BDNF4004
BDNF4004
    EATON(伊顿)
    SWITCH DISCONNECT 400A 600V 4POS
BDNF4004 数据手册
400A – 800A Bussmann® Non-Fusible Disconnect Switches Fusible For a complete assembly, please select one of each: 1 switch 1 handle 1 shaft 1 terminal lug kit BDNF400 + BDS280 + BDH116 + BDTL26 400 – 800 Amp switches, 600V UL general purpose amp rating 2 pole BDNF600A 3 pole Non-Fused 4 pole IEC AC21 amp rating 200V 208V 240V 480V 600V 400 600 800 630 800 1250 — — — — — — — — — — — — — — — BDNF4002 BDNF600A2 BDNF800A2 400 600 800 630 800 1250 100 150 200 100 150 200 125 200 250 250 400 500 350 500 600 BDNF400 BDNF600A BDNF800A 400 600 — 630 800 1250 100 150 200 100 150 200 125 200 250 250 400 500 350 500 600 BDNF4004 BDNF600A4 BDNF800A4 Maximum horsepower rating Pistol handles — for use with shafts BDNF800A Enclosed Fused BDH112-117 IEC type Color Length in/mm Marking Defeatable Padlockable Weight (lbs) 1,3R,12 1,3R,12 1,3R,12 1,3R,12 1,3R,12 1,3R,12 IP65 IP65 IP65 IP65 IP65 IP65 Blk R/Y Blk R/Y Blk R/Y 4.9/125 4.9/125 5.7/145 5.7/145 6.9/175 6.9/175 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes 0.39 0.39 0.39 0.39 0.41 0.41 BDH112 BDH113 BDH114 BDH115 BDH116 BDH117 1,3R,4,4X,12 1,3R,4,4X,12 1,3R,4,4X,12 1,3R,4,4X,12 IP66 IP66 IP66 IP66 Blk R/Y Blk R/Y 5.7/145 5.7/145 6.9/175 6.9/175 O/I & Off/On O/I & Off/On O/I & Off/On O/I & Off/On Yes Yes Yes Yes Yes Yes Yes Yes 0.39 0.39 0.41 0.41 CDHXB12 CDHXY12 CDHXB22 CDHXY22 1,3R,4,4X,12 IP65 Metal 8.7/220 Off/On — Yes 1.50 BDH8 Enclosed Non-Fused Shaft length inches/mm 11.0/280 12.8/325 15.6/395 18.3/465 21.1/535 Twisted shafts — Rotates handle 45° Shaft length inches/mm 11.0/280 12.8/325 18.3/465 BDS__45 .47 x .47” ( 12 x 12 mm) NEMA type Shafts — for use with pistol handles BDS280 Catalog number Catalog number .47 x .47" ( 12 x 12 mm) Mounting depth1 in inches 10.2 12.0 14.8 17.5 20.3 – – – – – 14.5 16.3 19.1 21.9 24.6 Weight (lbs) Catalog number 0.77 0.90 1.10 1.32 1.54 BDS280 BDS325 BDS395 BDS465 BDS535 .47 x .47" ( 12 x 12 mm) Mounting depth1 in inches 10.2 12.0 17.5 – 14.5 – 16.3 – 21.9 Weight (lbs) 0.77 0.90 1.32 Catalog number BDS28045 BDS32545 BDS46545 1 Mounting depth is the distance from the outside of the door to the disconnect switch mounting plate. Shaft can be cut to desired length. 46 Courtesy of Steven Engineering, Inc. ! 230 Ryan Way, South San Francisco, CA 94080-6370 ! Main Office: (650) 588-9200 ! Outside Local Area: (800) 258-9200 ! www.stevenengineering.com Accessories Bussmann® for 400A – 800A Non-Fusible Disconnect Switches Terminal lug kits BDTL27 BDTL26 Wire size Kit weight (lbs.) Wire type Terminal lugs per kit Kit catalog number BDNF400 #2 – 600 kcmil 3.50 Cu/Al 6 BDTL26 BDNF400 (2) #2 – 500 kcmil 4.62 Cu/Al 6 BDTL262 BDNF600A (2) #2 – 600 kcmil 4.62 Cu/Al 6 BDTL27 BDNF800A (2) #2 – 600 kcmil 6.90 Cu/Al 6 BDTL30 6.90 1.10 Cu/Al Cu/Al 3 6 BDTL32 BDTL175/400 Weight (lbs) AC thermal amp rating AC rated voltage Catalog number 1 N.O. + 1 N.C. 0.20 10 600 BDAUX1 2 N.O. + 2 N.C. 0.26 10 600 BDAUX2 BDNF800A1 BDNF400 – BDNF600A1 (8) 2/0 + (2)#2 600 kcmil (12) #14 – 6 Fusible For use on: BDTL30 BDAUX1–6 4 N.O. + 4 N.C BDNF400 – 0.40 10 600 BDAUX3 2 N.O. BDNF800A 0.18 10 600 BDAUX4 4 N.O. 0.25 10 600 BDAUX5 8 N.O. 0.40 10 600 BDAUX6 Weight (lbs) AC thermal amp rating AC rated voltage Catalog number Terminal poles Description Detachable neutral mounts on side of switch or DIN rail BDZX85 BDNF400 – BDNF600A 1.04 400 600 BDZX85 For use on: Weight (lbs) Catalog number Includes one BDNF400 0.62 BDTS4 shroud for line or BDNF600A 0.66 BDTS6A load side BDNF800A 0.88 BDTS8A For use on: Weight (lbs) Catalog number BDNF400 – BDNF600A 0.51 BDZX73 BDNF800A 0.88 BDZX71 Handle support bracket Description Allows handle to be directly mounted to switch behind the door BDZX71 For use on: Terminal shrouds Description BDTS__ For use on: Non-Fused Description Enclosed Fused BDTL32 Auxiliary contacts2 Enclosed Non-Fused BDTL175/400 1 A load side distribution lug eliminates the need to purchase, install and wire a separate distribution block. 2 UL File E57057 47 Courtesy of Steven Engineering, Inc. ! 230 Ryan Way, South San Francisco, CA 94080-6370 ! Main Office: (650) 588-9200 ! Outside Local Area: (800) 258-9200 ! www.stevenengineering.com Accessories Bussmann® for 400A – 800A Non-Fusible Disconnect Switches 90° angle kit Description Converts switch mechanism from front operation to side operation For use on: Weight (lbs) Catalog number BDNF400 BDNF600A BDNF800A 4.63 For use on: Weight (lbs) Catalog number 12mm shafts 0.26 BDZW95 For use on: Weight (lbs) Catalog number 12mm shafts 0.29 CDETL-ZW5 BDNF400 BDNF600A BDNF800A 2.42 CDETL-ZT80A/ CDETL-ZT80L/ BDNF400 BDNF600A 0.40 CDETL-ZT100 BDZX108 Fusible BDZX108 Shaft extension coupler Description BDZW95 Joins two shafts together for applications where extended length is required Locking accessories Non-Fused Description CDETL-ZW5 Enclosed Fused Cam attachment for Kirk Key, Castell, Lowe & Fletcher and Ronis interlock. For adapting to the interlock system The interlock is not included. Electrical interlock1 Closed circuit principle for interlocking the switch movement. When the coil circuit is dead, A-types cannot be operated to ON-position and L-types cannot be operated to ON- or OFF-position. Coil voltages 110VAC, 220VAC, 24VDC, 48VDC, 60 VDC, 110VDC, 220VDC, P = 15W U = 0.7 – 1.1 Un (U = coil voltage, Un = nominal voltage) Mounting bracket – Coil voltage Enclosed Non-Fused CDETL-ZT80_ CDETL-ZT100 1 CDETL-ZT100 mounting bracket required for BDNF400 & BDNF600A 48 Courtesy of Steven Engineering, Inc. ! 230 Ryan Way, South San Francisco, CA 94080-6370 ! Main Office: (650) 588-9200 ! Outside Local Area: (800) 258-9200 ! www.stevenengineering.com Accessories Bussmann® for 400A – 800A Non-Fusible Disconnect Switches Conversion mechanisms BDZW9 Catalog number 2.42 10.1 8.81 BDZW9 BDZW12 BDZW13 1.26 1.15 2.64 BDZW3 BDZW14 BDZW15 6 or 8 pole — BDZW9 6 (8) pole mechanism allows two switches controlled by one handle to open or close simultaneously. One shaft included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • One handle • One additional shaft (Only one shaft is included with mechanism). 1 BDZW12 POS.I O X SW. B O X X = Closed O = Open 1 Transfer — BDZW12 Transfer mechanism manually transfers between two power sources using two switches and a center OFF position. A 3 position handle is included. Shafts included. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches POS.O SW. A SW. A SW. B SW. A SW. B SW. A SW. B LOAD LOAD LOAD I O II POS. I POS.O POS.II SW. A X O O SW. B O O X X = Closed O = Open Bypass — BDZW13 1 Bypass mechanism operates three switches: Two switches in series and one changeover switch to allow power bypass. A 3 position handle is included. (UL Type 1, 3R, 4, 4X, 12). Shafts included. Equipment required for a complete installation: • One conversion mechanism • Three disconnect switches POS. I POS.O POS.II SW. A O O X SW. B O O X SW. C X O O SW. A POS. I SW. B POS. I SW. A X O SW. B O X X = Closed O = Open Mechanical interlock — BDZW3, BDZW14, BDZW15 BDZW13 Mechanical interlock mechanism prevents both switches from being in the ON position at the same time. Equipment required for a complete installation: • One conversion mechanism • Two disconnect switches • Two shafts • Two handles 1 X = Closed O = Open BDZW3, 14, 15 1 Non-Fused Mechanical interlock BDNF400 BDNF600A BDNF800A Weight (lbs) = Three poles 49 Courtesy of Steven Engineering, Inc. ! 230 Ryan Way, South San Francisco, CA 94080-6370 ! Main Office: (650) 588-9200 ! Outside Local Area: (800) 258-9200 ! www.stevenengineering.com Enclosed Fused 6 or 8 pole Transfer Bypass For use on: Enclosed Non-Fused Description Fusible • Switches are not included
BDNF4004 价格&库存
很抱歉,暂时无法提供与“BDNF4004”相匹配的价格&库存,您可以联系我们找货
