1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 3kVA 2.25kW Line-Interactive
Sine Wave UPS, Tower, Network Card Options,
USB, DB9 Serial
Highlights
3kVA / 3000VA line interactive
tower UPS; Sine wave output
120V nominal output during
brownouts to 83 and
overvoltages to 145V
USB, RS232, EPO and Network
Management Card options
Front panel status LEDs with
detailed load and battery
capacity display
NEMA L5-30P input; 6 NEMA 515/20R & 1 L5-30R outlets
MODEL NUMBER: SMART3000SLT
Package Includes
Description
3000VA line-interactive tower UPS system for server, networking and telecommunications equipment.
Upright tower form factor. Offers sine wave 120V nominal output in both AC and battery modes. Switches
to battery-derived AC output during power failures and extreme voltage variations. Line-interactive
automatic voltage regulation (AVR) provides voltage boost/cut during brownouts/overvoltages to maintain
regulated 120V nominal output over an input voltage range of 83-145V. Includes NEMA L5-30P input plug
and 7 UPS-supported output receptacles (6 x 5-15/20R, 1 x L5-30R). Network-grade AC surge and noise
suppression. Network management interfaces support simultaneous communications via USB port, DB9
serial port and installed Network Management Card. HID-compliant USB interface enables integration with
built-in power management and auto shutdown features of Windows and Mac OS X. Supports
simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via
all three network interfaces. PowerAlert power management software is available via free download.
Three-stage metered current monitoring and battery charge status LEDs. Utility power and voltage
regulation, and battery warning LEDs. Audible alarm. Self-test. Field-replaceable, hot-swappable internal
batteries. Attractive all-black color scheme.
Features
SmartPro line-interactive UPS system is ideal for voice, data, medical and industrial networking
applications
Line-interactive voltage regulation maintains selectable 120V nominal output during brownouts as low
as 83V and overvoltages to 145V
Enables continuous operation through blackouts, voltage fluctuations and surges
Line-interactive automatic voltage regulation (AVR) provides 12% and 24% voltage boost during
brownouts and a 12% voltage cut during overvoltages
Standard internal battery set offers 9 min. runtime at half load (1125W) and 3.5 min. at full load (2250W)
Intelligent battery management system extends battery life
Space-saving upright tower format
Built-in USB, RS-232 and slot for Network Management Card option; Compatible with Tripp Lite UPS
management card options WEBCARDLX, RELAYIOCARD and SNMPWEBCARD
HID-compliant USB interface enables integration with built-in power management and auto shutdown
1/5
SMART3000SLT UPS System
USB & DB9 Cables
Owner's manual
Cleveland, OH 44122
United States
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current
monitoring, battery charge current, battery capacity, timed inverter shutoff, activate self-test and output
power control
NEMA L5-30P input plug/6 x NEMA 5-15/20R and 1 x NEMA L5-30R output receptacles
Front panel LEDs provide current monitoring, voltage regulation, battery charge level and battery
warning information
UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of
internal batteries by user required
Specifications
OVERVIEW
UPC Code
037332125767
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
20A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
L5-30P
Input Circuit Breakers
30A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 120V
OUTPUT
Output Capacity (VA)
3000
Output Capacity (kVA)
3
Output Capacity (Watts)
2250
Output Capacity (kW)
2.25
Power Factor
0.8
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18% / +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output Circuit Breakers
20A branch rated (x2) - each breaker protects 3 5-15/20R outlets, L5-30R is unbreakered
2/5
Cleveland, OH 44122
United States
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15/20R; (1) L5-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.5 min. (2250W)
Runtime Half Load (min.)
9 min. (1125W)
Expandable Runtime
No
DC System Voltage (VDC)
48
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC54
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145
Overvoltage Correction
Input voltages between 127 and 145 are reduced by 12%; Voltage setpoints ±5% tolerance
Undervoltage Correction
Input voltages between 96 and 108V are boosted by 12%; Voltage setpoints ±5% tolerance
Severe Undervoltage Correction
Input voltages between 83 and 95V are boosted by 24%; Voltage setpoints ±5% tolerance
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power failure and overload conditions
LED Indicators
9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for
load and battery charge level
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
570
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
318
Primary UPS Height (mm)
267
Primary UPS Width (mm)
226
Shipping Dimensions (hwd / in.)
15.30 x 17.80 x 13.70
Shipping Dimensions (hwd / cm)
38.86 x 45.21 x 34.80
Shipping Weight (lbs.)
75.50
Shipping Weight (kg)
34.25
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
26.67 x 22.61 x 31.75
(hwd, in.)
10.5 x 8.9 x 12.5
UPS Power Module Weight (kg)
25.85
UPS Power Module Weight (lbs.)
57
Unit Weight (lbs.)
57.0000
Unit Weight (kg)
25.85
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
320
Battery Mode BTU / Hr. (Full Load)
1251
AC Mode Efficiency Rating (100%
Load)
96%
Audible Noise
Audible Noise < 50 dBA at Front Side 1 Meter
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; WEBCARDLX ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
4/5
Cleveland, OH 44122
United States
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
83
High Voltage Transfer to Battery
Power (Setpoint)
145
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
