1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 3kVA 2.4kW Line-Interactive UPS,
Tower, Extended Run, 3 DB9 ports
MODEL NUMBER: SMART3000NET
Highlights
3kVA / 3000VA / 2400W line
interactive, extended-run tower
UPS
120V output, Corrects
brownouts and overvoltages
from 87V to 140V
3 DB9 ports (1 RS232 / 2
contact-closure)
Front panel status LEDs with
load and battery capacity
display
2 independently switchable
output load banks
NEMA L5-30P input; 4 NEMA 515/20R & 4 NEMA 5-15R outlets
Package Includes
Description
Tripp Lite's SMART3000NET intelligent, line interactive large tower UPS system protects servers,
networking accessories and telecommunications equipment from blackouts, voltage fluctuations and
transient surges. Large internal batteries offer 23 minutes half load runtime and 7 minutes fully loaded.
Runtime is expandable with optional BP24V28-2U (limit 1) and BP24V70-3U (multi-pack compatible)
external battery packs. 3000VA/2400 watt power handling capability supports a variety of networking,
telecom and other sensitive electronic applications. Includes 8 protected outlets. Supports remote
monitoring of UPS and site power conditions via built-in RS-232 enabled monitoring port, plus standard
UPS monitoring via 2 built in contact closure ports. PowerAlert UPS monitoring software is available for
free download. Built-in audible alarm and front panel LEDs indicate line power, battery power, battery
charge level, load level and voltage regulation status. Network grade AC surge suppression protects
equipment from damage and performance problems resulting from transient surges.
Features
SMART 3000NET line interactive UPS offers battery derived AC output during power outages, voltage
regulation during brownouts and overvoltages, plus network-grade AC surge suppression
3000VA/2400 watt power handling capability supports a variety of networking, telecom and other
sensitive electronic devices
Large internal batteries offer runtimes of 23 minutes at half load (1500VA/1200 watts) and 7 minutes at
full load (3000VA/2400 watts)
Runtime is further expandable with optional external BP24V28-2U (limit 1) and BP24V70-3U (multi-pack
compatible) battery packs
Intelligent battery management system extends battery life
Automatic Voltage Regulation (AVR) circuits maintain 120V nominal output over an input voltage range
of 87-140V
Includes 8 fully protected outlets (4 NEMA 5-15R & 4 NEMA 5-15/20R) with 2 single outlet load banks
that can be individually powered off and back on again via software interface
PowerAlert UPS monitoring and unattended shutdown software enables configurable network broadcast
messaging, email notification, event logging and running user defined script commands
Offers simultaneous monitoring of up to 3 directly connected devices through included DB9 contact
closure and RS-232 enabled interfaces, or the monitoring of any number of additional servers over IP
with PowerAlert UPS monitoring software (available for free download at
tripplite.eaton.com/products/power-alert)
1/5
SMART 3000NET UPS System
3 DB9 network cables
Instruction manual
Cleveland, OH 44122
United States
In addition to the contact closure monitoring of on battery, low battery and power restored messaging,
built-in RS-232 interface supports messaging of UPS and line power status, including AC line voltage,
DC battery voltage and remaining battery capacity
Supports activate self-test and UPS output power control for delayed or immediate reboot of connected
equipment
Diagnostic LEDs (indicate 17 performance conditions)
Specifications
OVERVIEW
UPC Code
037332032065
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
22A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
UPS Input Cord Length (ft.)
8
UPS Input Cord Length (m)
2.4
Recommended Electrical Service
30A 120V
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2400
Output Capacity (kW)
2.4
Output Capacity Details
Output is reduced to 1600W maximum with 1 external battery pack and 1200W maximum with 2 or more external
battery packs
Power Factor
0.8
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-13% / +5%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Load Management Receptacles
Two switchable single-outlet 5-15R load banks
Output Circuit Breakers
15A branch rated (x2) - each breaker protects 4 outlets
Output AC Waveform (AC Mode)
Sine wave
2/5
Cleveland, OH 44122
United States
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(4) 5-15R; (4) 5-15/20R
Individually Controllable Load Banks
Yes
BATTERY
Runtime Full Load (min.)
7
Runtime Half Load (min.)
23
Expandable Runtime
Yes
External Battery Pack Compatibility
BP24V28-2U (limit 1); BP24V70-3U (multi-pack compatible)
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 9 hours from 10% to 90% (typical, full load discharge)
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 87 to 140
Overvoltage Correction
Input voltages between 127 and 140 are reduced by 12%
Undervoltage Correction
Input voltages between 95 and 105 are boosted by 10%
Severe Undervoltage Correction
Input voltages between 87 and 94 are boosted by 22%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; set of 4 rear-panel switches control
system enable and contact closure port inverter shutoff commands
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
3/5
Cleveland, OH 44122
United States
Primary UPS Depth (mm)
318
Primary UPS Height (mm)
432
Primary UPS Width (mm)
229
Shipping Dimensions (hwd / in.)
16.50 x 12.60 x 21.80
Shipping Dimensions (hwd / cm)
41.91 x 32.00 x 55.37
Shipping Weight (lbs.)
96.60
Shipping Weight (kg)
43.82
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
43.18 x 22.86 x 31.75
(hwd, in.)
17 x 9 x 12.5
UPS Power Module Weight (kg)
40.37
UPS Power Module Weight (lbs.)
89
Unit Weight (lbs.)
80.0000
Unit Weight (kg)
36.29
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
83
Battery Mode BTU / Hr. (Full Load)
1225
AC Mode Efficiency Rating (100%
Load)
99%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions; contact closure communications via two additional
DB9 ports (3 total)
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
3 DB9 cables included
Network Management Card
Description
Network management not supported
Communications Interface
Contact closure; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
4 ms. typical
Low Voltage Transfer to Battery
Power (Setpoint)
87
4/5
Cleveland, OH 44122
United States
High Voltage Transfer to Battery
Power (Setpoint)
140
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMART3000NET”相匹配的价格&库存,您可以联系我们找货
