1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack Shallow-Depth Rack Enclosure
Cabinet with doors & side panels
MODEL NUMBER: SR45UBSD
Highlights
Ideal for shallow depth A/V
equipment or any venue with
limited floorspace
32" (825mm) depth (with
mounting depth increments of 4
to 27") and standard 24"
(600mm) width
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors; Locking,
removable side panels keyed
alike with doors
Preinstalled casters and leveling
feet
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
Package Includes
Description
The shallow depth of the SR45UBSD is an ideal cabinet for shallow-depth audio/video equipment, smaller
equipment installs or areas with limited floor space. It houses 3000 lbs (1360.8 kgs) of standard 19-inch
rack equipment in 45U. Its front and rear pairs of vertical rails have square mounting holes that are
adjustable in quarter-inch increments from 4 to 27 inches. Adjustment is quick and an easy-view depth
index ensures consistent rail placement without requiring time-consuming measurements. Each rack
space within the enclosure is numbered for ready reference.
Two of the adjustable vertical mounting rails support tool-less button-mount 0U installation of up to four
compatible PDUs and cable managers. This feature makes it easier to route cabling to rack equipment
and reduces cord clutter.
With its locking, reversible, removable front and rear doors, and locking, removable side panels, the
SR45UBSD provides ultimate equipment safety. The side panels are half size for ease of removal and
reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The
SR45UBSD meets all requirements toward PCI DSS compliance.
The top panel of the SR45UBSD is vented to help remove warm air from the enclosure and draw in cool
air by convection. The top panel includes ports for cable routing, and can be quickly removed without
tools. To facilitate cable access, the SR45UBSD is open-bottom.
All components of the SR45UBSD are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
To simplify deployment, the SR45UBSD comes with preinstalled casters that enable it to be easily
maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note:
the casters are intended for minor position adjustments and are not designed for moving the enclosure
over long distances.
The SR45UBSD comes with a 5-year product warranty. As part of the SmartRack family, the SR45UBSD
is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to customize your
solution to meet any requirement.
Features
Shallow depth enclosure is perfect for shallow-depth audio/video equipment, smaller equipment installs
Ships fully assembled for rapid deployment and roll into place on pre-installed casters, allowing the
enclosures to be pre-configured and rolled to the final installation location. Casters are removable.
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
1/4
SR45UBSD Rack Enclosure
(4) Side panels
(4) Side panel locks
(2) Door & side panel keys
(50) M6 screws
(50) M6 cage nuts
(50) M6 washers
Owner's Manual
Cleveland, OH 44122
United States
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 27 inches (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Compatibility with airflow optimization accessories as well as cable management accessories.
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance.
Specifications
OVERVIEW
UPC Code
037332174895
Device Compatibility
Patch Panel; Network Switch; UPS
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Shallow
Factory Preset Rack Depth (in.)
19.25
Factory Preset Rack Depth (cm)
48.9
Factory Preset Rack Depth (mm)
489
2/4
Cleveland, OH 44122
United States
Maximum Device Depth (cm)
68.58
Maximum Device Depth (in.)
27
Maximum Device Depth (mm)
686
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.50 x 26.00 x 34.00
Shipping Dimensions (hwd / cm)
229.87 x 66.04 x 86.36
Shipping Weight (lbs.)
282.00
Shipping Weight (kg)
127.91
Unit Dimensions (hwd / in.)
83.750 x 23.630 x 32.480
Unit Dimensions (hwd / cm)
212.725 x 60.02 x 82.5
Unit Weight (lbs.)
232
Unit Weight (kg)
105.23
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and back door frames
Built-in Cable Management
Yes
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SR45UBSD”相匹配的价格&库存,您可以联系我们找货
