1000 Eaton Boulevard
Cleveland, OH 44122
United States
42U SmartRack Expandable Standard-Depth
Server Rack Enclosure Cabinet - side panels not
included
MODEL NUMBER: SR42UBEXP
Description
The SR42UBEXP is an expansion model used when several cabinets are bayed together. It has doors
and a roof but no side panels. Its integrated baying tabs make it easy to combine multiple enclosures in
rows fro data center application. The SR42UBEXP is also compatible with hot aisle/cold aisle
configurations.
The SR42UBEXP houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 42U. Offers
vendor-neutral square hole/cage nut mounting for guaranteed compatibility with all EIA-310-E compliant
19" equipment. Its front and rear pairs of vertical rails are adjustable in quarter-inch increments from 4 to
37 inches. Adjustment is quick and an easy-view depth index ensures consistent rail placement without
requiring time-consuming measurements. Each rack space within the enclosure is numbered for ready
reference. Two of these adjustable vertical mounting rails support toolless button-mount 0U installation of
up to four compatible PDUs and cable managers. This feature makes it easier to route cabling to rack
equipment and reduces cord clutter.
The top panel of the SR42UBEXP is vented to help remove warm air from the enclosure and draw in cool
air by convection. The top panel includes ports for cable routing, and can be quickly removed without
tools. To facilitate cable access, the SR42UBEXP is open-bottom.
All components of the SR42UBEXP are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
To simplify deployment, the SR42UBEXP comes with preinstalled casters that enable it to be easily
maneuvered into the desired location, where it can be secured by adjusting the preinstalled levelers. Note:
the casters are intended for minor position adjustments and are not designed for moving the enclosure
over long distances.
Features
Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters
(casters are removable)
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
1/3
Highlights
42U SmartRack enclosure with
doors and NO side panels.
'EXP' version is an expansion
model for when several cabinets
are bayed together
4 interior vertical posts with
unthreaded square hole
openings
Standard 24" (600mm) width
and 42" (1050mm) depth for
optimizing floor space
Massive front to rear ventilation
capacity
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors
Rolls through standard 7-ft.
(2.13 m) doorway
Cleveland, OH 44122
United States
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Side panels can be added at a later time if needed. (p/n: SR42SIDE)
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 600mm or 24" to match standard data center floor tiles.
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Compact design allows the enclosure to roll through standard height commercial doorways.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332123787
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
42U
Rack Depth
Standard
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
2/3
Cleveland, OH 44122
United States
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
85.00 x 26.00 x 45.50
Shipping Dimensions (hwd / cm)
215.90 x 66.04 x 115.57
Shipping Weight (lbs.)
259.00
Shipping Weight (kg)
117.48
Unit Dimensions (hwd / in.)
78.500 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
199.39 x 60.02 x 109.22
Unit Weight (lbs.)
203
Unit Weight (kg)
92.08
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR42UBEXP”相匹配的价格&库存,您可以联系我们找货
