1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 3kVA 2.25kW Line-Interactive
UPS, Tower, Extended Run, Network Card
Options, USB, DB9 Serial
Highlights
3kVA / 3000VA line interactive
tower UPS system
120V nominal output during
brownouts to 79V and
overvoltages to 147V
Front panel status LEDs with
load and battery capacity level
display
USB, RS232, EPO and slot for
Network Management Card
options
NEMA L5-30P input; 7 NEMA 515R, 2 5-15/20R & 1 L5-30R
outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SMART3000VS
Package Includes
Description
Tripp Lite's SMART 3000VS intelligent, line interactive UPS with expandable runtime protects server,
networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges.
Small footprint, tower UPS system occupies only 106 square inches of floorspace with a height of only
14.25 inches. Large capacity 3000 VA/2250 watt rated UPS system offers 4 minutes runtime at full load
and 14 minutes at half load during power failures. Runtime is expandable with optional external battery
packs. Line interactive voltage regulation corrects brownouts as low as 79V and overvoltages as high as
147V to fully regulated 120V nominal output for smooth continuous operation of connected equipment.
Includes a total of 10 outlets, 3 of which can be individually powered off and back on via software interface
to selectively reboot remote equipment or shed less critical loads to extend battery runtime for more
critical loads. Includes slot for Network Management Card option. Also includes 2 DB9 and 2 USB
enhanced monitoring ports for unattended shutdown, remote control and monitoring of UPS system and
power data. Ships in attractive gray color scheme. Compatible with Tripp Lite's PowerAlert and Watchdog
service software.
Features
3000VA/2250 watt output capacity accommodates a variety of server, networking and telecom devices
High power density 3kVA UPS system occupies only 106 square inches of floorspace with a height of
only 14.25 inches
Compatible with North American 120V/60 Hz power as found in the USA, Canada and Mexico
Offers 4 minutes runtime with a full load of 3000VA and 14 minutes with a half load of 1500VA
Runtime is expandable with BP48V60RT-3U and BP48V27-2US external battery packs
Intelligent battery management system extends battery life
Line interactive voltage regulation corrects severe brownouts and overvoltages from 79 to 147v back to
normal 120v levels without using battery power
10 total outlets (7 NEMA5-15R; 2 NEMA5-15/20R; 1 L5-30R)
Includes NEMA L5-30P locking 30 amp input plug connection
Notification of system status via 5 LEDs and multi-function audible alarms
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
1/6
SMART 3000VS UPS System
USB & DB9 Cables
Instruction manual
Cleveland, OH 44122
United States
4 built-in communications ports (2-DB9, 2-USB) for remote monitoring and unattended shutdown
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and
SNMPWEBCARD
Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically
restarting them and rebooting completely locked computers by automatically switching UPS power off
and back on again
Communication ports support on battery, low battery, power restored, AC line voltage, DC battery
voltage, load percentage, battery charge current, battery capacity, internal UPS temperature and line
frequency status messaging. Interface supports timed inverter shutoff after unattended shutdown,
activate self-test and 10 second reboot of connected equipment
3 individual customized load management receptacles can be individually powered off and back on
again via software interface to reboot remote equipment or perform "load shedding" of less critical loads
to extend battery runtime for the most critical equipment
Built-in Emergency Power Off (EPO) interface supports emergency shutoff in large facilities
Hot-swappable/user replaceable batteries allow on-site battery replacement without powering off
connected equipment
UPS battery set ships fully assembled and ready for use, no time consuming, connection of individual
internal batteries by user is necessary
Specifications
OVERVIEW
UPC Code
037332115867
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
Input Circuit Breakers
30A
UPS Input Cord Length (ft.)
8
UPS Input Cord Length (m)
2.4
Recommended Electrical Service
120V 30A
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2250
Output Capacity (kW)
2.25
Output Capacity Details
Output is reduced to 1600 watts maximum when used with external battery packs
2/6
Cleveland, OH 44122
United States
Power Factor
0.8
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18% / +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Load Management Receptacles
Three switchable two-outlet 5-15R load banks
Output Circuit Breakers
20A branch rated (x2) - breaker 1 protects 5-20R, breaker 2 protects 5-15R, L5-30R is unbreakered
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(7) 5-15R; (2) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4 min. (2250W)
Runtime Half Load (min.)
14 min. (1125W)
Expandable Runtime
Yes
External Battery Pack Compatibility
BP48V27-2US (multi-pack compatible); BP48V60RT-3U (multi-pack compatible)
DC System Voltage (VDC)
48
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC54
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 79V to 147V
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 95 and 104 are boosted by 12%
Severe Undervoltage Correction
Input voltages between 79 and 94 are boosted by 24%
USER INTERFACE, ALERTS & CONTROLS
3/6
Cleveland, OH 44122
United States
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
305
Primary UPS Height (mm)
361
Primary UPS Width (mm)
234
Shipping Dimensions (hwd / in.)
19.30 x 15.40 x 16.30
Shipping Dimensions (hwd / cm)
49.02 x 39.12 x 41.40
Shipping Weight (lbs.)
65.20
Shipping Weight (kg)
29.57
UPS Housing Material
Polycarbonate
UPS Power Module Dimensions
(hwd, cm)
36.07 x 23.37 x 30.48
(hwd, in.)
14.2 x 9.2 x 12
UPS Power Module Weight (kg)
26.76
UPS Power Module Weight (lbs.)
59
Unit Weight (lbs.)
60.0000
Unit Weight (kg)
27.22
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
4/6
Cleveland, OH 44122
United States
AC Mode Efficiency Rating (100%
Load)
94%
Audible Noise
Audible Noise < 47dBA At Front Side 1 Meter
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
2 USB and 2 DB9 cables included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
79
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
