1000 Eaton Boulevard
Cleveland, OH 44122
United States
750W PowerVerter RV Inverter/Charger with
Hardwire Input/Output
MODEL NUMBER: RV750ULHW
Highlights
12V DC or 120V AC input; 120V
AC output (hardwired)
750 watts continuous, 1125
watts OverPower™ and 1500
watts DoubleBoost™ inverter
output
3 stage, 11/45 amp selectable
wet/dry cell battery charger
Built-in Isobar® premium AC
surge protection and Auto
Transfer Switching option for
battery backup / UPS operation
Tested to power inverter
standards UL458 (USA) and
CSA (Canada)
High reliability large-transformer
design with protected DC and
AC wiring terminals
Package Includes
Description
Tripp Lite's RV750ULHW Inverter/Charger is the quiet alternative to gas generators—with no fumes, fuel
or noise to deal with! It provides equipment with utility- or generator-supplied AC electricity filtered through
premium ISOBAR surge protection. This DC-to-AC inverter with automatic line-to-battery transfer and
integrated charging system serves as an extended run UPS, a standalone power source or an automotive
inverter suitable for rugged RV applications. Supplies up to 750 watts of continuous 120V AC power from
any 12V DC battery or automotive DC source. OverPower inverter output feature temporarily provides up
to 150% of the continuous output for 1-60 minutes and DoubleBoost TM inverter output feature delivers up
to 200% of the continuous output for up to 10 seconds, providing the extra power needed to cold start
heavy-duty tools and motorized equipment. When hardwire AC input is energized, commercial power
passes through to connected equipment and the battery set is recharged via 3 stage, selectable 11/45
amp charging system. In UPS mode, the APS system responds to blackouts and voltage fluctuations with
a near instantaneous automatic transfer to battery-derived AC output. Includes a set of high current DC
input terminals for simple installation (user supplies batteries and cabling - see owner's manual for
recommendations). Passes sine wave utility or generator power during battery charging and UPS line
power operation, plus efficient PWM sine wave AC output in inverter and UPS backup modes. Reliable
large transformer design, with frequency control powers resistive electronic loads or large inductive
motors, compressors and other items with high current needs on startup. Optional APSRM4 wired remote
power switch with full status LEDs provides remote power inverter on/off switching and continuous status
information (APSRM4 sold separately). Supports an unlimited amount of runtime with any number of usersupplied batteries connected. Highly adaptable to a variety of applications and site conditions with
adjustable charger settings for wet/gel battery types and selectable line to battery power transfer voltages.
NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at
125a should be positioned no more than 18" from the RV750ULHW's battery in the positive line.
Features
RV750ULHW serves as an automotive or stationary DC-to-AC inverter with automatic line-to-battery
transfer and integrated battery charger
Supports 120V AC output from a 120V AC line power source or 12V DC battery source
16.6 millisecond automatic transfer between line and battery power supports UPS protection during
blackouts and voltage fluctuations for equipment compatible with a one cycle transfer time
750 watts continuous AC output in inverter mode, 750 watts continuous AC output in AC mode
Double Boost™ inverter output supports momentary startup loads up to 200% of the continuous rating
1/5
Instruction manual with warranty
information
Cleveland, OH 44122
United States
OverPower™ inverter output supports longer duration overloads to 150% for 1-60 minutes under ideal
battery and temperature conditions. (For best results, utilize OverPower usage for as short of a duration
as possible, ensure battery bank and cabling is able to provide full nominal DC voltage under load and
allow inverter/charger to fully cool before and after OverPower usage.)
3 stage, selectable 11/45 amp battery charger with adjustable settings for wet/gel battery types offers
fast, reliable battery recharging
Protected hardwire bolt-down input lugs safely accept heavy gauge input wiring from attached battery
bank
Protected hardwire output passes 120V line power or inverter output through to connected equipment
Reliability enhanced large-transformer design tested to UL (USA) and CSA (Canada) standards
Moisture-resistant construction enables vehicular or marine operation in high humidity environments
3 position operating mode switch supports "AUTO" mode to enable automatic transfer between DC and
AC modes, CHARGE-ONLY to maintain a full battery charge when AC is present without auto transfer
and SYSTEM OFF settings
Set of six front panel LEDs display AC/DC operational modes, overload status, DC voltage level,
shutdown status and system fault status
Set of 4 configuration dipswitches support wet/gel battery charging profiles, adjustable 135/145V high
voltage auto transfer during overvoltages and selectable 75/85/95/105V AC low voltage auto transfer
during brownouts
Set of 4 additional configuration dipswitches support 4 levels of charger limiting relative to output load
size, a battery equalization program and battery charger low/high/off settings
Resettable 10A charger AC input breaker and automatic 2 speed cooling fan protect the inverter from
load and temperature related failures
Grounding lug properly connects the inverter/charger system to earth ground or vehicle grounding
system
Automatic overload and thermal shutoff safely turns off inverter as excessive loads or overheating
conditions develop
Front panel remote control connector enables remote off/on switching (requires APSRM4 switch
accessory). Optional APSRM4 accessory also includes user configurable jacks to support inverter
shutoff or startup as a vehicle ignition is engaged
Load sensing control dial enables adjustable load threshold required to automatically turn the inverter
on and off in DC mode as load conditions change
Specifications
OVERVIEW
UPC Code
037332121639
INPUT
Nominal Input Voltage(s) Supported
120V AC
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 72A at 12V DC. AC INPUT: 29 amps at 120V AC with full inverter and charger
load (9.3A max charger-only / combined input load to support charger and AC output is automatically controllable to
66%-33%-0% based on AC output.
Recommended Electrical Service
DC INPUT: Requires 12V DC input source capable of delivering 73A for the required duration (when used at full
continuous capacity - DC requirements increase during Over-Power and Double-Boost operation).
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: hardwire
Input Cord Length Details
DC INPUT: User supplies cabling. 6 gauge or larger (see manual). AC INPUT: hardwire
Voltage Compatibility (VAC)
120
2/5
Cleveland, OH 44122
United States
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
Hardwire
Continuous Output Capacity (Watts)
750
Peak Output Capacity (Watts)
1500
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 120 V AC (+/-5%).
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 10A input breaker dedicated to the charging system
BATTERY
Expandable Battery Runtime
Runtime is expandable with any number of user supplied wet, gel or SLA batteries
Expandable Runtime
Yes
Expandable Runtime Description
DC System Voltage (VDC)
12
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
11A / 45A (selectable)
LVC (Low Voltage Cut-Off)
10VDC +/-3%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
Switches
3-position on/off/remote switch enables simple on/off power control plus auto/remote setting that enables distant
on/off control of the inverter system when used in conjunction with APSRM4 accessory (sold separately) in inverter mode. In AC uninterruptibl
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
450
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
3/5
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
12.40 x 10.50 x 10.70
Shipping Dimensions (hwd / cm)
31.50 x 26.67 x 27.18
Shipping Weight (lbs.)
18.60
Shipping Weight (kg)
8.44
Unit Dimensions (hwd / in.)
7.000 x 8.750 x 9.000
Unit Dimensions (hwd / cm)
17.78 x 22.23 x 22.86
Unit Weight (lbs.)
16
Unit Weight (kg)
7.26
ENVIRONMENTAL
Relative Humidity
0%-95% Non-Condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical - compatible with many computers - verify transfer time compatibility of loads for UPS
applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 75V (user adjustable to 85, 95,
105V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 145V
FEATURES & SPECIFICATIONS
Load Sensing
Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off
and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of
any level, up to 150 watts.
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 458
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
30-month limited warranty
(International)
1-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“RV750ULHW”相匹配的价格&库存,您可以联系我们找货
