1000 Eaton Boulevard
Cleveland, OH 44122
United States
48U SmartRack Standard-Depth Rack Enclosure
Cabinet - side panels not included
Highlights
48U SmartRack enclosure with
doors and NO side panels.
'EXP' version is an expansion
model for when several cabinets
are bayed together
4 interior vertical posts with
unthreaded square hole
openings
Standard 24" width for
optimizing floor space
Ships fully assembled
Massive front to rear ventilation
capacity
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors
MODEL NUMBER: SR48UBEXP
Description
SmartRack enclosures are designed for secure, high density server and networking applications in IT
environments. Designed with provisions to integrate cooling, power distribution and cable management,
SmartRack enclosures make ideal homes for mission-critical equipment. Vendor-neutral square hole/cage
nut mounting for guaranteed compatibility with all EIA-310-D compliant 19" equipment. Enclosures ship
fully assembled for rapid deployment and roll into place on heavy-duty casters. Toolless mounting slots
allow quick installation of PDUs and vertical cable managers. Adjustable mounting rails include an easyview depth index to eliminate time-consuming measurements. Lightweight modular doors provide safe,
convenient service access. Integrated baying tabs facilitate combining enclosures in rows for standard
data center baying applications. SmartRack enclosures hold up to 3000 lbs (1360.8 kgs) and support
cooling, cable management, power distribution and monitoring features that keep critical servers and
network equipment operating nonstop. Perforated doors permit massive front to rear airflow that exceeds
servers manufacturer requirements. Enclosures are fully compatible with hot-aisle / cold-aisle data center
configurations.
Features
Ships fully assembled for rapid deployment and roll into place on heavy-duty pre-installed casters.
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 37 inches/94 cm (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
1/3
Cleveland, OH 44122
United States
service entry allowing the enclosure to be placed closer to a wall.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 600mm or 24" to match standard data center floor tiles.
Casters are pre-installed and support a rolling load capacity of 2250 lbs (1020.6 kgs), allowing the
enclosures to be pre-configured and rolled to the final installation location. Casters are removable.
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Compact design allows the enclosure to roll through standard height commercial doorways.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332151001
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
48U
Rack Depth
Standard
Factory Preset Rack Depth (in.)
27.75
Factory Preset Rack Depth (cm)
70.5
Factory Preset Rack Depth (mm)
705
Maximum Device Depth (cm)
93.98
Maximum Device Depth (in.)
37
Maximum Device Depth (mm)
940
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
95.00 x 26.00 x 45.00
Shipping Dimensions (hwd / cm)
241.30 x 66.04 x 114.30
Shipping Weight (lbs.)
267.00
Shipping Weight (kg)
121.11
2/3
Cleveland, OH 44122
United States
Unit Dimensions (hwd / in.)
89.000 x 23.630 x 43.000
Unit Dimensions (hwd / cm)
226.06 x 60.02 x 109.22
Unit Weight (lbs.)
211
Unit Weight (kg)
95.71
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“SR48UBEXP”相匹配的价格&库存,您可以联系我们找货
