SMART3000CRMXL
SMART3000CRMXL
    TRIPPLITE
    UPSSMARTRACKMOUNTAVR
SMART3000CRMXL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 3kVA 2.88kW Line-Interactive Sine Wave UPS, 4U Short Depth, Extended Run, Network Card Options, USB, DB9 Highlights ● 3kVA / 3000VA / 2880W line interactive 4U reduced-depth rack/tower UPS, Sine Wave ● Reduced depth housing is ideal for 2 post rackmount installations ● 97% line-mode efficiency, 3 switched load banks, 2-post mounting kit ● USB, RS232 & EPO and slot for network management card options ● 120V NEMA L5-30P or Hardwire input, 8 NEMA 5-15/20R & 1 L530R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SMART3000CRMXL Package Includes Description Tripp Lites SmartPro Compact Rackmount Uninterruptible Power Supply (UPS) offers line interactive voltage regulation, network grade surge suppression and long lasting battery support for critical network hardware during blackouts and extended power failures. Special reduced-depth housing, larger internal batteries, higher rated wattage and included 2 post rackmount installation hardware makes these systems ideal for network and telecom wiring closets and other limited-space installations. Runtime is expandable with optional BP48V24-2U (limit 1), BP48V48RT4U (multi-pack compatible) and BP48V27-2US (multipack compatible) external battery packs. SMART3000CRMXL 4U rackmount 3000VA UPS offers battery-derived sine wave AC output during power failures and extreme voltage variations. Supports 3000VA/2880 watts when powered via included L5-30P input plug. Supports up to 3600VA/3600 watts when hardwired to a 120V 30A input source. Line interactive Automatic Voltage Regulation (AVR) provides two levels of voltage boost during brownouts and one level of voltage cut during overvoltage conditions to maintain regulated 120V nominal output over an input range of 83-145V. Includes NEMA L5-30P input plug (or hardwire input), L5-30R and 5-15/20R output receptacles. Network management interfaces support communications via USB, RS-232 and installed Network Management Card option. HID-compliant USB interface enables full integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces at once. PowerAlert UPS monitoring software is available via free download. Emergency Power Off (EPO) interface. Integrated 3-bank programmable PDU switching supports load shedding and remote-reboot of up to 3 individual connected devices. 3-stage metered current monitoring and battery charge status LEDs. Utility power and voltage regulation LEDs. Audible alarm. Self-test. 2-post rackmount accessories included; 2-9USTAND tower stands and 4POSTRAILKIT 4 post rackmount kit available. Fieldreplaceable, hot-swappable internal batteries and external battery packs. Attractive all-black color scheme. Features ● Tripp Lite's SmartPro Compact Rackmount Uninterruptible Power Supply (UPS) offers line interactive voltage regulation, network grade surge suppression and long lasting battery support for critical network hardware during blackouts and extended power failures ● Special reduced-depth housing, larger internal batteries, higher rated wattage and included 2 post rackmount installation hardware makes these systems ideal for network and telecom wiring closets and other limited-space installations ● Runtime is expandable with optional BP48V24-2U (limit 1), BP48V48RT4U (multi-pack compatible) and 1/6 ● SmartPro Compact 4U Rackmount UPS system ● 2 post rackmount installation brackets ● USB and Serial Cabling ● Owner's manual information 1000 Eaton Boulevard Cleveland, OH 44122 United States BP48V27-2US (multi-pack compatible) external battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Intelligent battery management system extends battery life ● SMART3000CRMXL 4U rackmount 3000VA/2880 watt UPS offers battery-derived sine wave AC output during power failures and extreme voltage variations ● Supports loading up to 3600 watts when hardwired ● Line interactive Automatic Voltage Regulation (AVR) provides two levels of voltage boost during brownouts and one level of voltage cut during overvoltage conditions to maintain regulated 120V nominal output over an input range of 83-145V ● Includes NEMA L5-30P input plug (hardwire line cord installation supported), L5-30R and 5-15/20R output receptacles ● Network management interfaces support simultaneous communications via USB port, DB9 serial port and installed Network Management Card option ● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and RELAYIOCARD ● HID-compliant USB interface enables full integration with built-in power management and auto shutdown features of Windows and Mac OS X ● 97% efficiency in line power mode offers substantially lower operating costs than lower efficiency UPS types ● Supports detailed monitoring of equipment load levels, self-test data and utility power conditions via all 3 network interfaces at once ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Emergency Power Off (EPO) interface ● Integrated 3-bank programmable PDU switching supports load shedding and remote-reboot of up to 3 individual connected devices ● 3-stage metered current monitoring and battery charge status LEDs; Utility power and voltage regulation LEDs; Audible alarm; Self-test ● 2-post rackmount accessories included; 2-9USTAND tower stands and 4POSTRAILKIT 4 post rackmount kit available ● Field-replaceable, hot-swappable internal batteries and external battery packs ● Attractive all-black color scheme Specifications OVERVIEW UPC Code 037332142375 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 24A (L5-30P input), 30A (hardwire) Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type L5-30P; Hardwire UPS Input Cord Length (ft.) 10 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Cord Length (m) 3.1 Recommended Electrical Service 120V 30A Voltage Compatibility (VAC) 120 OUTPUT Output Capacity (VA) 3000 Output Capacity (kVA) 3 Output Capacity (Watts) 2880 Output Capacity (kW) 2.88 Output Capacity Details Maximum output increases to 3600W when used with hardwire input Power Factor .96 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/-5% Load Management Receptacles Three switchable single-outlet 5-15/20R load banks Output Circuit Breakers 20A (x2) - each 20A breaker protects 4 5-15/20R outlets / 30A breaker protects L5-30R Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15/20R; (1) L5-30R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7.5 min. (2880W) Runtime Half Load (min.) 19 min. (1440W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V48RT4U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 7.2 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door allows hot swap battery replacement without powering connected equipment off 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Internal UPS Replacement Battery Cartridge  RBC94-2U  (quantity 2) VOLTAGE REGULATION Voltage Regulation Description Automatic Voltage Regulation (AVR) circuits maintain clean, regulated computer-grade 120V nominal output, without using battery power, during brownouts to 83V and overvoltages to 145V Overvoltage Correction Input voltages between 127 and 145V AC are reduced by 12% Undervoltage Correction Input voltages between 96 and 108 are boosted by 12% Severe Undervoltage Correction Input voltages between 83 and 95 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Switches Yes, includes 2 front panel mounted push-button switches for system enable, self-test and alarm cancel functions. Back panel includes battery charge level switch for internal or external battery configurations Audible Alarm 3 function audible alarm indicates power failure conditions (4 short beeps every 10 seconds), overload (continuous short beeps) and low battery (continuous tone) LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount Rack Height 4U Cooling Method Fan Included Mounting Accessory Description Included 2POSTRMKITWM mounting accessory enables 2-post rackmount installation Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 4 post rackmount full-depth ( 4POSTRAILKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 2-9USTAND ) Minimum Required Rack Depth (cm) 53.34 Minimum Required Rack Depth (inches) 21 Minimum Required Rack Depth with External Battery Pack (cm) 64 Minimum Required Rack Depth with External Battery Pack (in.) 25 Minimum Required Rack Depth without External Battery Pack (cm) 58 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth without External Battery Pack (in.) 22.8 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  4POSTRAILKIT  mounting bracket enables installation in 4 post racks from 20.5 to 36 inches;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm) Primary UPS Depth (mm) 452 Primary UPS Height (mm) 175 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 13.00 x 23.50 x 22.50 Shipping Dimensions (hwd / cm) 33.02 x 59.69 x 57.15 Shipping Weight (lbs.) 128.50 Shipping Weight (kg) 58.29 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 17.50 x 43.94 x 45.21 UPS Power Module Dimensions (hwd, in.) 6.89 x 17.30 x 17.80 UPS Power Module Weight (kg) 46.27 UPS Power Module Weight (lbs.) 102 Unit Weight (lbs.) 102.000 Unit Weight (kg) 46.27 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0-95%, non-condensing AC Mode BTU / Hr. (Full Load) 539 Battery Mode BTU / Hr. (Full Load) 2159 Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX ;  RELAYIOCARD  PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert WatchDog Compatibility Yes, compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application / OS or hard power off/on reboot of connected equipment ideal for unattended kiosk applications 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States EPO Port Includes RJ11 EPO (emergency power off) port and interconnection cable SNMP Compatibility Compatible with Tripp Lite UPS management card options  WEBCARDLX , SNMPWEBCARD and  RELAYIOCARD  Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 5 ms. (typical) Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART3000CRMXL 价格&库存
很抱歉,暂时无法提供与“SMART3000CRMXL”相匹配的价格&库存,您可以联系我们找货
