1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA-Compliant 45U SmartRack Standard-Depth
Rack Enclosure Cabinet with doors & side
panels
Highlights
Compliant with the Federal
Trades Agreement Act (TAA) for
GSA Schedule purchases
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimizing floor space
Ships fully assembled
3000 lb stationary / 2250 lb
rolling load capacity
Locking, removable, reversible
front and rear doors; Locking,
removable side panels keyed
alike with doors
Pre-installed casters and
leveling feet
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
MODEL NUMBER: SR45UBTAA
Package Includes
SR45UBTAA Rack Enclosure
(4) Side Panels
Description
(4) Side panel locks
SR45UBTAA meets the requirements of the Trade Agreements Act (TAA). TAA compliance applies to
(50) M6 screws
GSA Schedule and IDIQ contract purchases, and requires that products be assembled within the United
(50) M6 cage nuts
States or in an approved country.
(50) M6 washers
(2) Door and side panel keys
Owner's Manual
The SR45UBTAA features a massive front-to rear-ventilation capacity that meets or exceeds server
manufacturer requirements. Its integrated baying tabs make it easy to combine multiple enclosures in
rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle
configurations.
The SR45UBTAA houses 3000 lb of standard 19-inch rack equipment in 45U. Its front and rear pairs of
vertical rails have square mounting holes that are adjustable in quarter-inch increments from 4 to 37
inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without
requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready
reference.
Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four
compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment
and reduces cord clutter.
With its locking, reversible, removable front and rear doors, and locking, removable side panels, the
SR45UBTAA provides ultimate equipment safety. The side panels are half size for ease of removal and
reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The
SR45UBTAA meets all requirements toward PCI DSS compliance.
1/4
Cleveland, OH 44122
United States
The top panel of the SR45UBTAA is vented to help remove warm air from the enclosure and draw in cool
air by convection. The top panel includes ports for cable routing, and can be quickly removed without
tools. To facilitate cable access, the SR45UBTAA is open-bottom.
All components of the SR45UBTAA are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
To simplify deployment, the SR45UBTAA comes with preinstalled casters that enable it to be easily
maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note:
the casters are intended for minor position adjustments and are not designed for moving the enclosure
over long distances.
The SR45UBTAA comes with a 5-year product warranty. As part of the SmartRack family, the
SR45UBTAA is compatible with Tripp Lite’s extensive range of rackmount accessories, enabling you to
customize your solution to meet any requirement.
Features
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Ships fully assembled for rapid deployment and roll into place on pre-installed casters that support a
rolling load capacity of 2250 lbs, allowing the enclosures to be pre-configured and rolled to the final
installation location. (Casters are removable.)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lb stationary and 2250 lb rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
2/4
Cleveland, OH 44122
United States
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332175724
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
45U
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
83.00 x 25.50 x 44.00
Shipping Dimensions (hwd / cm)
210.82 x 64.77 x 111.76
Shipping Weight (lbs.)
357.00
Shipping Weight (kg)
161.93
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
212.725 x 60.02 x 109.22
Unit Weight (lbs.)
307
Unit Weight (kg)
139.25
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
3/4
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Grounding Lug
Front and back door frames
Built-in Cable Management
Yes
Pre-Installed Casters
Yes
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SR45UBTAA”相匹配的价格&库存,您可以联系我们找货
