1598RCBK
1598RCBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 7.07"L X 6.06"W
1598RCBK 数据手册
2 Bottom View of Assembly A 1 Front Face SECTION A-A (Side View Inside Assembly) n10.90 n 8.32 [.429] (Bottom Boss n) [.328] (Top Boss n) Top Cover Detail View of Boss (Located on Top and Bottom Cover) n 8.00 179.50 [7.067] [.315] B B P.C. Board 3.85 [.152] 46.00 [1.811] (Inner Box Height) A 132.21 [5.205] SECTION B-B (Inside of Bottom Cover) End View of Assembly B 1.91 [.075] (PCB dist from inner wall) Bottom Cover 154.00 [6.063] .50 [.020] (PCB Dist from end panel) End Panel B 144.49 [5.689] (Inner Box Width) P.C. Board Aligned on Bosses 51.00 [2.008] NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. 167.90 [6.610] (Inner Box Length) 1598C Instrument Case Maximum P.C. Board Size 23.24 [.915] Front/Rear Panel (Dashed Line Indicates Viewing Area) 142.50 [5.610] (Viewing Area) A 43.00 [1.693] (Viewing Area) 45.50 [1.791] 146.60 [5.772] 1.65 [.065] 2 140.67 [5.538] 94.20 [3.709] 11.33 [.446] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com 77.50 [3.051] 11.90 [.469] P.C. Board (Not Supplied) 10.48 [.413] n3.51 X 4 [.138] FLAME RETARDANT ABS (UL94-VO) 1598CBK Bla ck Enclosure w ith Alum inum Pa ne ls 1598CGY Gre y Enclosure w ith Alum inum Pa ne ls 1598RCBK Bla ck EMI/RFI Shie lde d NON-FLAME RETARDANT GPABS (UL94-HB) 1598CSGY Gre y Enclosure w ith Alum inum Pa ne ls 1598CSGYPBK Gre y Enclosure w ith Bla ck Pla stic Pa ne ls ACCESSORIES 1598PLCBK Bla ck Pla stic Pa ne ls 1421T2 Rubbe r Fe e t (Pkg 24) For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] 1598C 144.25 [5.679] 166.90 [6.571] 1 A
1598RCBK 价格&库存
很抱歉,暂时无法提供与“1598RCBK”相匹配的价格&库存,您可以联系我们找货
