1000 Eaton Boulevard
Cleveland, OH 44122
United States
45U SmartRack Deep and Wide Rack Enclosure
Cabinet with doors & side panels
MODEL NUMBER: SR45UBDPWD
Highlights
45" (1143mm) depth for extra
space need for mounting deep
equipment
30" (750mm) width for
optimizing airflow through
cabinet
Ships fully assembled
3000 lbs (1360.8 kgs) stationary
/ 2250 lbs (1020.6 kgs) rolling
load capacity
Locking, removable, reversible
front and rear doors; Locking,
removable side panels keyed
alike with doors
Pre-installed casters and
leveling feet
Meets all enclosure
requirements towards PCI DSS
(Payment Card Industry Data
Security Standard) Compliance
Package Includes
Description
The SR45UBDPWD is a DEEP and WIDE version of our standard 45U SmartRack. This enclosure is
1143mm deep (45") compared to the standard 1050mm deep (42"). This extra depth allows for high
density equipment installations. It allows extra space for moving the cable management back as well as
providing space for mounted equipment that has hot-swap, removable power supplies out the back of the
enclosure. It is also 750mm wide (30") compared to the standard 600mm wide (24"). This extra width
allows for high density equipment installations. It allows cable management and PDU mounting off to the
sides of the rack in order to keep these items out of the airflow for proper cooling.
The SR45UBDPWD features a massive front-to rear-ventilation capacity that meets or exceeds server
manufacturer requirements. Its integrated baying tabs make it easy to combine multiple enclosures in
rows for data center applications. This enclosure is also compatible with hot-aisle/cold-aisle
configurations.
With its locking, reversible, removable front and rear doors, and locking, removable side panels, the
SR45UBDPWD provides ultimate equipment safety. The side panels are half size for ease of removal and
reinstallation. The split rear door design allows the enclosure to be placed closer to a wall. The
SR45UBDPWD meets all requirements toward PCI DSS compliance.
The top panel of the SR45UBDPWD is vented to help remove warm air from the enclosure and draw in
cool air by convection. The top panel includes ports for cable routing, and can be quickly removed without
tools. To facilitate cable access, the SR45UBDPWD is open-bottom.
All components of the SR45UBDPWD are grounded to the enclosure frame. Front and rear threaded
grounding points are provided for connection to the facility earth ground. The removable front and rear
doors feature quick-release ground wires.
It houses 3000 lbs (1360.8 kgs) of standard 19-inch rack equipment in 45U. To simplify deployment, the
SR45UBDPWD comes with preinstalled casters that enable it to be easily maneuvered into the desired
location, where it can be secured by adjusting the preinstalled levelers. Note: the casters are intended for
minor position adjustments and are not designed for moving the enclosure over long distances.
The SR45UBDPWD comes with a 5-year product warranty. As part of the SmartRack family, the
SR45UBDPWD is compatible with Tripp Lite's extensive range of rackmount accessories, enabling you to
customize your solution to meet any requirement.
Features
Ships fully assembled for rapid deployment and roll into place on pre-installed casters, allowing the
enclosures to be pre-configured and rolled to the final installation location. Casters are removable.
Front and rear sets of equipment mounting rails adjust in 1/4" increments. Adjustment is quick and
convenient. The easy-view depth index ensures consistent rail placement without requiring timeconsuming measurements.
1/4
SR45UBDPWD Rack Enclosure
(4) Side panels
(4) Side panel locks
(2) Door & side panel keys
(50) M6 screws
(50) M6 cage nuts
(50) M6 washers
(1) Allen Wrench
Owner's Manual
Cleveland, OH 44122
United States
Toolless accessory mounting rails (2 rails per enclosure) include slots for quick installation of compatible
PDUs and vertical cable managers. Mounting slots are arranged in an industry-standard pattern
compatible with a wide variety of accessories. Each rail can accommodate two vertical PDUs or cable
managers side-by-side (four items per enclosure).
Enclosure includes mounting hardware of 50 pieces of M6 cage nuts and 50 pieces of M6 screws
Textured powder coat finish for tough resistance to environmental concerns such as deployment in
warehouses.
Massive front to rear ventilation capacity. 65+% open space in door perforation pattern meets or
exceeds server manufacturer requirements.
Maximum usable internal depth of 42 inches (front to rear rail).
Weight ratings of 3000 lbs (1360.8 kgs) stationary and 2250 lbs (1020.6 kgs) rolling.
Front door is locking, reversible and removable.
Rear doors are locking and reversible. Split rear door design reduces clearance requirements for
service entry allowing the enclosure to be placed closer to a wall.
Locking removable side panels are 'half size' to make them smaller and lighter improving ease of
installation and servicing. Two side panels per side (4 panels total). Side panels are keyed alike to the
front and rear doors.
Built in baying tabs allow enclosures to be combined securely in rows. Center-to-center width can be set
at 750mm or 30".
Leveling feet extend to allow enclosure to be positioned on uneven floors. Levelers are removable.
Convenient grounding system. All components are grounded to the enclosure frame which includes
multiple connections for facility ground. Front and rear doors include quick-release ground wires.
Open bottom for cable access.
Top panel has generous cable access holes. Panel can be removed toollessly in seconds without
having to disconnect cables first.
Included stabilizing brackets are used for shipment and can be reattached at the bottom of the
enclosure frame on the inside or outside of the rack.
Meets all enclosure requirements towards PCI DSS (Payment Card Industry Data Security Standard)
Compliance
Compatibility with airflow optimization accessories as well as cable management accessories.
Specifications
OVERVIEW
UPC Code
037332175243
Device Compatibility
Patch Panel; Network Switch; UPS; Server
Rack Type
Enclosure
PHYSICAL
Color
Black
Rack Height
45U
Rack Depth
Deep
Factory Preset Rack Depth (in.)
28.125
Factory Preset Rack Depth (cm)
71.4
Factory Preset Rack Depth (mm)
714
2/4
Cleveland, OH 44122
United States
Maximum Device Depth (cm)
106.68
Maximum Device Depth (in.)
42
Maximum Device Depth (mm)
1,067
Minimum Device Depth (cm)
10.16
Minimum Device Depth (in.)
4
Minimum Device Depth (mm)
102
Shipping Dimensions (hwd / in.)
90.30 x 32.00 x 52.75
Shipping Dimensions (hwd / cm)
229.36 x 81.28 x 133.98
Shipping Weight (lbs.)
420.00
Shipping Weight (kg)
190.51
Unit Dimensions (hwd / in.)
83.750 x 29.530 x 48.500
Unit Dimensions (hwd / cm)
212.725 x 75.01 x 123.19
Unit Weight (lbs.)
370
Unit Weight (kg)
167.83
Weight Capacity - Rolling (kg)
1,021
Weight Capacity - Rolling (lbs.)
2250
Weight Capacity - Stationary (kg)
1,361
Weight Capacity - Stationary (lbs.)
3000
Number of Vertical Mounting Rails
4
FEATURES & SPECIFICATIONS
Grounding Lug
Front and Back door frames
Built-in Cable Management
Yes
Extra Wide
Yes
Pre-Installed Casters
Yes
STANDARDS & COMPLIANCE
Product Certifications
UL 60950-1
Product Compliance
RoHS; CE (Europe); UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SR45UBDPWD”相匹配的价格&库存,您可以联系我们找货
