SR18UB
SR18UB
    TRIPPLITE
    18U RACK ENCL SERVER CABINET 33"
SR18UB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartRack 18U Mid-Depth Half-Height Rack Enclosure MODEL NUMBER: SR18UB Highlights ● 18U with adjustable front and rear vertical rackmount rails ● Depth of 33" allow for standard server installation ● Locking, reversible front/rear doors and locking, removable side panels ● Fully assembled for quick installation ● Casters and leveling feet ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) compliance Package Includes Description Tripp Lite's SmartRack 18U Mid-Depth Rack Enclosure Cabinet is packed with features designed to simplify rack equipment installations and rack equipment maintenance: top and bottom cable routing ports, perforated door and side panels to promote efficient airflow, adjustable vertical mounting rails and more. And as part of the SmartRack family, the SR18UB is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to meet any requirement. The SR18UB ships fully assembled for quick installation and comes with a 5-year warranty. The SR18UB is compatible with all standard 19-inch rack equipment and features front and rear pairs of vertical rails with square mounting holes. The rails are adjustable in quarter-inch increments to accommodate equipment depths from 3 to 32.5 inches, ideal for standard server installation. The rails feature square mounting holes and are capable of supporting up to 1000 lbs (453.6 kgs) of equipment with included installation hardware. Each rack space within the enclosure is numbered for easy reference. With a locking, reversible front/rear doors and locking, removable side panels, the SR18UB provides safe, secure installation for all equipment. This prevents unauthorized access to installed equipment while making it easy for authorized personnel to perform inspections, maintenance and equipment replacement. The enclosure meets all requirements toward PCI DSS compliance. The top and bottom panels of the SR18UB are furnished with vents designed to help remove warm air from the enclosure and draw in cool air by convection. They also support installation of standard usersupplied case fans (Tripp Lite SRFANWM). The top and bottom panels are also provided with ports for cable routing. To simplify deployment, the SR18UB comes with an accessory caster kit consisting of 4 casters and all required installation hardware. With casters installed, the SR18UB can easily be maneuvered into to desired location, and then secured in place by adjusting the unit's levelers. Note: the casters are intended for minor position adjustments within the final installation area only and are not designed for moving the enclosure over long distances. Features ● 18U mid-depth enclosure ● Adjustable mounting depths from 3" to 32.5" inches ● Locking, reversible front and rear doors ● Locking, removable side panels ● Top and bottom panel cable access openings ● Fully assembled for quick installation ● Casters and leveling feet 1/3 ● SmartRack 18U Mid-Depth Rack Enclosure Cabinet ● (42) M6 screws ● (42) M6 cage nuts ● (42) M6 washers ● (4) Casters ● (4) Levelers ● (2) keys ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard) compliance Specifications OVERVIEW UPC Code 037332178039 Device Compatibility Patch Panel; Network Switch; UPS; Server Rack Type Half-Height Enclosure PHYSICAL Color Black Rack Height 18U Rack Depth Mid Factory Preset Rack Depth (in.) 28.31 Factory Preset Rack Depth (cm) 71.9 Factory Preset Rack Depth (mm) 719 Maximum Device Depth (cm) 82.55 Maximum Device Depth (in.) 32.5 Maximum Device Depth (mm) 826 Minimum Device Depth (cm) 7.62 Minimum Device Depth (in.) 3 Minimum Device Depth (mm) 76 Cable Access Hole Measurement (inches) 9.812 x 2.35 (l x w) Shipping Dimensions (hwd / in.) 41.00 x 24.00 x 34.00 Shipping Dimensions (hwd / cm) 104.14 x 60.96 x 86.36 Shipping Weight (lbs.) 125.00 Shipping Weight (kg) 56.70 Unit Dimensions (hwd / in.) 35.600 x 23.620 x 33.500 Unit Dimensions (hwd / cm) 90.42 x 60 x 85.09 Unit Weight (lbs.) 105 Unit Weight (kg) 47.63 Weight Capacity - Rolling (kg) 454 Weight Capacity - Rolling (lbs.) 1000 Weight Capacity - Stationary (kg) 454 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Weight Capacity - Stationary (lbs.) 1000 Number of Vertical Mounting Rails 4 FEATURES & SPECIFICATIONS Grounding Lug Front and Back door frames Built-in Cable Management Yes Pre-Installed Casters Yes STANDARDS & COMPLIANCE Product Certifications UL 60950-1 Product Compliance RoHS; EIA/ECA-310-E; UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
SR18UB 价格&库存
很抱歉,暂时无法提供与“SR18UB”相匹配的价格&库存,您可以联系我们找货
