SMART2200NET
SMART2200NET
    TRIPPLITE
    UPS2200VA1700W6OUTW/SOFTWARE
SMART2200NET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.7kW Line-Interactive UPS, Tower, Extended run, 3 DB9 ports MODEL NUMBER: SMART2200NET Highlights ● 2.2kVA / 2200VA line interactive, extended-run tower UPS ● 120V output, Corrects brownouts and overvoltages from 87V to 140V ● 3 DB9 communication ports (1 RS232 / 2 contact-closure) ● Front panel status LEDs with load and battery capacity display ● 2 independently switchable output load banks ● NEMA 5-15P input, 6 NEMA 515R outlets Package Includes Description Tripp Lite's SMART 2200NET intelligent, line interactive large tower UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 27 minutes half load runtime and 11 minutes fully loaded. Runtime is expandable with optional BP24V28-2U (limit 1) and BP24V70-3U external battery packs. 2200VA/1700 watt power handling capability supports a variety of networking, telecom and other sensitive electronic applications. Includes 6 protected outlets. Supports remote monitoring of UPS and site power conditions via built-in RS-232 enabled monitoring port, plus standard UPS monitoring via 2 built in contact closure ports. PowerAlert UPS monitoring and unattended shutdown software is available via free download. Built-in audible alarm and front panel LEDs indicate line power, battery power, battery charge level, load level, plus voltage regulation status. Network grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Features ● SMART 2200NET line interactive UPS offers battery derived AC output during power outages, voltage regulation during brownouts and overvoltages, plus network-grade AC surge suppression ● 2200VA/1700 watt power handling capability supports a variety of networking, telecom and other sensitive electronic devices ● Large internal batteries offer runtimes of 27 minutes at half load (1100VA/850 watts) and 11 minutes at full load (2200VA/1700 watts) ● Runtime is further expandable with optional external BP24V28-2U (limit 1) and BP24V70-3U (multi-pack compatible) battery packs ● Intelligent battery management system extends battery life ● Automatic Voltage Regulation (AVR) circuits maintain 120V nominal output over an input voltage range of 87-140V ● Includes 6 fully protected NEMA 5-15R outlets with 2 single outlet load banks that can be individually powered off and back on again via software interface ● DB9 ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Offers simultaneous monitoring of up to 3 directly connected devices through included DB9 contact closure and RS-232 enabled interfaces ● In addition to the contact closure monitoring of on battery, low battery and power restored messaging, built-in RS-232 interface supports messaging of UPS and line power status, including AC line voltage, 1/5 ● SMART2200NET UPS System ● Three 6ft network cables ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States DC battery voltage and remaining battery capacity ● Supports activate self-test and UPS output power control for delayed or immediate reboot of connected equipment ● Diagnostic LEDs (indicate 17 performance conditions) Specifications OVERVIEW UPC Code 037332032041 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 15A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 8 UPS Input Cord Length (m) 2.4 Recommended Electrical Service 20A 120V Input Cord Length (ft.) 8 Input Cord Length (m) 2.44 OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1700 Output Capacity (kW) 1.7 Output Capacity Details Output is reduced to 1200W maximum with 1-2 external battery packs and 800W maximum with 3 or more external battery packs Power Factor 0.8 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -13% / +5% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable single outlet 5-15R load banks 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Runtime Full Load (min.) 11 Runtime Half Load (min.) 27 Expandable Runtime Yes External Battery Pack Compatibility  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 9 hours from 10% to 90% (typical, full load discharge) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 87 to 140 Overvoltage Correction Input voltages between 127 and 140 are reduced by 12% Undervoltage Correction Input voltages between 95 and 105 are boosted by 10% Severe Undervoltage Correction Input voltages between 87 and 94 are boosted by 22% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; set of 4 rear-panel switches control system enable and contact closure port inverter shutoff commands Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 720 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Depth (mm) 318 Primary UPS Height (mm) 432 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 13.75 x 16.50 x 22.50 Shipping Dimensions (hwd / cm) 34.92 x 41.91 x 57.15 Shipping Weight (lbs.) 82.16 Shipping Weight (kg) 37.27 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 43.18 x 22.86 x 31.75 UPS Power Module Dimensions (hwd, in.) 17 x 9 x 12.5 UPS Power Module Weight (kg) 36.29 UPS Power Module Weight (lbs.) 80 Unit Weight (lbs.) 80.0000 Unit Weight (kg) 36.29 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 59 Battery Mode BTU / Hr. (Full Load) 867 AC Mode Efficiency Rating (100% Load) 99% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; contact closure communications via two additional DB9 ports (3 total) PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable 3 DB9 cables included Network Management Card Description Network management not supported Communications Interface Contact closure; DB9 Serial LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 87 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States High Voltage Transfer to Battery Power (Setpoint) 140 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART2200NET 价格&库存
很抱歉,暂时无法提供与“SMART2200NET”相匹配的价格&库存,您可以联系我们找货
