1000 Eaton Boulevard
Cleveland, OH 44122
United States
1000W PowerVerter RV Inverter/Charger with
Hardwire Input/Output
MODEL NUMBER: RV1012ULHW
Highlights
12V DC or 120V AC input; 120V
AC output (hardwired)
1000 watts continuous, 1500
watts OverPower™ and 2000
watts DoubleBoost™ inverter
output
3 stage, 14/55 amp selectable
wet/dry cell battery charger
Built-in Isobar® premium AC
surge protection and Auto
Transfer Switching option for
battery backup / UPS operation
Tested to power inverter
standards UL458 (USA) and
CSA (Canada)
High reliability large-transformer
design with protected DC and
AC wiring terminals
Package Includes
Description
Tripp Lite's RV1012ULHW Inverter/Charger is the quiet alternative to gas generators - with no fumes, fuel
or noise to deal with! It provides equipment with utility- or generator-supplied AC electricity filtered through
premium ISOBAR surge protection. This DC-to-AC inverter with automatic line-to-battery transfer and
integrated charging system serves as an extended run UPS, a standalone power source or an automotive
inverter suitable for rugged RV applications. Supplies up to 1000 watts of continuous 120V AC power from
any 12V DC battery or automotive DC source. OverPower TM inverter output feature temporarily provides
up to 150% of the continuous output for 1-60 minutes, and DoubleBoost TM inverter output feature
delivers up to 200% of the continuous output for up to 10 seconds, providing the extra power needed to
cold start heavy-duty tools and motorized equipment. When hardwire AC input is energized, commercial
power passes through to connected equipment and the battery set is recharged via 3 stage, selectable
14/55 amp charging system. In UPS mode, the APS system responds to blackouts and voltage
fluctuations with a near instantaneous automatic transfer to battery-derived AC output. Includes a set of
high current DC input terminals for simple installation (user supplies batteries and cabling - see owner's
manual for recommendations). Passes sine wave utility or generator power during battery charging and
UPS line power operation, plus efficient PWM sine wave AC output in inverter and UPS backup modes.
Reliable large transformer design, with frequency control powers resistive electronic loads or large
inductive motors, compressors and other items with high current needs on startup. Optional APSRM4
wired remote power switch with full status LEDs provides remote power inverter on/off switching and
continuous status information (APSRM4 sold separately). Supports an unlimited amount of runtime with
any number of user-supplied batteries connected. Highly adaptable to a variety of applications and site
conditions with adjustable charger settings for wet/gel battery types and selectable line to battery power
transfer voltages.
NOTE: To protect against high current draw that may occur during inverter failure, a fuse link rated at
175a should be positioned no more than 18" from the RV1012ULHW's battery in the positive line.
1/5
Instruction manual with warranty
information
Cleveland, OH 44122
United States
Features
RV1012ULHW serves as an automotive or stationary DC-to-AC inverter with automatic line-to-battery
transfer and integrated battery charger
Supports 120V AC output from a 120V AC line power source or 12V DC battery source
16.6 millisecond automatic transfer between line and battery power supports UPS protection during
blackouts and voltage fluctuations for equipment compatible with a one cycle transfer time
1000 watts continuous AC output in inverter mode, 1440 watts continuous AC output in AC mode
Double Boost inverter output supports momentary startup loads up to 200% of the continuous rating for
up to 10 seconds
OverPower inverter output supports longer duration overloads to 150% for 1-60 minutes under ideal
battery and temperature conditions. (For best results, utilize OverPower usage for as short of a duration
as possible, ensure battery bank and cabling is able to provide full nominal DC voltage under load and
allow inverter/charger to fully cool before and after OverPower usage.)
3 stage, selectable 14/55 amp battery charger with adjustable settings for wet/gel battery types offers
fast, reliable battery recharging
Protected hardwire bolt-down input lugs safely accept heavy gauge input wiring from attached battery
bank
Protected hardwire output passes 120V line power or inverter output through to connected equipment
Reliability enhanced large-transformer design tested to UL (USA) and CSA (Canada) standards
Moisture-resistant construction enables vehicular or marine operation in high humidity environments
3 position operating mode switch supports "AUTO" mode to enable automatic transfer between DC and
AC modes, CHARGE-ONLY to maintain a full battery charge when AC is present without auto transfer
and SYSTEM OFF settings
Set of six front panel LEDs display AC/DC operational modes, overload status, DC voltage level,
shutdown status and system fault status
Set of 4 configuration dipswitches support wet/gel battery charging profiles, adjustable 135/145V high
voltage auto transfer during overvoltages and selectable 75/85/95/105V AC low voltage auto transfer
during brownouts
Set of 4 additional configuration dipswitches support 4 levels of charger limiting relative to output load
size, a battery equalization program and battery charger low/high settings
Resettable 12A charger AC input breaker and resettable 12A AC output breaker and automatic 2 speed
cooling fan protect the inverter from load and temperature related failures
Grounding lug properly connects the inverter/charger system to earth ground or vehicle grounding
system
Automatic overload and thermal shutoff safely turns off inverter as excessive loads or overheating
conditions develop
Front panel remote control connector enables remote off/on switching (requires APSRM4 switch
accessory). Optional APSRM4 accessory also includes user configurable jacks to support inverter
shutoff or startup as a vehicle ignition is engaged
Load sensing control dial enables adjustable load threshold required to automatically turn the inverter
on and off in DC mode as load conditions change
Includes battery temperature sensor with 20 foot cable to prolong battery life by adjusting the charge
level based on battery temperature
Automatic Generator Starter jack enables user configuration of automatic generator startup as inverter
batteries drop to 11.5VDC and generator shutoff as inverter batteries are recharged to 14.1VDC
Specifications
OVERVIEW
UPC Code
037332117755
2/5
Cleveland, OH 44122
United States
INPUT
Nominal Input Voltage(s) Supported
120V AC
Maximum Input Amps / Watts
DC INPUT: Full continuous load - 95A at 12V DC. AC INPUT: 20 amps at 120V AC with full inverter and charger
load (12A max charger-only / combined input load to support charger and AC output is automatically controllable to
66%-33%-0% based on AC output lo
Recommended Electrical Service
DC INPUT: Requires 12V DC input source capable of delivering 95A for the required duration (when used at full
continuous capacity - DC requirements increase during Over-Power and Double-Boost operation). For automotive
applications, professional hardwire
Input Connection Type
DC INPUT: Set of 2 DC bolt-down terminals. AC INPUT: hardwire
Input Cord Length Details
DC INPUT: User supplies cabling. 4 gauge or larger (see manual). AC INPUT: hardwire
Voltage Compatibility (VAC)
120
Voltage Compatibility (VDC)
12
OUTPUT
Frequency Compatibility
60 Hz
Pure Sine Wave Output
No
Nominal Output Voltage(s)
Supported
120V
Output Receptacles
Hardwire
Continuous Output Capacity (Watts)
1000
Peak Output Capacity (Watts)
2000
Output Voltage Regulation
LINE POWER (AC): Maintains 120V nominal sine wave output from line power source. INVERTER POWER (AC):
Maintains PWM sine wave output voltage of 120 V AC (+/-5%).
Output Frequency Regulation
60 Hz (+/- 0.3 Hz)
Overload Protection
Includes 12A input breaker dedicated to the charging system and 12A output breaker for AC output loads
BATTERY
Expandable Runtime
Yes
Expandable Runtime Description
Runtime is expandable with any number of user supplied wet or gel type batteries
DC System Voltage (VDC)
12
Battery Pack Accessory (Optional)
98-121 sealed lead acid battery (optional)
Battery Charge
14A / 55A (selectable)
LVC (Low Voltage Cut-Off)
10V DC +/-3%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LEDs
Set of 6 LEDs offer continuous status information on load percentage (6 levels reported) and battery charge level (7
levels reported). See manual for sequences.
3/5
Cleveland, OH 44122
United States
Switches
3-position on/off/remote switch enables simple on/off power control plus auto/remote setting that enables distant
on/off control of the inverter system when used in conjunction with APSRM4 accessory (sold separately) in inverter mode. In AC uninterruptible power
mode, auto/remote setting enables automatic transfer from line power to battery power, maintaining continuous AC
power to connected loads.
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
450
PHYSICAL
Material of Construction
Polycarbonate
Cooling Method
Multi-speed fan
Form Factors Supported
Mounting slots enable permanent placement of inverter on any horizontal surface (see manual for additional
mounting information)
Shipping Dimensions (hwd / in.)
12.80 x 14.50 x 21.20
Shipping Dimensions (hwd / cm)
32.51 x 36.83 x 53.85
Shipping Weight (lbs.)
31.00
Shipping Weight (kg)
14.06
Unit Dimensions (hwd / in.)
7.000 x 10.500 x 16.250
Unit Dimensions (hwd / cm)
17.78 x 26.67 x 41.28
Unit Weight (lbs.)
27
Unit Weight (kg)
12.25
ENVIRONMENTAL
Relative Humidity
0-95% non-condensing
LINE / BATTERY TRANSFER
Transfer Time (Line Power to
Battery Mode)
16.6 milliseconds (typical - compatible with many computers - verify transfer time compatibility of loads for UPS
applications)
Low Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage drops to 75V (user adjustable to 85, 95,
105V - see manual)
High Voltage Transfer to Battery
Power
In AC "auto" mode, inverter/charger switches to battery mode as line voltage increases to 135V (user adjustable to
145 - see manual)
FEATURES & SPECIFICATIONS
Load Sensing
Optional load sense function enables automatic inverter shutoff and startup as connected equipment is powered off
and on. Front panel load sense potentiometer can be set to shutoff or turn on inverter power in response to loads of
any level, up to 150 watts.
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
30-month limited warranty
(International)
1-year limited warranty
4/5
Cleveland, OH 44122
United States
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“RV1012ULHW”相匹配的价格&库存,您可以联系我们找货
