connect to those analog pins (or to analog
4/5) but Y-/X+ can connect to any digital or analog pins.
Page 32 of 63
The image below shows the wiring, its for the 2.8" TFT but its the same wiring setup
Load up the tftpaint example from the Adafruit_TFTLCD library and try drawing with
your fingernail! You can select colors by touching the 'pallette' of colors on the right
You will need a board capable of running CircuitPython such as the Metro M0 Express
or the Metro M4 Express. You can also use boards such as the Feather M0 Express or
the Feather M4 Express. We recommend either the Metro M4 or the Feather M4
Express because it's much faster and works better for driving a display. For this guide,
we will be using a Feather M4 Express. The steps should be about the same for the
Feather M0 Express or either of the Metros. If you haven't already, be sure to check
out our Feather M4 Express (https://adafru.it/EEm) guide.
Adafruit Feather M4 Express - Featuring
ATSAMD51
It's what you've been waiting for, the
Feather M4 Express featuring ATSAMD51.
This Feather is fast like a swift, smart like
an owl, strong like a ox-bird (it's half ox,...
https://www.adafruit.com/product/3857
Page 33 of 63
For this guide, we'll assume you have a Feather M4 Express. The steps should be
about the same for the Feather M0 Express. To start, if you haven't already done so,
follow the assembly instructions for the Feather M4 Express in our Feather M4
Express guide (https://adafru.it/EEm).
Before using the TFT Breakout, you will need to solder the headers or some wires to
it. Be sure to check out the Adafruit Guide To Excellent Soldering (https://adafru.it/drI).
Also, follow the SPI Wiring & Test (https://adafru.it/FxS) page of this guide to be sure
your display is setup for SPI. After that, the breakout should be ready to go.
To use this display with displayio , there is only one required library.
Adafruit_CircuitPython_HX8357
https://adafru.it/EGf
First, make sure you are running the latest version of Adafruit CircuitPython (https://
adafru.it/Amd) for your board.
Next, you'll need to install the necessary libraries to use the hardware--carefully
follow the steps to find and install these libraries from Adafruit's CircuitPython library
bundle (https://adafru.it/zdx). Our introduction guide has a great page on how to
install the library bundle (https://adafru.it/ABU) for both express and non-express
boards.
Remember for non-express boards, you'll need to manually install the necessary
libraries from the bundle:
• adafruit_hx8357
Before continuing make sure your board's lib folder or root filesystem has the adafruit
_hx8357 file copied over.
Page 34 of 63
For the Code Example, you will need an additional library. We decided to make use of
a library so the code didn't get overly complicated.
Adafruit_CircuitPython_Display_Text
https://adafru.it/FiA
Go ahead and install this in the same manner as the driver library by copying the adaf
ruit_display_text folder over to the lib folder on your CircuitPython device.
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
This test will initialize the display using displayio and draw a solid green
background, a smaller purple rectangle, and some yellow text.
import board
import terminalio
import displayio
from adafruit_display_text import label
from adafruit_hx8357 import HX8357
# Release any resources currently in use for the displays
displayio.release_displays()
spi = board.SPI()
tft_cs = board.D9
tft_dc = board.D10
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs)
display = HX8357(display_bus, width=480, height=320)
# Make the display context
splash = displayio.Group()
display.show(splash)
color_bitmap = displayio.Bitmap(480, 320, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0x00FF00 # Bright Green
bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
splash.append(bg_sprite)
# Draw a smaller inner rectangle
inner_bitmap = displayio.Bitmap(440, 280, 1)
inner_palette = displayio.Palette(1)
inner_palette[0] = 0xAA0088 # Purple
inner_sprite = displayio.TileGrid(inner_bitmap, pixel_shader=inner_palette, x=20,
y=20)
splash.append(inner_sprite)
Page 35 of 63
# Draw a label
text_group = displayio.Group(scale=3, x=137, y=160)
text = "Hello World!"
text_area = label.Label(terminalio.FONT, text=text, color=0xFFFF00)
text_group.append(text_area) # Subgroup for text scaling
splash.append(text_group)
while True:
pass
Let's take a look at the sections of code one by one. We start by importing the board
so that we can initialize SPI , displayio , terminalio for the font, a label , and
the adafruit_hx8357 driver.
import board
import displayio
import terminalio
Next we release any previously used displays. This is important because if the
Feather is reset, the display pins are not automatically released and this makes them
available for use again.
Next, we set the SPI object to the board's SPI with the easy shortcut function
board.SPI() . By using this function, it finds the SPI module and initializes using the
default SPI parameters. Next we set the Chip Select and Data/Command pins that will
be used.
spi = board.SPI()
tft_cs = board.D9
tft_dc = board.D10
In the next line, we set the display bus to FourWire which makes use of the SPI bus.
Finally, we initialize the driver with a width of 480 and a height of 320. If we stopped
at this point and ran the code, we would have a terminal that we could type at and
have the screen update.
Page 36 of 63
Next we create a background splash image. We do this by creating a group that we
can add elements to and adding that group to the display. In this example, we are
limiting the maximum number of elements to 10, but this can be increased if you
would like. The display will automatically handle updating the group.
splash = displayio.Group(max_size=10)
After that we create a Bitmap which is like a canvas that we can draw on. In this case
we are creating the Bitmap to be the same size as the screen, but only have one
color. The Bitmaps can currently handle up to 256 different colors. We create a
Palette with one color and set that color to 0x00FF00 which happens to be green.
Colors are Hexadecimal values in the format of RRGGBB. Even though the Bitmaps
can only handle 256 colors at a time, you get to define what those 256 different
colors are.
With all those pieces in place, we create a TileGrid by passing the bitmap and palette
and draw it at (0, 0) which represents the display's upper left.
x=0, y=0)
This creates a solid green background which we will draw on top of.
Page 37 of 63
Next we will create a smaller purple rectangle. The easiest way to do this is the create
a new bitmap that is a little smaller than the full screen with a single color and place it
in a specific location. In this case we will create a bitmap that is 20 pixels smaller on
each side. The screen is 480x320, so we'll want to subtract 40 from each of those
numbers.
We'll also want to place it at the position (20, 20) so that it ends up centered.
x=20, y=20)
Since we are adding this after the first rectangle, it's automatically drawn on top.
Here's what it looks like now.
Page 38 of 63
Next let's add a label that says "Hello World!" on top of that. We're going to use the
built-in Terminal Font and scale it up by a factor of three. To scale the label only, we
will make use of a subgroup, which we will then add to the main group.
Labels are centered vertically, so we'll place it at 160 for the Y coordinate, and around
137 pixels make it appear to be centered horizontally, but if you want to change the
text, change this to whatever looks good to you. Let's go with some yellow text, so
we'll pass it a value of 0xFFFF00 .
# Draw a label
text_group = displayio.Group(max_size=10, scale=3, x=137, y=160)
Finally, we place an infinite loop at the end so that the graphics screen remains in
place and isn't replaced by a terminal.
Page 39 of 63
while True:
pass
Using Touch
We won't be covering how to use the touchscreen with CircuitPython in this guide, but
the library required for enabling resistive touch is the Adafruit_CircuitPython_STMPE6
10 (https://adafru.it/Fsz) library.
Be sure to check out this excellent guide to CircuitPython Display Support Using
displayio (https://adafru.it/EGh)
Wiring
It's easy to use display breakouts with Python and the Adafruit CircuitPython RGB
Display (https://adafru.it/u1C) module. This module allows you to easily write Python
code to control the display.
We'll cover how to wire the display to your Raspberry Pi. First assemble your display.
Page 40 of 63
Since there's dozens of Linux computers/boards you can use we will show wiring for
Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to
see whether your platform is supported (https://adafru.it/BSN).
Connect the display as shown below to your Raspberry Pi.
Note this is not a kernel driver that will let you have the console appear on the
TFT. However, this is handy when you can't install an fbtft driver, and want to use
the TFT purely from 'user Python' code!
You can only use this technique with Linux/computer devices that have hardware
SPI support, and not all single board computers have an SPI device so check
before continuing
2.2" Display
• CLK connects to SPI clock. On the Raspberry Pi, thats SLCK
• MOSI connects to SPI MOSI. On the Raspberry Pi, thats also MOSI
• CS connects to our SPI Chip Select pin. We'll be using CE0
• D/C connects to our SPI Chip Select pin. We'll be using GPIO 25, but this can be
changed later.
• RST connects to our Reset pin. We'll be using GPIO 24 but this can be changed
later as well.
• Vin connects to the Raspberry Pi's 3V pin
• GND connects to the Raspberry Pi's ground
Page 41 of 63
Download the Fritzing Diagram
https://adafru.it/H6C
2.4", 2.8", 3.2", and 3.5" Displays
These displays are set up to use the 8-bit data lines by default. We want to use them
for SPI. To do that, you'll need to either solder bridge some pads on the back or
connect the appropriate IM lines to 3.3V with jumper wires. Check the back of your
display for the correct solder pads or IM lines to put it in SPI mode.
changed later.
later as well.
These larger displays are set to use 8-bit data lines by default and may need to
be modified to use SPI.
https://adafru.it/H7a
Page 42 of 63
1.3", 1.54", and 2.0" IPS TFT Display
later.
changed later as well.
https://adafru.it/H7A
0.96", 1.14", and 1.44" Displays
later.
Page 43 of 63
https://adafru.it/H7B
1.8" Display
later.
• LITE connects to the Raspberry Pi's 3V pin. This can be used to separately
control the backlight.
Page 44 of 63
https://adafru.it/H8a
1.27" and 1.5" OLED Displays
later.
Page 45 of 63
https://adafru.it/H8A
0.96" OLED Display
changed later.
later as well.
Page 46 of 63
https://adafru.it/OaF
Setup
You'll need to install the Adafruit_Blinka library that provides the CircuitPython
support in Python. This may also require enabling SPI on your platform and verifying
you are running Python 3. Since each platform is a little different, and Linux changes
often, please visit the CircuitPython on Linux guide to get your computer ready (https:
//adafru.it/BSN)!
If you have previously installed the Kernel Driver with the PiTFT Easy Setup, you
will need to remove it first in order to run this example.
Once that's done, from your command line run the following command:
• sudo pip3 install adafruit-circuitpython-rgb-display
If your default Python is version 3 you may need to run 'pip' instead. Just make sure
you aren't trying to use CircuitPython on Python 2.x, it isn't supported!
Page 47 of 63
If that complains about pip3 not being installed, then run this first to install it:
• sudo apt-get install python3-pip
DejaVu TTF Font
Raspberry Pi usually comes with the DejaVu font already installed, but in case it didn't,
you can run the following to install it:
• sudo apt-get install fonts-dejavu
This package was previously calls ttf-dejavu, so if you are running an older version of
Raspberry Pi OS, it may be called that.
Pillow Library
We also need PIL, the Python Imaging Library, to allow graphics and using text with
custom fonts. There are several system libraries that PIL relies on, so installing via a
package manager is the easiest way to bring in everything:
• sudo apt-get install python3-pil
That's it. You should be ready to go.
Python Usage
Now that you have everything setup, we're going to look over three different
examples. For the first, we'll take a look at automatically scaling and cropping an
image and then centering it on the display.
On some displays, the backlight is controlled by a separate pin such as the 1.3" TFT
Bonnet with Joystick. On such displays, running the below code will likely result in the
Page 48 of 63
display remaining black. To turn on the backlight, you will need to add a small snippet
of code. If your backlight pin number differs, be sure to change it in the code:
# Turn on the Backlight
backlight = DigitalInOut(board.D26)
backlight.switch_to_output()
backlight.value = True
Displaying an Image
Here's the full code to the example. We will go through it section by section to help
you better understand what is going on. Let's start by downloading an image of
Blinka. This image has enough border to allow resizing and cropping with a variety of
display sizes and rations to still look good.
Make sure you save it as blinka.jpg and place it in the same folder as your script.
Here's the code we'll be loading onto the Raspberry Pi. We'll go over the interesting
parts.
Be sure to check the learn guides for more usage information.
This example is for use on (Linux) computers that are using CPython with
Adafruit Blinka to support CircuitPython libraries. CircuitPython does
not support PIL/pillow (python imaging library)!
Author(s): Melissa LeBlanc-Williams for Adafruit Industries
import digitalio
import board
from PIL import Image, ImageDraw
from adafruit_rgb_display import ili9341
from adafruit_rgb_display import st7789 # pylint: disable=unused-import
Page 49 of 63
from
from
from
from
import
import
import
import
hx8357 # pylint: disable=unused-import
st7735 # pylint: disable=unused-import
ssd1351 # pylint: disable=unused-import
ssd1331 # pylint: disable=unused-import
# Configuration for CS and DC pins (these are PiTFT defaults):
cs_pin = digitalio.DigitalInOut(board.CE0)
dc_pin = digitalio.DigitalInOut(board.D25)
reset_pin = digitalio.DigitalInOut(board.D24)
# Config for display baudrate (default max is 24mhz):
BAUDRATE = 24000000
# Setup SPI bus using hardware SPI:
spi = board.SPI()
# pylint: disable=line-too-long
# Create the display:
# disp = st7789.ST7789(spi, rotation=90,
# 2.0" ST7789
# disp = st7789.ST7789(spi, height=240, y_offset=80, rotation=180, # 1.3", 1.54"
ST7789
# disp = st7789.ST7789(spi, rotation=90, width=135, height=240, x_offset=53,
y_offset=40, # 1.14" ST7789
# disp = st7789.ST7789(spi, rotation=90, width=172, height=320, x_offset=34, #
1.47" ST7789
# disp = st7789.ST7789(spi, rotation=270, width=170, height=320, x_offset=35, #
1.9" ST7789
# disp = hx8357.HX8357(spi, rotation=180,
# 3.5" HX8357
# disp = st7735.ST7735R(spi, rotation=90,
# 1.8" ST7735R
# disp = st7735.ST7735R(spi, rotation=270, height=128, x_offset=2, y_offset=3,
1.44" ST7735R
# disp = st7735.ST7735R(spi, rotation=90, bgr=True,
# 0.96" MiniTFT
ST7735R
# disp = ssd1351.SSD1351(spi, rotation=180,
# 1.5" SSD1351
# disp = ssd1351.SSD1351(spi, height=96, y_offset=32, rotation=180, # 1.27" SSD1351
# disp = ssd1331.SSD1331(spi, rotation=180,
# 0.96" SSD1331
disp = ili9341.ILI9341(
spi,
rotation=90, # 2.2", 2.4", 2.8", 3.2" ILI9341
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
# pylint: enable=line-too-long
# Create blank image for drawing.
# Make sure to create image with mode 'RGB' for full color.
if disp.rotation % 180 == 90:
height = disp.width # we swap height/width to rotate it to landscape!
width = disp.height
else:
width = disp.width # we swap height/width to rotate it to landscape!
height = disp.height
image = Image.new("RGB", (width, height))
# Get drawing object to draw on image.
draw = ImageDraw.Draw(image)
# Draw a black filled box to clear the image.
draw.rectangle((0, 0, width, height), outline=0, fill=(0, 0, 0))
disp.image(image)
image = Image.open("blinka.jpg")
# Scale the image to the smaller screen dimension
image_ratio = image.width / image.height
screen_ratio = width / height
if screen_ratio < image_ratio:
Page 50 of 63
scaled_width = image.width * height // image.height
scaled_height = height
else:
scaled_width = width
scaled_height = image.height * width // image.width
image = image.resize((scaled_width, scaled_height), Image.Resampling.BICUBIC)
# Crop and center the image
x = scaled_width // 2 - width // 2
y = scaled_height // 2 - height // 2
image = image.crop((x, y, x + width, y + height))
# Display image.
disp.image(image)
So we start with our usual imports including a couple of Pillow modules and the
display drivers. That is followed by defining a few pins here. The reason we chose
these is because they allow you to use the same code with the PiTFT if you chose to
do so.
import digitalio
import board
import adafruit_rgb_display.ili9341 as ili9341
import adafruit_rgb_display.st7789 as st7789
import adafruit_rgb_display.hx8357 as hx8357
import adafruit_rgb_display.st7735 as st7735
import adafruit_rgb_display.ssd1351 as ssd1351
import adafruit_rgb_display.ssd1331 as ssd1331
Next we'll set the baud rate from the default 24 MHz so that it works on a variety of
displays. The exception to this is the SSD1351 driver, which will automatically limit it to
16MHz even if you pass 24MHz. We'll set up out SPI bus and then initialize the display.
We wanted to make these examples work on as many displays as possible with very
few changes. The ILI9341 display is selected by default. For other displays, go ahead
and comment out the line that starts with:
disp = ili9341.ILI9341(spi,
and uncomment the line appropriate for your display. The displays have a rotation
property so that it can be set in just one place.
BAUDRATE = 24000000
spi = board.SPI()
Page 51 of 63
#disp = st7789.ST7789(spi, rotation=90,
# 2.0" ST7789
#disp = st7789.ST7789(spi, height=240, y_offset=80, rotation=180, # 1.3", 1.54"
ST7789
#disp = st7789.ST7789(spi, rotation=90, width=135, height=240, x_offset=53,
#disp = hx8357.HX8357(spi, rotation=180,
# 3.5" HX8357
#disp = st7735.ST7735R(spi, rotation=90,
# 1.8" ST7735R
#disp = st7735.ST7735R(spi, rotation=270, height=128, x_offset=2, y_offset=3,
1.44" ST7735R
#disp = st7735.ST7735R(spi, rotation=90, bgr=True,
# 0.96" MiniTFT
ST7735R
#disp = ssd1351.SSD1351(spi, rotation=180,
# 1.5" SSD1351
#disp = ssd1351.SSD1351(spi, height=96, y_offset=32, rotation=180, # 1.27" SSD1351
#disp = ssd1331.SSD1331(spi, rotation=180,
# 0.96" SSD1331
disp = ili9341.ILI9341(spi, rotation=90,
# 2.2", 2.4",
2.8", 3.2" ILI9341
cs=cs_pin, dc=dc_pin, rst=reset_pin, baudrate=BAUDRATE)
Next we read the current rotation setting of the display and if it is 90 or 270 degrees,
we need to swap the width and height for our calculations, otherwise we just grab the
width and height. We will create an image with our dimensions and use that to create
a draw object. The draw object will have all of our drawing functions.
height = disp.width
width = disp.height
else:
width = disp.width
image = Image.new('RGB', (width, height))
Next we clear whatever is on the screen by drawing a black rectangle. This isn't
strictly necessary since it will be overwritten by the image, but it kind of sets the
stage.
disp.image(image)
Next we open the Blinka image, which we've named blinka.jpg, which assumes it is in
the same directory that you are running the script from. Feel free to change it if it
doesn't match your configuration.
Here's where it starts to get interesting. We want to scale the image so that it matches
either the width or height of the display, depending on which is smaller, so that we
Page 52 of 63
have some of the image to chop off when we crop it. So we start by calculating the
width to height ration of both the display and the image. If the height is the closer of
the dimensions, we want to match the image height to the display height and let it be
a bit wider than the display. Otherwise, we want to do the opposite.
Once we've figured out how we're going to scale it, we pass in the new dimensions
and using a Bicubic rescaling method, we reassign the newly rescaled image back to
image . Pillow has quite a few different methods to choose from, but Bicubic does a
great job and is reasonably fast.
else:
image = image.resize((scaled_width, scaled_height), Image.BICUBIC)
Next we want to figure the starting x and y points of the image where we want to
begin cropping it so that it ends up centered. We do that by using a standard
centering function, which is basically requesting the difference of the center of the
display and the center of the image. Just like with scaling, we replace the image
variable with the newly cropped image.
Finally, we take our image and display it. At this point, the image should have the
exact same dimensions at the display and fill it completely.
disp.image(image)
Page 53 of 63
In the next example, we'll take a look at drawing shapes and text. This is very similar
to the displayio example, but it uses Pillow instead. Here's the code for that.
This demo will draw a few rectangles onto the screen along with some text
on top of that.
import digitalio
import board
from PIL import Image, ImageDraw, ImageFont
from adafruit_rgb_display import hx8357 # pylint: disable=unused-import
from adafruit_rgb_display import st7735 # pylint: disable=unused-import
from adafruit_rgb_display import ssd1351 # pylint: disable=unused-import
from adafruit_rgb_display import ssd1331 # pylint: disable=unused-import
# First define some constants to allow easy resizing of shapes.
BORDER = 20
FONTSIZE = 24
Page 54 of 63
BAUDRATE = 24000000
spi = board.SPI()
# 2.0" ST7789
ST7789
1.47" ST7789
1.9" ST7789
# 3.5" HX8357
# 1.8" ST7735R
1.44" ST7735R
# 0.96" MiniTFT
ST7735R
# 1.5" SSD1351
# 0.96" SSD1331
spi,
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
width = disp.height
else:
# Draw a green filled box as the background
draw.rectangle((0, 0, width, height), fill=(0, 255, 0))
disp.image(image)
# Draw a smaller inner purple rectangle
draw.rectangle(
(BORDER, BORDER, width - BORDER - 1, height - BORDER - 1), fill=(170, 0, 136)
# Load a TTF Font
font = ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf",
FONTSIZE)
# Draw Some Text
(font_width, font_height) = font.getsize(text)
draw.text(
(width // 2 - font_width // 2, height // 2 - font_height // 2),
text,
font=font,
Page 55 of 63
fill=(255, 255, 0),
# Display image.
disp.image(image)
Just like in the last example, we'll do our imports, but this time we're including the
ImageFont Pillow module because we'll be drawing some text this time.
import digitalio
import board
Next we'll define some parameters that we can tweak for various displays. The BORDE
R will be the size in pixels of the green border between the edge of the display and
the inner purple rectangle. The FONTSIZE will be the size of the font in points so that
we can adjust it easily for different displays.
BORDER = 20
FONTSIZE = 24
Next, just like in the previous example, we will set up the display, setup the rotation,
and create a draw object. If you have are using a different display than the ILI9341, go
ahead and adjust your initializer as explained in the previous example. After that, we
will setup the background with a green rectangle that takes up the full screen. To get
green, we pass in a tuple that has our Red, Green, and Blue color values in it in that
order which can be any integer from 0 to 255 .
disp.image(image)
Next we will draw an inner purple rectangle. This is the same color value as our
example in displayio quickstart, except the hexadecimal values have been converted
to decimal. We use the BORDER parameter to calculate the size and position that we
want to draw the rectangle.
draw.rectangle((BORDER, BORDER, width - BORDER - 1, height - BORDER - 1),
fill=(170, 0, 136))
Next we'll load a TTF font. The DejaVuSans.ttf font should come preloaded on
your Pi in the location in the code. We also make use of the FONTSIZE parameter
that we discussed earlier.
Page 56 of 63
# Load a TTF Font
font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf',
FONTSIZE)
Now we draw the text Hello World onto the center of the display. You may recognize
the centering calculation was the same one we used to center crop the image in the
previous example. In this example though, we get the font size values using the gets
ize() function of the font object.
# Draw Some Text
draw.text((width//2 - font_width//2, height//2 - font_height//2),
text, font=font, fill=(255, 255, 0))
Finally, just like before, we display the image.
disp.image(image)
In this last example we'll take a look at getting the system information and displaying
it. This can be very handy for system monitoring. Here's the code for that example:
This will show some Linux Statistics on the attached display. Be sure to adjust
Page 57 of 63
to the display you have connected. Be sure to check the learn guides for more
usage information.
import time
import subprocess
import digitalio
import board
BAUDRATE = 24000000
spi = board.SPI()
# 2.0" ST7789
ST7789
1.47" ST7789
1.9" ST7789
# 3.5" HX8357
# 1.8" ST7735R
1.44" ST7735R
# 0.96" MiniTFT
ST7735R
# 1.5" SSD1351
# 0.96" SSD1331
spi,
cs=cs_pin,
dc=dc_pin,
rst=reset_pin,
baudrate=BAUDRATE,
width = disp.height
else:
Page 58 of 63
disp.image(image)
# First define some constants to allow easy positioning of text.
padding = -2
x = 0
# Load
# same
# Some
font =
a TTF font. Make sure the .ttf font file is in the
directory as the python script!
other nice fonts to try: http://www.dafont.com/bitmap.php
ImageFont.truetype("/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf", 24)
while True:
draw.rectangle((0, 0, width, height), outline=0, fill=0)
# Shell scripts for system monitoring from here:
# https://unix.stackexchange.com/questions/119126/command-to-display-memoryusage-disk-usage-and-cpu-load
cmd = "hostname -I | cut -d' ' -f1"
IP = "IP: " + subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "top -bn1 | grep load | awk '{printf \"CPU Load: %.2f\", $(NF-2)}'"
CPU = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "free -m | awk 'NR==2{printf \"Mem: %s/%s MB %.2f%%\",
$3,$2,$3*100/$2 }'"
MemUsage = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = 'df -h | awk \'$NF=="/"{printf "Disk: %d/%d GB %s", $3,$2,$5}\''
Disk = subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "cat /sys/class/thermal/thermal_zone0/temp | awk '{printf \"CPU Temp: %.
1f C\", $(NF-0) / 1000}'" # pylint: disable=line-too-long
Temp = subprocess.check_output(cmd, shell=True).decode("utf-8")
# Write four lines of text.
y = padding
draw.text((x, y), IP, font=font, fill="#FFFFFF")
y += font.getsize(IP)[1]
draw.text((x, y), CPU, font=font, fill="#FFFF00")
y += font.getsize(CPU)[1]
draw.text((x, y), MemUsage, font=font, fill="#00FF00")
y += font.getsize(MemUsage)[1]
draw.text((x, y), Disk, font=font, fill="#0000FF")
y += font.getsize(Disk)[1]
draw.text((x, y), Temp, font=font, fill="#FF00FF")
# Display image.
disp.image(image)
time.sleep(0.1)
Just like the last example, we'll start by importing everything we imported, but we're
adding two more imports. The first one is time so that we can add a small delay and
the other is subprocess so we can gather some system information.
import
import
import
import
time
subprocess
digitalio
board
Page 59 of 63
Next, just like in the first two examples, we will set up the display, setup the rotation,
Just like in the first example, we're going to draw a black rectangle to fill up the
screen. After that, we're going to set up a couple of constants to help with positioning
text. The first is the padding and that will be the Y-position of the top-most text and
the other is x which is the X-Position and represents the left side of the text.
padding = -2
x = 0
Next, we load a font just like in the second example.
font = ImageFont.truetype('/usr/share/fonts/truetype/dejavu/DejaVuSans.ttf', 24)
Now we get to the main loop and by using while True: , it will loop until Control+C
is pressed on the keyboard. The first item inside here, we clear the screen, but notice
that instead of giving it a tuple like before, we can just pass 0 and it will draw black.
Next, we run a few scripts using the subprocess function that get called to the
Operating System to get information. The in each command is passed through awk in
order to be formatted better for the display. By having the OS do the work, we don't
have to. These little scripts came from https://unix.stackexchange.com/
questions/119126/command-to-display-memory-usage-disk-usage-and-cpuload
cmd = "hostname -I | cut -d\' \' -f1"
IP = "IP: "+subprocess.check_output(cmd, shell=True).decode("utf-8")
cmd = "free -m | awk 'NR==2{printf \"Mem: %s/%s MB %.2f%%\", $3,$2,$3*100/$2 }'"
cmd = "df -h | awk '$NF==\"/\"{printf \"Disk: %d/%d GB %s\", $3,$2,$5}'"
cmd = "cat /sys/class/thermal/thermal_zone0/temp | awk \'{printf \"CPU Temp: %.1f
C\", $(NF-0) / 1000}\'" # pylint: disable=line-too-long
Page 60 of 63
Now we display the information for the user. Here we use yet another way to pass
color information. We can pass it as a color string using the pound symbol, just like we
would with HTML. With each line, we take the height of the line using getsize()
and move the pointer down by that much.
y = padding
Finally, we write all the information out to the display using disp.image() . Since we
are looping, we tell Python to sleep for 0.1 seconds so that the CPU never gets too
busy.
disp.image(image)
time.sleep(.1)
Troubleshooting
Page 61 of 63
Display does not work on initial power but does work
after a reset.
The display driver circuit needs a small amount of time to be ready after initial
power. If your code tries to write to the display too soon, it may not be ready. It will
work on reset since that typically does not cycle power. If you are having this issue,
try adding a small amount of delay before trying to write to the display.
In Arduino, use delay() to add a few milliseconds before calling tft.begin(). Adjust
the amount of delay as needed to see how little you can get away with for your
specific setup.
Downloads
Datasheets & Files
• Datasheet for the HX8357D chipset controller (https://adafru.it/dQQ)
• Datasheet for the 3.5" TFT display (raw) (https://adafru.it/dR4)
• EagleCAD PCB files on GitHub (https://adafru.it/pBE)
• Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3)
Page 62 of 63
Page 63 of 63
