1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartRack 45U Standard-Depth 4-Post Premium
Open Frame Rack with No Sides, Doors or Roof
MODEL NUMBER: SR45UBEXPNDNR3
Highlights
45U SmartRack Premium open
frame rack (no sides, doors or
roof)
4 interior vertical posts with
unthreaded square hole
openings
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimizing floor space
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 3000 lbs (1360.8 kgs) rolling
load capacity
Preinstalled heavy duty 3"
casters and leveling feet
Includes 50 pieces of M6 cage
nuts and 50 pieces of M6
screws (equipment mounting
hardware)
Package Includes
4-Post Premium Open Frame
Rack
Mounting Hardware
Owner's Manual
Description
This SmartRack 45U Standard-Depth 4-Post Premium Open Frame Rack is an expansion model with no
sides, doors or roof. An expansion model is useful when baying together multiple enclosures. Its
integrated baying tabs make it easy to combine multiple enclosures in rows for data center applications.
The SR45UBEXPNDNR3 houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. It is
an expansion model that comes without sides, doors or roof. The front and rear pairs of vertical rails have
square mounting holes that are adjustable in quarter-inch increments from 4 to 37 inches. Adjustment is
quick and an easy-view depth index ensures consistent rail placement without requiring time-consuming
measurements. Each rack space within the enclosure is numbered for ready reference and supports toolless button-mount 0U installation of up to four compatible PDUs and cable managers.
All components of the SR45UBEXPNDNR3 are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground.
To simplify deployment, the SR45UBEXPNDNR3 comes with heavy duty 3" preinstalled casters that
enable it to be easily maneuvered into the desired location, where it can be secured by adjusting the
preinstalled levelers. Note: the casters are intended for minor position adjustments and are not designed
for moving the enclosure over long distances.
The SR45UBEXPNDNR3 comes with a 5-year product warranty. As part of the SmartRack family, the
SR45UBEXPNDNR3 is compatible with Tripp Lite's extensive range of rackmount accessories, enabling
you to customize your solution to meet any requirement.
Features
Open frame rack with no sides, doors or roof
Ships fully assembled for rapid deployment and roll into place on 3" pre-installed casters (casters are
removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Tool-less accessory mounting rails (2 rails per enclosure) include slots for quick installation of
compatible PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard
pattern compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or
cable managers side-by-side (four items per enclosure).
Mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws included
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
1/3
Cleveland, OH 44122
United States
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 3000 lbs (1360.8 kgs) rolling.
Built in baying tabs allow premium open frame racks to be combined securely in rows. Center-to-center
width can be set at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow premium open frame racks to be positioned on uneven floors. Levelers are
removable.
Convenient grounding system. All components are grounded to the premium open frame rack structure
which includes multiple connections for facility ground.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the premium
open frame rack on the inside or outside of the rack.
Compatibility with all cable management accessories.
Specifications
OVERVIEW
UPC Code
037332174857
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Open-Frame
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Standard
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.50 x 26.00 x 45.00
Shipping Dimensions (hwd / cm)
229.87 x 66.04 x 114.30
Shipping Weight (lbs.)
180.00
Shipping Weight (kg)
81.65
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
215.27 x 60.02 x 105.41
Unit Weight (lbs.)
130
Unit Weight (kg)
58.97
Weight Capacity - Rolling (kg)
1,361
Weight Capacity - Rolling (lbs.)
3000
2/3
Cleveland, OH 44122
United States
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR45UBEXPNDNR3”相匹配的价格&库存,您可以联系我们找货
