1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack Standard-Depth Rack Enclosure
Cabinet with doors, side panels & shock pallet
packaging
MODEL NUMBER: SR45UBSP1
Description
45U SmartRack Enclosure ships mounted on a special pallet that features additional reinforcement and
shock-absorbing material. The pallet's protective cushion safeguards the enclosure and the precision
components it contains during re-shipping. Reinforced pallets and reusable packaging provide the
flexibility to fully configure rack enclosures in a centralized location and safely re-ship them to remote
sites, saving significant service costs. They also allow the freedom to custom-configure enclosures with
network and server hardware along with UPS systems, PDUs, KVM switches and a variety of other
devices prior to final installation. At the desired location the SR45UBSP1 can be easily maneuvered with
its preinstalled casters and can be secured by adjusting the preinstalled levelers.
The SR45UBSP1 houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. Its front and
rear pairs of vertical rails have square mounting holes that are adjustable in quarter-inch increments from
4 to 37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement
without requiring time-consuming measurements. Each rack space within the enclosure is numbered for
ready reference.
Two of the adjustable vertical mounting rails support toolless button-mount 0U installation of up to four
compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment
and reduces cord clutter.
With its locking, reversible, removable front and rear doors, and locking, removable side panels, the
SR45UBUSP1 provides ultimate equipment safety. The side panels are half size for ease of removal and
reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The
SR45UBSP1 meets all requirements toward PCI DSS compliance.
The top panel of the SR45UBSP1 is vented to help remove warm air from the enclosure and draw in cool
air by convection. the top panel includes ports for cable routing, and can be quickly removed without tools.
The facilitate cable access, the SR45UBSP1 is open-bottom.
All components of the SR45UBSP1 are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
The SR45UBSP1 comes with a 5-year product warranty. As part of the SmartRack family it is compatible
with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your solution to
meet any requirements.
Features
This special version of Tripp Lite's SR45UB SmartRack Enclosure ships mounted on a "shock pallet"
that features additional reinforcement and shock-absorbing material for safe loading and re-shipping
Heavy-duty ramps (included) allow enclosure to be rolled on and off the pallet during configuration
1/4
Highlights
45U SmartRack enclosure with
doors and side panels
Ships fully assembled on shock
pallet with loading ramps
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimizing floor space
4 interior vertical posts with
unthreaded square hole
openings
Massive front to rear ventilation
capacity
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
Locking, removable side panels
keyed alike with doors
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
Package Includes
SR45UB Rack Enclosure
(4) side panels
(4) side panel locks
(2) door & side panel keys
(50) M6 screws
(50) M6 washers
(50) M6 cage nuts
Owner's Manual
Cleveland, OH 44122
United States
Shipping Capacity: shock-pallet supports up to 1250 lbs (566.9 kgs) (281 lbs (127.5 kgs) SmartRack
Enclosure weight + up to 969 lbs (439.5 kgs) of additional equipment), enabling safe loading and reshipping
Final Installation Capacity: SmartRack Enclosure supports up to 3000 lbs (1360.8 kgs) of equipment
stationary and 2250 lbs (1020.6 kgs) rolling.
Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters.
(casters are removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws.
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 750mm or 29.5" to match standard data center floor tiles.
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332174864
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
2/4
Cleveland, OH 44122
United States
Rack Height
45U
Rack Depth
Standard
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.25 x 26.00 x 45.00
Shipping Dimensions (hwd / cm)
229.24 x 66.04 x 114.30
Shipping Weight (lbs.)
357.00
Shipping Weight (kg)
161.93
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
212.725 x 60.02 x 109.22
Unit Weight (lbs.)
307
Unit Weight (kg)
139.25
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and back rear door frames
Built-in Cable Management
Yes
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SR45UBSP1”相匹配的价格&库存,您可以联系我们找货
