BDNF1200
BDNF1200
    EATON(伊顿)
    SWITCH DISCONNCT 1200A 600V 3POS
BDNF1200 数据手册
1200A – 3150A Bussmann® Non-Fusible Disconnect Switches Fusible For a complete assembly please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit BDNF1200 + BDS280 + BDH117 + BDTL28 1200 – 3150 Amp switches, 600V UL general purpose amp rating 2 pole 3 pole Non-Fused BDNF1600 BDNF2000 BDNF3150 4 pole IEC AC21 amp rating 1200 1600 2000 – 1600 2500 2500 3150 1200 1600 2000 — 1600 2500 2500 3150 — — — — 1600 2500 2500 3150 Maximum horsepower rating Catalog number — — — — — — — — — — — — — — — The US National Electric Code does not specify HP — — — — — ratings for switches this large. Please select a switch based on 115% of application FLA. For example: a motor with an FLA of 800A would require a 1200A switch: 800A x 115% = 920A, the closest higher rated switch is 1200A. — — — — — Enclosed Fused NEMA type IEC type BDNF1200 BDNF1600 BDNF2000 BDNF3150 BDNF12004 BDNF16004 BDNF20004 BDNF31504 Pistol handles — for use with shaft BDH114 BDNF12002 BDNF16002 BDNF20002 BDNF31502 .47 x .47” ( 12 x 12mm) Color Length mm Marking Defeatable Padlockable Weight (lbs) Catalog number For use with BDNF1200 BDH115 1,3R,12 1,3R,12 1,3R,12 1,3R,12 IP65 IP65 IP65 IP65 Black Red/Yellow Black Red/Yellow 5.7/145 5.7/145 6.9/175 6.9/175 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes 0.39 0.39 0.41 0.41 BDH114 BDH115 BDH116 BDH117 1,3R,4,4X,12 1,3R,4,4X,12 1,3R,4,4X,12 1,3R,4,4X,12 IP66 IP66 IP66 IP65 Black Red/Yellow Black Red/Yellow 5.7/145 5.7/145 6.9/175 6.9/175 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes 0.39 0.39 0.41 0.41 CDHXB12 CDHXY12 CDHXB22 CDHXY22 Metal 8.7/220 Off/On — Yes 1.50 BDH8 For use with BDNF1600 – 3150 1,3R,4,4X,12 IP65 Enclosed Non-Fused Shafts — for use with pistol handles .47 x .47" ( 12 x 12 mm) BDH8 Shaft length inches/mm Mounting depth1 in inches Weight (lbs) Catalog number For use with BDNF1200 11.0/280 12.8/325 15.6/397 18.3/465 21.1/536 11.6 13.7 16.2 18.9 21.7 – – – – – 15.3 17.1 19.9 22.6 25.4 0.77 0.90 1.10 1.32 1.54 BDS280 BDS325 BDS395 BDS465 BDS535 13.7 16.2 18.9 21.7 – – – – 17.1 19.9 22.6 25.4 0.90 1.10 1.32 1.54 BDS325 BDS395 BDS465 BDS535 For use with BDNF1600 – 3150 BDS325 12.8/325 15.6/397 18.3/465 21.1/536 1 Mounting depth is the distance from the outside of the door to the disconnect switch mounting plate. Shaft can be cut to desired length. 50 Accessories Bussmann® for 1200A – 3150A Non-Fusible Disconnect Switches Twisted shafts – Rotates handle 45° .47 x .47" ( 12 x 12 mm) Mounting depth1 in inches Shaft length inches/mm Weight (lbs) Catalog number For use with BDNF1200 11.0/280 11.6 – 15.3 0.77 12.8/325 13.7 – 17.1 0.90 BDS28045 BDS32545 18.3/465 18.9 – 22.6 1.32 BDS46545 Fusible BDS__45 For use with BDNF1600 – 3150 12.8/325 16.2 – 19.9 0.90 BDS32545 18.3/465 18.9 – 22.6 1.32 BDS46545 BDTL28 BDTL28/2 Terminal lug kits BDNF1200 & BDNF1600 BDNF1200 & BDNF16002 BDNF2000 & BDNF3150 Wire size Kit weight (lbs.) Wire type Terminal lugs per kit Kit catalog number (4) #2 – 600kcmil 10.44 Cu/Al 6 BDTL28 (8) 2/0 + (2) #2 600kcmil 10.44 Cu/Al 3 BDTL32 (8) #2 – 600kcmil 20.88 Cu/Al 12 BDTL28/2 Non-Fused For use on: BDTL32 Power distribution lugs eliminate the need to purchase a separate distribution block BDBUS115 Busbar connections Vertical mounting3 Vertical, back or edgewise mounting For use on: Weight (lbs) BDNF1600 – BDNF3150 46.2 31.0 For use on: Weight (lbs) Catalog number BDBUS115 BDBUS114 Enclosed Fused Description Auxiliary contacts4 BDAUX1 BDAUX1 Description AC thermal amp rating AC rated voltage Catalog number 1 N.O. + 1 N.C. 0.20 10 600 BDAUX1 2 N.O. + 2 N.C. 0.26 10 600 BDAUX2 4 N.O. + 4 N.C. BDNF1200 – 0.40 10 600 BDAUX3 2 N.O. BDNF3150 0.18 10 600 BDAUX4 4 N.O. 0.25 10 600 BDAUX5 8 N.O. 0.40 10 600 BDAUX6 Enclosed Non-Fused BDBUS114 Terminal shrouds Description For use on: Weight (lbs) Catalog number Includes one shroud for line or load side BDNF1200 1.20 BDTS12 1 Mounting depth is the distance from the outside of the door to the disconnect switch mounting plate. Shaft can be cut to desired length. 2 A load side distribution lug eliminates the need to purchase, install and wire a separate distribution block. 3 Provided as standard with BDNF1600, BDNF2000 and BDNF3150. 51 Accessories Bussmann® for 1200A – 3150A Non-Fusible Disconnect Switches Handle support bracket For use on: Weight (lbs) Catalog number BDNF1200 – BDNF3150 0.88 BDZX71 Description For use on: Weight (lbs) Converts switch mechanism from front operation to side operation BDNF1200 – BDNF3150 4.63 BDZX90 Description For use on: Weight (lbs) Catalog number Joins two shafts together for applications where extended length is required 12mm shafts 0.26 BDZW95 For use on: Weight (lbs) Catalog number 12mm shafts 0.29 Description Allows handle to be directly mounted to switch behind the door Fusible BDZX71 90° angle kit Catalog number Non-Fused BDZX90 Shaft extension coupler BDZW95 Enclosed Fused Locking accessories Description Enclosed Non-Fused CDETL-ZW5 Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. For adapting to the interlock system The interlock is not included. Electrical interlock Closed circuit principle for interlocking the switch movement. When the coil circuit is dead, A-types cannot be operated to ON-position and L-types cannot be operated to ON- or OFF-position. Coil voltages 110VAC, 220VAC, 24VDC, 48VDC, 60 VDC, 110VDC, 220VDC, P = 15W U = 0.7 – 1.1 Un (U= coil voltage, Un = nominal voltage) = Coil voltage CDETL-ZT80 52 BDNF1200 – BDNF3150 2.42 CDETL-ZW5 CDETL-ZT80A/ CDETL-ZT80L/ Accessories Bussmann® for 1200A – 3150A Non-Fusible Disconnect Switches Conversion mechanisms • Switches are not included Weight (lbs) Catalog number BDNF1200 2.42 10.1 8.81 BDZW9 BDZW12 BDZW13 BDNF1200 – BDNF3150 2.64 BDZW15 For use on: 6 or 8 pole Transfer Bypass Mechanical interlock Fusible Description BDZW9 6 or 8 pole — BDZW9 6 (8) pole mechanism allows two switches controlled by one handle to open or close simultaneously. One shaft included. Equipment required for a complete installation: • One conversion mechanism. • Two disconnect switches • One handle • One addtional shaft (Only one shaft is included with mechanism) 1 X SW. B O X SW. B SW. A SW. B SW. A SW. B LOAD LOAD LOAD I O II Bypass — BDZW13 POS. I POS.O POS.II SW. A X O O SW. B O O X X = Closed O = Open 1 Bypass mechanism operates three switches: Two switches in series and one changeover switch to allow power bypass. A 3 position handle is included. Shafts included. Equipment required for a complete installation: • One conversion mechanism • Three disconnect switches POS. I POS.O POS.II SW. A O O X SW. B O O X SW. C X O O SW. A POS. I SW. B POS. I SW. A X O SW. B O X X = Closed O = Open Mechanical interlock —BDZW15 BDZW13 Mechanical interlock mechanism prevents both switches from being in the "ON" position at the same time. Handles are not included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • Two shafts • Two handles 1 X = Closed O = Open BDZW15 1 = Three poles 53 Enclosed Fused SW. A Non-Fused 1 Enclosed Non-Fused BDZW12 POS.I O X = Closed O = Open Transfer — BDZW12 Transfer mechanism manually transfers between two power sources using two switches and a center OFF position. A 3 position handle is included. Shafts included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches POS. O SW. A
BDNF1200 价格&库存
很抱歉,暂时无法提供与“BDNF1200”相匹配的价格&库存,您可以联系我们找货
