1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 120V 1.5kVA 900W Line-Interactive
Sine Wave UPS, Tower, Network Card Options,
USB, DB9, 8 Outlets
MODEL NUMBER: SMART1500SLT
Highlights
Corrects under- and
overvoltages from 95V to 145V
8 NEMA 5-15R outlets
Front-panel LEDs indicate load,
power and battery statuses
Monitoring of power conditions
via PowerAlert®
20 min. runtime at half load; 8
min. at full load
Designed for commercial
applications; see product
description for home-use
recommendations
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, power surges and line noise. Ideal solution for VoIP systems, point-of-sale applications and
network closets.
Description
The SMART1500SLT SmartPro 120V 1.5kVA 900W Line-Interactive Sine Wave UPS provides battery
backup and AC power protection against blackouts, brownouts, power surges and line noise that can
damage electronics or destroy data. Ideal for backing up VoIP systems, point-of-sale applications and
network closets, the SMART1500SLT switches to battery mode in milliseconds to keep your connected
equipment running long enough to save files and shut down safely with no data loss.
Featuring eight NEMA 5-15R outlets and a six-foot power cord with NEMA 5-15P input, the
SMART1500SLT has an internal battery that provides 20 minutes of support at half load and eight minutes
at full load. Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery
status. An alarm sounds to indicate power failure and overload conditions.
Automatic voltage regulation (AVR) maintains selectable 100V, 110V or 120V nominal output over an
input range of 95V to 145V without using battery power. EMI/RFI noise filtering improves your equipment’s
performance and prevents damage. A 690-joule surge suppression rating protects your equipment from
harmful power surges. With Tripp Lite’s PowerAlert software (available via free download),
SMART1500SLT enables safe unattended system shutdown and file saves in case of a prolonged power
failure.
This product is designed with features typically required in commercial applications, including network
connectivity and a ruggedized case. For home use, consider SMART1500 or SMART1500LCDT. Click to
compare product features.
Features
Protects Mission-Critical Equipment
● Provides fully regulated AC output for VoIP systems, point-of-sale applications and network closets
Audible alarm signals loss of utility power or overload
6 ft. power cord with NEMA 5-15P input
Reliable Battery Backup
● Supports half load up to 20 min. and full load up to 8 min.
1/6
120V 1.5kVA 900W LineInteractive Sine Wave UPS
USB cable
DB9 cable
Owner’s manual
Cleveland, OH 44122
United States
Internal batteries designed for hot-swap field replacement
95% line-power efficiency rating saves money in energy costs
Cold-start capability enables turn-on in battery mode during blackouts
Automatic Voltage Regulation (AVR)
● Maintains selected 100V, 110V or 120V nominal output over input range of 95V–145V without using
battery power
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
LED Indicators
● Front-panel LEDs signal indicate line power, battery power, overload, voltage regulation and battery
status
Network Management Cards
● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and
RELAYIOCARD
Communications Ports
● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
RJ45 Telephone/Ethernet Protection Jacks
● Protect phone/DSL/fax/modem/Ethernet network against power surges
Specifications
OVERVIEW
UPC Code
037332119896
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10.1A (100V), 9.3A (110V), 8.6A (120V)
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
Total Harmonic Distortion
0.03
2/6
Cleveland, OH 44122
United States
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Output Capacity Details
7.5A @ 120V (default), 8.2A @ 110V, 9A @ 100V. 125% @ 10 minutes 110% +/- 10% @ 5 seconds
Power Factor
0.63
Nominal Voltage Details
120V sinusoidal in line mode and 120V sinusoidal in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection. Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal.
Output Voltage Regulation (Line
Mode)
-13%, + 15%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
100V; 110V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
8 min. (900W)
Runtime Half Load (min.)
20 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 6 hours from 10% to 80% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC36-SLT
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 95 to 145 (120v),
87 to 133 (110v), 83 to 121 (100v)
Overvoltage Correction
Voltage reduction of 12% applies when input is 127 to 145 (120v), 116 to 133 (110v), 111 to 121 (100v); All voltage
setpoints ±5% tolerance
3/6
Cleveland, OH 44122
United States
Undervoltage Correction
Voltage boost of 14% applies when input is 95 to 108 (120v), 87 to 99 (110v), 83 to 90 (100v); All voltage setpoints
±5% tolerance
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support
nominal voltage selection
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power failure and overload conditions
LED Indicators
Status LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter
for load and battery charge level
Site Wiring Fault Indication
Rear panel site wiring fault LED
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
690
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
335
Primary UPS Height (mm)
259
Primary UPS Width (mm)
173
Shipping Dimensions (hwd / in.)
13.90 x 9.70 x 17.60
Shipping Dimensions (hwd / cm)
35.31 x 24.64 x 44.70
Shipping Weight (lbs.)
48.10
Shipping Weight (kg)
21.82
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
25.91 x 17.27 x 33.53
(hwd, in.)
10.2 x 6.8 x 13.2
UPS Power Module Weight (kg)
20.41
UPS Power Module Weight (lbs.)
45
Unit Dimensions (hwd / in.)
10.250 x 6.750 x 13.250
Unit Weight (lbs.)
45.0000
4/6
Cleveland, OH 44122
United States
Unit Weight (kg)
20.41
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
148
Battery Mode BTU / Hr. (Full Load)
500
AC Mode Efficiency Rating (100%
Load)
95%
Operating Elevation (ft.)
6561 ft. (2000 m) above sea level
Audible Noise
Audible Noise < 50 dBA at Front Side 1 Meter
COMMUNICATIONS
SNMPWEBCARD; WEBCARDLX ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
4-6 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
95V (120V), 87V (110V), 83V (100V); All voltage setpoints ±5% tolerance
High Voltage Transfer to Battery
Power (Setpoint)
145V (120V), 133V (110V), 121V (100V); All voltage setpoints ±5% tolerance
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
5/6
Cleveland, OH 44122
United States
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
