ROB-12404
ROB-12404
    SPARKFUNELECTRONICS
    SETSCREWHUB5MMBORE
ROB-12404 数据手册
 Set Screw Hub - 5mm Bore ROB - 12404  images are CC BY-NC-SA 3.0 Description: Set screw hubs offer a cheap way to attach hub mount gears or wheels to a shaft. The hub offers 4 equally spaced 6-32 tapped holes utilizing the 0.77" hub pattern and is precision machined from 6061 T6 aluminum. The set-screw is 10-32 and uses a 3/32” hex key. This hub has a 5mm bore. Actobotics is a robotics building system based around extruded aluminum channels, gears, precision shafts, and ball bearings. Thanks to the two standardized hole patterns, nearly all Actobotics components can be intuitively connected together. The wide range of components makes building complex electromechanical prototypes or finished projects a reality. https://www.sparkfun.com/products/12404 2/5/2016
ROB-12404 价格&库存
很抱歉,暂时无法提供与“ROB-12404”相匹配的价格&库存,您可以联系我们找货
